- 2 Tuners PVR
- Compliant MPEG-4/H.264 & Fully DVB-S2 (High Definition)
- Simultaneous 6 Record and 1 playback
- Simultaneous Time-shifting & Dual Recording
- Dual Decoding from Live stream or Recorded stream (PIP: Picture-in-Picture)
- MP3(MPEG-1 Layer-3) Transfer & Play from Internet via USB 2.0
- RGB and YPbPr and S-Video and CVBS and HDMI video Outputs
- Powerful & Stable Trick mode
- USB 2.0 support for Fast transfer via PC
Main Processor 32-bit superscalar RISC CPU
Modulation QPSK, 8PSK
HDD Size 5.25 Inch of 80GB and more
Multistandard Demodulation DVB-S2 = QPSK,8PSK
Serial IF USB 2.0, RS232C of D-SUB 9
TUNNER & CHANNEL
2 Tuner Decoding & Recording [or Decoding]
RF INPUT RANGE 950MHz ~ 2150MHz
DYNAMMIC RANGE -65dBm ~ -25dBm
INPUT CONNECTOR F-type, Female
INPUT IMPEDANCE 75ohm
Symbol rate DVB-S2=Maximum QPSK 36 MSPS @ 108MHz fsamp
Maximum 8PSK 30 MSPS @ 108MHz fsamp
Multistandard decoding LDPC and BCH (1/4,1/3,3/4,5/6,6/7,7/8)
MPEG TS A/V DECODING
Transport Stream MPEG-4/H.264 HP@L4.0 1920x1080 interface@50Hz
Profile Level MPEG-2 MP@HL, MPEG-4/AVC MP@L4
Input Rate Max. 81Mbit/s
Aspect Ratio 4:3, 16:9, Letter Box
Video Resolution 1920*1080i, 1280*720p, 720*576i
Audio Decoding Dolby AAC, AC-3, MPEG-1 layers 1,2 and 3(MP3)
Audio Mode Mono / Left / Right / Stereo
A/V & DATA OUTPUT
Component Y/Pb/Pr 1 set (RCA Type)
RGB D-Sub 15 pin 1 Connector
CVBS 1 Connector (RCA Type)
S-Video 1 Connector
Dolby Digital 5.1 CH 1 Optical
Stereo L/R 1/1 Connector (RCA Type)
HDMI 1 Connector
DATA Port RS 232C Transfer rate 115Kbps, 9 pin D-Sub Type
SYSTEM RESOURCES
Flash Memory Max. 8MByte (Optional)
Program DRAM Max. 128MByte (Optional)
EEPROM Max. 32KByte (Optional)
POWER SUPPLY
Input Voltage AC 90 to 250V, 50/60Hz
Power Consumption MAX. 30W
Protection Separate Internal Fuse
Type SMPS
Safety & EMI For Australian Regulation
TUNNER & CHANNEL
A/V & DATA OUTPUT
S-Video 1 Connector
HDMI 1 Connector
SYSTEM RESOURCES
POWER SUPPLY
Type SMPS
