Notepad++ 8.6.4 (20/02/24)
Notepad++ 7.7.1 (20/06/19)
Disponibile Notepad++ 7.7.1
https://notepad-plus-plus.org/news
Change log:
1. Fix drag and drop tab regression: dragging tab is switched to another tab issue.
2. Fix an input regression: Cyrillic, Turkish and other languages input issue in ANSI mode.
3. Fix an ASP regression: VB looses syntax highlighting in ASP document.
4. Fix Reload dialog displaying issue during File Monitoring.
5. Fix “unhide lines” markers disappears issue.
6. Fix Plugin menu is not localized issue if no plugin installed.
7. Add “Copy File Name” command in context menu of “Folder as Workspace”.
8. Fix crash while sorting lines with numbers longer than 20 digits.
9. Enable Scintilla Virtual Space Option change from macro.
10. Add Tcl, CMake and AutoIt keywords; add Python and SQL new syntax highlighting cathegories.
Notepad++ 7.8 (11/10/19)
Disponibile Notepad++ 7.8
https://notepad-plus-plus.org/news/v78-released/
Downloads
Change log:
Codice:
1. Upgrade Scintilla from 4.1.4 to 4.2.0
2. Fix non Unicode encoding problem in non-Western language(Chinese or Turkish).
3. Add “No to All” and “Yes to All” options in Save dialog.
4. Add the command line argument “-openFoldersAsWorkspace” to open folders in “folder as workspace” panel. Example: notepad++ -openFoldersAsWorkspace c:\src\myProj01 c:\src\myProj02
5. Enhance plugin system: allow any plugin to load private DLL files from the plugin folder.
6. Fix File-Rename failing when new name is on a different drive.
7. Make “Clear all marks”, “Inverse Bookmark”, “Remove Consecutive Duplicate Lines” & “Find All Current Document” to be macro recordable.
8. Make “Command Argument Help” MessageBox modal.
9. Fix Folder as Workspace crash and “queue overflow” issues.
10. Make Combobox font monospace in Find dialog.
11. Fix folding in user-defined languages for non-windows line endings.
12. Fix crash of Folder as Workspace when too many directory changes happen.
13. Fix ‘-nosession’ overwrites config.xml issue.
14. Fix the crash due to NPPM_DESTROYSCINTILLAHANDLE message.
15. Improve GUI in Find dialog for Find Previous & Find Next buttons.
16. Fix Sort Line as Integer regression.
17. Add more OS information to debug info.
18. Fix tab dragging issues under WINE and ReactOS.
19. Fix indent indicators continue to following code blocks for Python.
20. Fix Python folding collapse issue.
21. Fix crash when sorting “out of range” columns.
22. Fix find 2 times for the same occurrence in both original and cloned documents issue.
23. Fix command line issues where filenames have multiple white spaces in them.
24. Fix Document Peeker constantly changing focus problem.
25. Make backward direction checkbox be also on Find dialog’s Mark tab.
26. Add 2 new columns for HTML Code in the Character Panel.
27. Fix “clear all marks in find dialog also removes bookmarks” issue.
28. Enhance supported language (on function list or auto-completion): LISP, BaanC,(PL/)SQL & COBOL.
Notepad++ 7.8.1 (29/10/19)
Disponibile Notepad++ 7.8.1
Non conosco questo programma, a cosa serve?
è un editor di testo https://www.youtube.com/watch?v=T9oPzQQogbw
su un altro notebook lo avevo già installato di default, ricordo che mi veniva in aiuto quando dovevo passare dati da excel (per esempio) a un file di testo...il blocco note mi tradiva, invece notepad mi manteneva alla grande le colonne senza scombinarle ;)
uno dei tanti utilizzi, per dire...
Notepad++ 7.8.3 (16/01/20)
Disponibile Notepad++ 7.8.3
Notepad++ 7.8.4 (30/01/20)
Disponibile Notepad++ 7.8.4
Salve, con notepad++ è possibile avere alla creazione di un nuovo file html, i tag principali html, head e body già pronti?
Sì, esistono diversi plugin per fare cose del genere e molto di più.
Il più famoso è emmet, che è disponibile per la maggior parte degli editor ma che su notepad++ va installato a mano (solo nella versione a 32 bit).
Io ho la versione a 64 bit, questo significa che posso installarlo automaticamente, oppure che non posso proprio installarlo? Altrimenti qualche alternativa?
Ho fatto tutto passo passo: ho disinstallato notepad++ 64 bit, e messo quello a 32 bit, ho scaricato emmet-npp.zip e python script 1.0.8.0, ho decompresso il file emmet, ho copiato il contenuto nella cartella plugins di notepad++, e ho installato python scripts. Ma non è accaduto nulla, quando apro notepad++ e vado in plugin non compare emmet. Non so dove sbaglio. :doubt:
Va installato con privilegi di amministratore.
Nella cartella pugni config ci deve essere nppPluginList.dll
plugins admin deve essere abilitato.
Allora, per quanto riguarda nppPluginList.dll è regolarmente presente nella cartella config. Invece come faccio a vedere se plugins admin è abilitato?
Finalmente ce l'ho fatta!! ho seguito un ulteriore video su youtube, e semplicemente il problema era che dovevo copiare il file EmmetNPP.dll anche nella cartella EmmetNPP. Grazie per l'aiuto :D.
Ma quindi questo plugin è disponibile anche per la versione a 64 bit?
