Aggiornamento LG Webos
Su vari canali sat l'interattività hbbtv non e' proprio presente e prevista.
Detailed applicable model list : Please check with reference Tab exactly
* SW information
1. Improvement
1) LG Channel has been upgraded and service territory expansion. (Selected Countries Only)
2) Software update contains minor bug fix
2. Applicable model list
OLED65W7V-Z
OLED77W7V-Z
OLED65G7V-Z
OLED77G7V-Z
OLED55E7N-Z
OLED65E7V-Z
OLED55C7D-Z
OLED55C7V-Z
OLED65C7D-Z
OLED65C7V-Z
OLED55B7D-Z
OLED65B7D-Z
OLED55B7V-Z
OLED65B7V-Z
49SK7900PLA
55SK7900PLA
65SK7900PLA
86SJ957V-ZA
75SJ955V-ZA
55SJ950V-ZA
65SJ950V-ZA
65SJ9509-ZA
55SJ850V-ZA
60SJ850V-ZA
65SJ850V-ZA
55SJ930V-ZA
65SJ930V-ZA
55SJ8509-ZA
60SJ8509-ZA
65SJ8509-ZA
49SJ810V-ZA
55SJ810V-ZA
60SJ810V-ZA
65SJ810V-ZA
49SJ8109-ZA
55SJ8109-ZA
65SJ8109-ZA
49SJ800V-ZB
55SJ800V-ZB
65SJ800V-ZB
43UJ750V-ZB
49UJ750V-ZB
55UJ750V-ZB
60UJ750V-ZB
65UJ750V-ZB
49UJ7509-ZB
55UJ7509-ZB
65UJ7509-ZB
43UJ7507-ZB
49UJ7507-ZB
55UJ7507-ZB
60UJ7507-ZB
65UJ7507-ZB
43UJ740V-ZA
49UJ740V-ZA
55UJ740V-ZA
3. Release History
[03.51.20]
1. Improved shaking video periodically when connecting VideoCon STB.
2. Improved blinking screen when changing channel after close livezoom.
3. Improved UI moving slowly when playing store demo.
4. Improved lipsync issue on DTV in OLED model.
5. Improved ATV noise on bottom of screen.
[03.60.09]
1. Improvements in HDR (HDR 10/ HLG)
2. Bugs fix in Dolby vision
3. Improvements in shortcut key for apps on remote controller.
4. Improvements in Dolby Atmos
[03.60.15]
1. To improve T8 store stream equipment issue.
[04.70.06]
For 2017 OLED TVs (W7, G7, E7, C7, B7)
1. Support TrueHD audio format through HDMI
2. Technicolor Expert mode
For 2017 Super UHD 4K TVs (SJ)
1. Technicolor Expert mode
For 2017 Ultra HD 4K TVs (UJ)
1. Add an Apply to all input feature in Color Management Setting
2. Improving HDD detection speed
3. Add function for maintaining compatibility of remote controller
[04.70.10]
1. To improve Store mode OLED afterimage issue in Europe
[04.70.30]
1. To improve Youtube VP9 HDR Contents SDR processing issue
2. To improve Smart Retune Deleted Reservations issue
3. To improve OLED Model Screen Saver occurrence issue
4. To improve issue of canceling favorite setting channel in European Standby Channel Update
[04.70.65]
1. Bug Fixes – Playing Dolby Vision contents over HDMI
[04.70.85]
1. Apply the GDPR terms.
[04.70.95]
1. Support BBC iPlayer 4K DASH Live
2. Italy TivuSat Wrong channels positioning
[05.80.04]
1. Improvement regarding Netflix usability have been applied.
2. Addition of satellite channels and feature updates in certain countries. (Russia/CIS country)
3. IPv6 connection feature on/off can be selected from Network/Wired Connection settings.
4. also, minor bugs are fixed.
[05.80.10]
1. To improve that the subtitle is not displayed when HbbTV app in on.
[05.80.15]
1. To improve Intermittent no audio issue during watching LiveTV.
[05.80.25]
1. To Improve color issues at HDMI 2160p 50Hz input
[05.80.35]
1. Security Update.
[05.80.55]
1. Add HEVC logo to user guide
2. fix unknown device toast pop-up issue by Galvanic Corrosion
[05.80.60]
1. Fix the failure of access to certain website in the browser
[06.00.05]
1. LG Channel has been upgraded and service territory expansion. (Selected Countries Only)
2. Software update contains minor bug fix
SW File (Version 06.00.05) Detailed applicable model list : Please check with reference Tab exactly
Software_File(Version_06.00.05).zip
24/02/2021844424K
Riferimento
SW File (Version 05.80.35) Detailed applicable model list : Please check with reference Tab exactly
* SW information
1. Improvement
OLED65W7V-Z
OLED77W7V-Z
OLED65G7V-Z
OLED77G7V-Z
OLED55E7N-Z
OLED65E7V-Z
OLED55C7D-Z
OLED55C7V-Z
OLED65C7D-Z
OLED65C7V-Z
OLED55B7D-Z
OLED65B7D-Z
OLED55B7V-Z
OLED65B7V-Z
49SK7900PLA
55SK7900PLA
65SK7900PLA
86SJ957V-ZA
75SJ955V-ZA
55SJ950V-ZA
65SJ950V-ZA
65SJ9509-ZA
55SJ850V-ZA
60SJ850V-ZA
65SJ850V-ZA
55SJ930V-ZA
65SJ930V-ZA
55SJ8509-ZA
60SJ8509-ZA
65SJ8509-ZA
49SJ810V-ZA
55SJ810V-ZA
60SJ810V-ZA
65SJ810V-ZA
49SJ8109-ZA
55SJ8109-ZA
65SJ8109-ZA
49SJ800V-ZB
55SJ800V-ZB
65SJ800V-ZB
43UJ750V-ZB
49UJ750V-ZB
55UJ750V-ZB
60UJ750V-ZB
65UJ750V-ZB
49UJ7509-ZB
55UJ7509-ZB
65UJ7509-ZB
43UJ7507-ZB
49UJ7507-ZB
55UJ7507-ZB
60UJ7507-ZB
65UJ7507-ZB
43UJ740V-ZA
49UJ740V-ZA
55UJ740V-ZA
3. Release History
[03.51.20]
[03.60.09]
[03.60.15]
[04.70.06]
[04.70.10]
[04.70.30]
[04.70.65]
[04.70.85]
[04.70.95]
[05.80.04]
[05.80.10]
[05.80.15]
[05.80.25]
[05.80.35]
1. Security Update.
[05.80.55]
[05.80.60]
[06.00.05]
24/02/2021844424K
Riferimento
Io ho aggiornato la mia tv lg 32lj610v https://www.lg.com/it/supporto/prodotto/lg-32LJ610V alla nuova versione del software 06.00.04, ma non vedo niente di nuovo.
Cosa contiene questo nuovo aggiornamento?
Con questo aggiornamento hanno disttivato il riquadro in alto a sinistra (dove pubblicizzavano le app) nella home. Ora appare la pubblicita di LG Channels ma se si clicca sopra dice che l'app non è più supportata.
Anche a voi ?
Anche a voi ?
Si, identica cosa anche sul mio (49UJ634V).
Magari già lo avete scoperto, andando su LIST e selezionando CAVO compare la lista dei canali internet.
Invece facendo la ricerca canali CAVO da zero canali trovati, suppongo si aggiornino da soli quindi?:eusa_think:
Qualcuno di voi ha ricevuto l'aggiornamento 06.00.15 ? e su quale modello.
OT: LG Channels c'è qualche canale in italiano diciamo noto o interessante?
Dovrebbero usare questa modalità di trasmissione magari per quei canali italiani che non sono sul satellite (Supertennis, Sportitalia...).
No, solo canali stranieri.... dovrebbero fare un lista come Samsung
Anche le app non hanno un indice per lingua (o nazione) e lo trovo ridicolo: ogni tanto scorro l'elenco per vedere se c'e' qualcosa di nuovo e ci sono 1000 app di canali dell'est europa di cui non me ne frega niente ed a volte i nomi "internazionali" non fanno capire di che lingua si tratta (spesso lo si capisce da sceenshot).
Comunque, mi sembra che nell'ultimo mese ci sono state parecchie modifiche un po' dappertutto, non so quanto dovuto a LG e quanto ai vari gestori:
- HBBTV di DISCOVERY (nove, k2, dmax, ecc): prima mi andava solo su alcuni canali (ad esempio dmax o motortrend) ora mi va dappertutto. Cioè appare il banner. Insisto col dire che LG però dovrebbe inserire una opzione per lanciare quando si vuole il servizio, invece di dover aspettare il banner che a volte arriva dopo una vita.
Aggiungo anche una richiesta per i programmatori dell'HBBTV: dovrebbero mettere in HOME il link diretto ai canali HD in diretta. Infatti io sia i canali DISCOVERY che i canali RAI che MEDIASET li vedo sempre via HBBTV per avere l'HD che sui mux normali non è disponibile ed ogni volta è una palla andare nei vari sottomenù... (ovviamente non fa altro che avviare la sessione di IPTV; quindi ovvio ci vuole anche una buona connettività di rete).
- l'app INFINITY di mediaset ora ha anche i canali free, ovvero MEDIASETPLAY. Prima era solo i servizi di INFINITY a pagamento, dunque finalmente anche mediaset ha la sua app per i canali free.
Comunque prima andava benissimo l'HBBTV e quindi era comunque tutto facile, ma.... ora sull'HBBTV di mediaset hanno tolto il link ai servizi interattivi di LATIVU che quindi almeno io non so più come lanciare.
Lì era l'unico posto dove ad esempio si accedeva a ARTE TV che aveva ottimi documentari sempre sottotitolati in italiano.
accidenti.
Qualcuno sa come lanciare il servizio IPTV di LATIVU?
- anche l'app RAI ha ora 3 canali in più: in coda ai canali in diretta appaiono 3 misteriosi RAIPLAY1, RAIPLAY2, RAIPLAY3. I primi 2 sono sempre eventi sportivi, il terzo l'ho sempre beccato nero
- cavolo, ora c'e' sempre qualcosa in onda su RAI4K, accessibile da interattivo rai. Quindi andare su un canale rai, premete il tasto rosso e poi scorrete con le frecce su/giu i canali fino ad arrivare a RAI4K e OK.
Qualità eccezionale, 4K reali con HDR.
Purtroppo manca qualsiasi guida tv.
Noto però che la RAI sviluppa dunque parallelamente vari applicativi: l'HBBTV, l'app MHP, e l'app per LG, l'app per Amazon Firestick (oltre ovviamente alla versione web, android ed apple). Poverini.... capisco che deve essere un bel costo... E' l'unica che mi pare faccia tutto e decisamente bene, fra l'altro.
accidenti.
Salve, sul mio LG 50UK6950PLB non funziona più l'HBBTV per Discovery Plus (in nessun canale), mentre funziona regolarmente su Rai, Mediaset, ecc...
Qualcuno sa dirmi perchè o a chi chiedere lumi?
Salve, posseggo questo TV:
TV: LG 32 LK 6200 PLA
SW: WebOS 4.0
FW: 05.30.11
L'HBBTV funziona sui principali canali Rai, Mediaset, Discovery, La7 ma non su TV8 e Cielo.
Problema del mio televisore o altri hanno lo stesso problrma?
trovato nuovo aggiornamento 05.10.05 mod.43UM7600PLB
