Configurazione Tuner su Vu+ Zero 4k
Hai attivato la Oscam?
Tasto blu - Impostazioni softcam
Poi se non funziona ancora accedi all'interfaccia Oscam sul decoder:
http://xxx.xxx.xxx.xxx:8081
Fai il restart della Oscam e poi posta il log della schermata "Status" che contiene i dati di avvio.
Scusami Eragon ho avuto un attimo da fare, comunque dal live status di oscam mi dice questo:
1970/01/01 02:03:55 615918DC r (reader) lower_card [internal] detect nagra tiger card
1970/01/01 02:03:58 615918DC r (reader) lower_card [internal] Resync error: readtimeouts 0/0 (max/min) us, writetimeouts 0/0 (max/min) us
1970/01/01 02:04:01 615918DC r (reader) lower_card [internal] T1 Resync command error, trying to reactivate!
1970/01/01 02:04:02 615918DC r (reader) lower_card [internal] ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
1970/01/01 02:04:02 615918DC r (reader) lower_card [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 02:04:02 615918DC r (reader) lower_card [internal] Calculated work ETU is 7.11 us reader mhz = 450
1970/01/01 02:04:05 615918DC r (reader) lower_card [internal] Buffers readed 0 bytes total time_us 3099773
1970/01/01 02:04:06 615918DC r (reader) lower_card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
1970/01/01 02:04:06 615918DC r (reader) lower_card [internal] Card responded ok for ifsd request of 251
1970/01/01 02:04:06 615918DC r (reader) lower_card [internal] card system not supported
1970/01/01 02:04:06 615918DC r (reader) lower_card [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
1970/01/01 02:04:06 615918DC r (reader) lower_card [internal] card initializing error
Metti solo questo dentro il file oscam.conf e riavvia la oscam:
(NB: tutti i parametri su una riga senza ritorni a capo, per editare i file usa Notepad++)
# oscam.conf generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11272
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.conf.txt
[global]
logfile = /dev/tty
clienttimeout = 4000
clientmaxidle = 300
netprio = 1
nice = -1
maxlogsize = 1000
preferlocalcards = 2
dropdups = 1
[cache]
[newcamd]
port = 18000@183E:005411,000000;18001@183D:005411,000000
key = 0102030405060708091011121314
[cccam]
port = 12000
nodeid = F8EC58A010561576
version = 2.3.0
reshare = -1
[dvbapi]
enabled = 1
au = 1
pmt_mode = 0
user = locale
read_sdt = 1
write_sdt_prov = 1
boxtype = dreambox
[webif]
httpport = 8081
httpshowmeminfo = 1
httpshowuserinfo = 1
httpshowcacheexinfo = 1
httpshowecminfo = 1
httpshowloadinfo = 1
httpallowed = 127.0.0.1,192.168.0.1-192.168.255.255,10.0.0.1-10.255.255.255
http_status_log = 1
[global]
logfile = /dev/tty
clientmaxidle = 300
netprio = 1
nice = -1
maxlogsize = 1000
dropdups = 1
[cache]
[newcamd]
[cccam]
port = 12000
version = 2.3.0
reshare = -1
[dvbapi]
enabled = 1
au = 1
pmt_mode = 0
user = locale
read_sdt = 1
write_sdt_prov = 1
boxtype = dreambox
[webif]
httpport = 8081
httpshowmeminfo = 1
httpshowecminfo = 1
http_status_log = 1
Allora ho provato a fare tutto quello che mi hai detto, ti allego la mia cartella dropbox dove trovi le immagini come ho configurato su tuo consiglio (i file provid, user e srvid non li ho modificato) riavviato la oscam ma il log è sempre questo:
1970/01/01 03:01:44 615918DC r (reader) lower_card [internal] card detected
1970/01/01 03:01:45 615918DC r (reader) lower_card [internal] ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
1970/01/01 03:01:45 615918DC r (reader) lower_card [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 03:01:45 615918DC r (reader) lower_card [internal] Calculated work ETU is 7.11 us reader mhz = 450
1970/01/01 03:01:48 615918DC r (reader) lower_card [internal] Buffers readed 0 bytes total time_us 3099763
1970/01/01 03:01:49 615918DC r (reader) lower_card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
1970/01/01 03:01:49 615918DC r (reader) lower_card [internal] Card responded ok for ifsd request of 251
1970/01/01 03:01:50 615918DC r (reader) lower_card [internal] detect nagra tiger card
1970/01/01 03:01:50 615918DC r (reader) lower_card [internal] card system not supported
1970/01/01 03:01:50 615918DC r (reader) lower_card [internal] Normal mode failed, reverting to Deprecated Mode
1970/01/01 03:01:51 615918DC r (reader) lower_card [internal] ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
1970/01/01 03:01:51 615918DC r (reader) lower_card [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 03:01:51 615918DC r (reader) lower_card [internal] Calculated work ETU is 82.67 us reader mhz = 450
1970/01/01 03:01:54 615918DC r (reader) lower_card [internal] Buffers readed 0 bytes total time_us 3099735
1970/01/01 03:01:55 615918DC r (reader) lower_card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
1970/01/01 03:01:58 615918DC r (reader) lower_card [internal] Warning: Card returned error on setting ifsd value to 251
1970/01/01 03:01:59 615918DC r (reader) lower_card [internal] detect nagra tiger card
1970/01/01 03:02:02 615918DC r (reader) lower_card [internal] Resync error: readtimeouts 0/0 (max/min) us, writetimeouts 0/0 (max/min) us
1970/01/01 03:02:06 615918DC r (reader) lower_card [internal] T1 Resync command error, trying to reactivate!
1970/01/01 03:02:07 615918DC r (reader) lower_card [internal] ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
1970/01/01 03:02:07 615918DC r (reader) lower_card [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
1970/01/01 03:02:07 615918DC r (reader) lower_card [internal] Calculated work ETU is 7.11 us reader mhz = 450
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] Buffers readed 0 bytes total time_us 3099743
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] Card responded ok for ifsd request of 251
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] card system not supported
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
1970/01/01 03:02:10 615918DC r (reader) lower_card [internal] card initializing error
Prova a mettere solo questo nel file oscam.user:
# oscam.user generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11272
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.user.txt
[account]
user = locale
hostname = 127.0.0.1
monlevel = 4
au = 1
group = 1,2
cccignorereshare = 0
Una volta fatto il riavvio della oscam, posta il log del riquadro della finestra Status, no quello del live log.
[account]
user = locale
monlevel = 4
au = 1
group = 1,2
1970/01/01 01:03:47 00000000 s >> OSCam << cardserver log switched, version 1.20-unstable_svn, build r11420 (arm-oe-linux-gnueabi)
1970/01/01 01:03:47 00000000 s (main) System name = Linux
1970/01/01 01:03:47 00000000 s (main) Host name = vuzero4k
1970/01/01 01:03:47 00000000 s (main) Release = 4.1.20-1.9
1970/01/01 01:03:47 00000000 s (main) Version = #1 SMP Tue May 8 04:13:13 CEST 2018
1970/01/01 01:03:47 00000000 s (main) Machine = armv7l
1970/01/01 01:03:47 00000000 s (main) Stb model = dm8000
1970/01/01 01:03:47 00000000 s (main) Stb vumodel = vuzero4k
1970/01/01 01:03:47 00000000 s (main) Stb boxtype = vuzero4k
1970/01/01 01:03:47 00000000 s (main) The current system time is smaller than the build date (May 8 2018). Waiting up to 60 seconds for time to correct
1970/01/01 01:04:48 00000000 s (main) Waiting was not successful. OSCam will be started but is UNSUPPORTED this way. Do not report any errors with this version.
1970/01/01 01:04:48 00000000 s (main) creating pidfile /tmp/oscam.pid with pid 1330
1970/01/01 01:04:48 00000000 s (config) services reloaded: 0 services freed, 1 services loaded, rejected 0
1970/01/01 01:04:48 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
1970/01/01 01:04:48 00000000 s (main) signal handling initialized
1970/01/01 01:04:48 00000000 s (config) 10 provid's loaded
1970/01/01 01:04:48 00000000 s (config) 164 service-id's loaded in 0 ms
1970/01/01 01:04:48 00000000 s (net) newcamd: initialized (fd=4, port=18000, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
1970/01/01 01:04:48 00000000 s (net) -> CAID: 183E PROVID: 005411, 000000
1970/01/01 01:04:48 00000000 s (net) newcamd: initialized (fd=5, port=18001, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
1970/01/01 01:04:48 00000000 s (net) -> CAID: 183D PROVID: 005411, 000000
1970/01/01 01:04:48 00000000 s (net) cccam: initialized (fd=6, port=12000, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
1970/01/01 01:04:48 00000000 s (reader) tivusat_card [internal] creating thread for device /dev/sci1
1970/01/01 01:04:48 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
1970/01/01 01:04:48 00000000 s (main) waiting for local card init
1970/01/01 01:04:48 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:48 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:04:48 663A0EE6 h (webif) webif: decompressed 176846 bytes back into 435776 bytes
1970/01/01 01:04:48 663A0EE6 h (webif) HTTP Server running. ip=:: port=8081
1970/01/01 01:04:50 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:50 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:04:52 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:52 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:04:54 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:54 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:04:56 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:56 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:04:58 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:04:58 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:00 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:05:00 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:02 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:05:02 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:04 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:05:04 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:06 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:05:06 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:08 040136D9 r (reader) tivusat_card [internal] ERROR: Opening device /dev/sci1 (errno=2 No such file or directory)
1970/01/01 01:05:08 040136D9 r (reader) tivusat_card [internal] Cannot open device: /dev/sci1
1970/01/01 01:05:08 040136D9 r (reader) tivusat_card [internal] Deactivating card
1970/01/01 01:05:08 040136D9 r (reader) tivusat_card [internal] Error:Sci_Deactivate ioctl(IOCTL_GET_IS_CARD_PRESENT) failed.(9:Bad file descriptor)
1970/01/01 01:05:08 00000000 s (main) init for all local cards done
1970/01/01 01:05:08 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
1970/01/01 01:05:08 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
1970/01/01 01:05:08 00000000 s (anticasc) anti cascading disabled
1970/01/01 01:05:08 21B5A112 c (client) plain dvbapi-client granted (locale, au=auto (1 reader))
1970/01/01 01:05:08 21B5A112 c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam/oscam.ccache
1970/01/01 01:05:08 21B5A112 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
Hai 2 errori, primo, l'orario del decoder e' sbagliato, e questo succede se non hai impostato di prendere l'orario dal sat, oppure non hai mai sintonizzato un canale sat.
Secondo, non trova proprio la smartcard, non e' che l'hai inserita al contrario nello slot?
Altrimenti, prova a mettere /dev/sci0
2018/08/05 15:48:42 00000000 s >> OSCam << cardserver log switched, version 1.20-unstable_svn, build r11420 (arm-oe-linux-gnueabi)
2018/08/05 15:48:42 00000000 s (main) System name = Linux
2018/08/05 15:48:42 00000000 s (main) Host name = vuzero4k
2018/08/05 15:48:42 00000000 s (main) Release = 4.1.20-1.9
2018/08/05 15:48:42 00000000 s (main) Version = #1 SMP Tue May 8 04:13:13 CEST 2018
2018/08/05 15:48:42 00000000 s (main) Machine = armv7l
2018/08/05 15:48:42 00000000 s (main) Stb model = dm8000
2018/08/05 15:48:42 00000000 s (main) Stb vumodel = vuzero4k
2018/08/05 15:48:42 00000000 s (main) Stb boxtype = vuzero4k
2018/08/05 15:48:42 00000000 s (main) creating pidfile /tmp/oscam.pid with pid 1430
2018/08/05 15:48:42 00000000 s (config) services reloaded: 0 services freed, 1 services loaded, rejected 0
2018/08/05 15:48:42 00000000 s (config) userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
2018/08/05 15:48:42 00000000 s (main) signal handling initialized
2018/08/05 15:48:42 00000000 s (config) 10 provid's loaded
2018/08/05 15:48:42 00000000 s (config) 164 service-id's loaded in 1 ms
2018/08/05 15:48:42 00000000 s (net) newcamd: initialized (fd=4, port=18000, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
2018/08/05 15:48:42 00000000 s (net) -> CAID: 183E PROVID: 005411, 000000
2018/08/05 15:48:42 00000000 s (net) newcamd: initialized (fd=5, port=18001, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
2018/08/05 15:48:42 00000000 s (net) -> CAID: 183D PROVID: 005411, 000000
2018/08/05 15:48:42 00000000 s (net) cccam: initialized (fd=6, port=12000, prio=1 [ SO_PRIORITY IP_TOS IPV6_TCLASS ])
2018/08/05 15:48:42 00000000 s (reader) tivusat_card [internal] creating thread for device /dev/sci0
2018/08/05 15:48:42 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
2018/08/05 15:48:42 00000000 s (main) waiting for local card init
2018/08/05 15:48:42 4FE2BE0F r (reader) tivusat_card [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2018/08/05 15:48:42 4FE2BE0F r (reader) tivusat_card [internal] Reader sci internal, detected box type: vuzero4k
2018/08/05 15:48:42 45A519F6 h (webif) webif: decompressed 176846 bytes back into 435776 bytes
2018/08/05 15:48:42 45A519F6 h (webif) HTTP Server running. ip=:: port=8081
2018/08/05 15:48:43 4FE2BE0F r (reader) tivusat_card [internal] card detected
2018/08/05 15:48:44 4FE2BE0F r (reader) tivusat_card [internal] ATR: 3F FF 95 00 FF 91 81 71 FE 47 00 54 49 47 45 52 36 30 31 20 52 65 76 4D 38 37 14
2018/08/05 15:48:44 4FE2BE0F r (reader) tivusat_card [internal] Init card protocol T1, FI=9, F=512, D=16, N=255
2018/08/05 15:48:44 4FE2BE0F r (reader) tivusat_card [internal] Calculated work ETU is 7.11 us reader mhz = 450
2018/08/05 15:48:47 4FE2BE0F r (reader) tivusat_card [internal] Buffers readed 0 bytes total time_us 3099689
2018/08/05 15:48:47 4FE2BE0F r (reader) tivusat_card [internal] PLL Reader: ATR Fsmax is 5 MHz, clocking card to 4.50 Mhz (nearest possible mhz specified reader->mhz)
2018/08/05 15:48:47 4FE2BE0F r (reader) tivusat_card [internal] Card responded ok for ifsd request of 251
2018/08/05 15:48:48 4FE2BE0F r (reader) tivusat_card [internal] detect nagra tiger card
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [internal] type: NAGRA, caid: 183E, IRD ID: ############
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [internal] ProviderID: 00 00 54 11
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [internal] ready for requests
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [internal] found card system nagra
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] ROM: T I G E R 6 0 1
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] REV: R e v M 8 7
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] SER: ############
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] CAID: 183E
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] Prv.ID: 00 00 54 11 (sysid)
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] Activation Date : 01/01/2009
2018/08/05 15:48:49 4FE2BE0F r (reader) tivusat_card [nagra] Expiry Date : 01/01/2038
2018/08/05 15:48:50 00000000 s (main) init for all local cards done
2018/08/05 15:48:50 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
2018/08/05 15:48:50 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
2018/08/05 15:48:50 00000000 s (anticasc) anti cascading disabled
2018/08/05 15:48:50 47CA3954 c (client) plain dvbapi-client granted (locale, au=auto (1 reader))
2018/08/05 15:48:50 47CA3954 c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam/oscam.ccache
2018/08/05 15:48:50 47CA3954 c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
Adesso ci siamo? comunque la tessera l'ho inserita con il chip verso il basso
Adesso si'!
Aspetta che si aggiornino i diritti sulla smartcard sul canale sat RAI 1 HD.
La tessera l'hai mai usata su un decoder ufficiale Tivusat? Nel senso è stata già attivata o stai cercando di attivarla ora tramite il Vu Zero 4k?
Ti chiedo questo perchè ricordo (ma non sono sicuro al 100%) che la tessera non si riesce ad attivare tramite decoder non ufficiali Tivusat, per esempio io avevo un decoder Tivusat ufficiale ed ho attivato la tessera tramite questo ed ora utilizzo la tessera senza problemi sul mio Vu Solo 4k.
Ciao carissimo ti posso dire che la tessera anche se non l ho attivata da decoder tvsat funziona!
Nel file oscam.services i srvid devono stare tutti su una riga senza spazi.
Prova a fare manualmente la ricerca sui transponder dei canali che mancano.
Comunque dopo aver selezionato un canale che non vedi c'e' sempre il live log della oscam che ti dice perche' non riesce a decodificare quel canale.
PS. non c'e' bisogno di attivare la smartcard su un decoder Tivusat, la Oscam puo' fare tutto da sola.:)
2018/08/05 18:07:53 00000000 s (emmcache) loaded 3 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
2018/08/05 18:07:53 00000000 s (emmcache) loaded 3 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
2018/08/05 18:07:53 00000000 s (anticasc) anti cascading disabled
2018/08/05 18:07:53 41281B8E c (client) plain dvbapi-client granted (locale, au=auto (1 reader))
2018/08/05 18:07:53 41281B8E c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam/oscam.ccache
2018/08/05 18:07:53 41281B8E c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0919 ECM_PID: 1878 PROVID: 000000
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 ecmpid 1 CAID: 09CD ECM_PID: 1879 PROVID: 000000
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 ecmpid 2 CAID: 093B ECM_PID: 187A PROVID: 000000
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 ecmpid 3 CAID: 183D ECM_PID: 187B PROVID: 000000
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 ecmpid 4 CAID: 183E ECM_PID: 187C PROVID: 000000
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 found 5 ECMpids and 3 STREAMpids in caPMT
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2018/08/05 18:07:55 41281B8E c (dvbapi) Demuxer 0 found 5 ECMpids and 3 STREAMpids in PMT
2018/08/05 18:07:56 41281B8E c (dvbapi) Demuxer 0 stop descrambling program number 0E2A (NOVE)
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 ecmpid 0 CAID: 183D ECM_PID: 1081 PROVID: 000000
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 ecmpid 1 CAID: 183E ECM_PID: 1149 PROVID: 000000
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 found 2 ECMpids and 10 STREAMpids in caPMT
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 found channel in cache and matching prio -> start descrambling ecmpid 1
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 183E PROVID 000000 ECMPID 1149 ANY CHID PMTPID 044D VPID 01F5
2018/08/05 18:07:57 41281B8E c (dvbapi) Demuxer 0 found 2 ECMpids and 10 STREAMpids in PMT
2018/08/05 18:07:57 41281B8E c (ecm) locale (183E@000000/0000/0D49/91:2A625A0D89BE18A8F46AECA7A03CF6B6): found (229 ms) by tivusat_card - Rai 1 HD
2018/08/05 18:08:00 41281B8E c (ecm) locale (183E@000000/0000/0D49/91:37D70BEE51734267EA44F1F8A696975F): found (229 ms) by tivusat_card - Rai 1 HD
2018/08/05 18:08:11 41281B8E c (ecm) locale (183E@000000/0000/0D49/91:67A932693A51A09920C491C81F91D436): found (229 ms) by tivusat_card - Rai 1 HD
2018/08/05 18:08:15 41281B8E c (dvbapi) Demuxer 0 stop descrambling program number 0D49 (Rai 1 HD)
2018/08/05 18:08:15 41281B8E c (dvbapi) Demuxer 0 ecmpid 0 CAID: 183D ECM_PID: 1896 PROVID: 000000
2018/08/05 18:08:15 41281B8E c (dvbapi) Demuxer 0 ecmpid 1 CAID: 183E ECM_PID: 1897 PROVID: 000000
2018/08/05 18:08:15 41281B8E c (dvbapi) Demuxer 0 found 2 ECMpids and 2 STREAMpids in caPMT
2018/08/05 18:08:15 41281B8E c (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2018/08/05 18:08:16 41281B8E c (dvbapi) Demuxer 0 found 2 ECMpids and 2 STREAMpids in PMT
2018/08/05 18:08:20 41281B8E c (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2018/08/05 18:09:31 41281B8E c (-) -- Skipped 14 duplicated log lines --
Se non vedi un canale Tivusat (cioe' resta nero), allora attiva l'infobar e guarda il codice ID che viene mostrato, e aggiungi quel numero nel file
oscam.services
in coda alla riga "srvid" (precedendolo con una virgola e senza spazi)
Ad es il codice di RAI 1 HD e' quello cerchiato in rosso:
E questo e' il codice per il canale Nove:
