In Rilievo satellites.xml per Enigma2
Aggiornamenti Eutelsat 5West/B
Update al primo post:
+ tp 11013 V 35300 2/3 Root 16416 Gold 131070 stream 5
+ tp 11675 V 35300 2/3 Root 16416 Gold 131070 stream 1 e nuovo S/R
- tp 11013 V 35300 2/3 Root 16416 Gold 131070 stream 4
- tp 11675 V 35300 2/3 Root 16416 Gold 131070 stream 14
- tp 11675 V 35300 2/3 Root 16416 Gold 131070 stream 16
Se ritieni ... e vuoi aggiungere 46E, 50E, 51.5E e 52E...
ciao
Codice:
	<sat name="Turkmenalem/Monacosat (52E) Ku" flags="1" position="520">
		<transponder frequency="10752000" symbol_rate="2500000" polarization="0" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="10804000" symbol_rate="27500000" polarization="0" fec_inner="2" system="0" modulation="1"/>
		<transponder frequency="10845000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="10845000" symbol_rate="27500000" polarization="1" fec_inner="2" system="0" modulation="1"/>
		<transponder frequency="10887000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="10887000" symbol_rate="27500000" polarization="1" fec_inner="2" system="0" modulation="1"/>
		<transponder frequency="11221000" symbol_rate="27500000" polarization="1" fec_inner="2" system="0" modulation="1"/>
		<transponder frequency="11381000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
		<transponder frequency="12226000" symbol_rate="28000000" polarization="1" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="12264000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="1"/>
		<transponder frequency="12303000" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="1"/>
		<transponder frequency="12341000" symbol_rate="28000000" polarization="1" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="12380000" symbol_rate="28000000" polarization="1" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="12418000" symbol_rate="27500000" polarization="1" fec_inner="1" system="0" modulation="1"/>
		<transponder frequency="12437000" symbol_rate="27500000" polarization="0" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="12476000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
	</sat>
	<sat name="Belintersat (51.5E) Ku" flags="1" position="515">
		<transponder frequency="11230000" symbol_rate="45000000" polarization="0" fec_inner="6" system="1" modulation="2"/>
		<transponder frequency="11290000" symbol_rate="45000000" polarization="0" fec_inner="6" system="1" modulation="2"/>
		<transponder frequency="11350000" symbol_rate="45000000" polarization="0" fec_inner="3" system="1" modulation="2"/>
	</sat>
	<sat name="Turksat (50E) Ku" flags="1" position="500">
		<transponder frequency="10959000" symbol_rate="2222000" polarization="0" fec_inner="4" system="0" modulation="1"/>
		<transponder frequency="11196000" symbol_rate="2222000" polarization="1" fec_inner="4" system="0" modulation="1"/>
		<transponder frequency="11688000" symbol_rate="2222000" polarization="0" fec_inner="4" system="0" modulation="1"/>
	</sat>
	<sat name="AzerSpace 1/Africasat-1A (46E) C" flags="1" position="461">
		<transponder frequency="3741000" symbol_rate="2500000" polarization="0" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="3817000" symbol_rate="1666000" polarization="1" fec_inner="3" system="1" modulation="1"/>
		<transponder frequency="3823000" symbol_rate="3333000" polarization="1" fec_inner="7" system="1" modulation="1"/>
		<transponder frequency="3827000" symbol_rate="1405000" polarization="1" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="3840000" symbol_rate="1666000" polarization="0" fec_inner="2" system="1" modulation="2"/>
		<transponder frequency="3874000" symbol_rate="1250000" polarization="0" fec_inner="2" system="1" modulation="2"/>
	 	<transponder frequency="3902000" symbol_rate="1582000" polarization="0" fec_inner="2" system="1" modulation="2"/>
		<transponder frequency="3946000" symbol_rate="1190000" polarization="1" fec_inner="3" system="1" modulation="1"/>
		<transponder frequency="3961000" symbol_rate="2330000" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="3978000" symbol_rate="2111000" polarization="1" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="3993000" symbol_rate="1666000" polarization="1" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="4112000" symbol_rate="2432000" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="4115000" symbol_rate="1010000" polarization="1" fec_inner="7" system="1" modulation="2"/>
		<transponder frequency="4117000" symbol_rate="1390000" polarization="1" fec_inner="8" system="1" modulation="1"/>
		<transponder frequency="4119000" symbol_rate="1180000" polarization="1" fec_inner="7" system="1" modulation="2"/>
		<transponder frequency="4120000" symbol_rate="1200000" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="4123000" symbol_rate="2380000" polarization="1" fec_inner="3" system="1" modulation="1"/>
		<transponder frequency="4127000" symbol_rate="2378000" polarization="1" fec_inner="3" system="1" modulation="1"/>
		<transponder frequency="4130000" symbol_rate="2000000" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="4132000" symbol_rate="1843000" polarization="1" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="4135000" symbol_rate="1282000" polarization="1" fec_inner="4" system="1" modulation="1"/>
		<transponder frequency="4137000" symbol_rate="1603000" polarization="1" fec_inner="6" system="1" modulation="1"/>
		<transponder frequency="4160000" symbol_rate="1632500" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="4180000" symbol_rate="1632500" polarization="1" fec_inner="3" system="1" modulation="2"/>
	</sat>
	<sat name="Azerspace 1 (46E) Ku" flags="1" position="460">
		<transponder frequency="11000000" symbol_rate="1054000" polarization="0" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="11024000" symbol_rate="16500000" polarization="0" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="11025000" symbol_rate="12700000" polarization="1" fec_inner="4" system="0" modulation="1"/>
		<transponder frequency="11095000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2"/>
		<transponder frequency="11104000" symbol_rate="13000000" polarization="1" fec_inner="3" system="1" modulation="2"/>
		<transponder frequency="11135000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1"/>
		<transponder frequency="11175000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1"/>
	</sat>
Buongiorno a tutti, ho un problema con il salvataggio delle impostazioni del tuner del mio vu+duo 4k se, in pratica, ogni volta che salvo le impostazioni tuner, mi va in crash il decoder, secondo me perche il file satellite e troppo grande e non riesce a gestirlo, c'e un anima buona che mi fa un file satellites.xml per i soli satelliti: 13 est, 9 est, inclusi multistream, 8w, 5 w, 16 est,19 est, 28,2 est31,5 est 39 est, dove ci sono anche i multistream, ho provato ad "alleggerire" il file da voi postato ma mi e andato in crash il decoder, ho dovuto reinstallare tutto e preferisco se me lo fa uno di voi, grazie
Non credo dipenda dal file.
Prova ad installare i setting Motor di Vhannibal.
@ Number10
non è assolutamente il mio file di 340Kb
I decoder vanno prima a leggere in /etc/engima2 se trova il file (che viene generalmente scritto se caricate un setting già pronto di vari setting-men) e quindi carica le informazioni in esso contenute; io non ne faccio uso e trasferisco ed uso il mio satellites.xml via FTP in etc/tuxbox e riavvio il decoder mai avuto un problema in diversi decoder ed immagini. Per sicurezza sovrascrivilo a quello in etc/enigma2 e cancellalo da var/etc/tuxbox se ritieni.
Per quanto riguarda il range credo che sia il massimo visibile qui da noi e se c'è qualche satellite in più non inficia sulla qualità e risposta dei satelliti che si vuole sintonizzare non hai bisogno di nessun specifico file questo fa già al caso tuo.
Poi ripeto il preambolo di inizio thread non c'è molto di aggiornato online ed in rete soprattutto per i multistream che interessano a noi quindi ho reputato di comune aiuto condividere la mia esperienza e pubblicarla, poi ognuno ritiene quelle che è utile e cosa no.
Update odierni al primo post
  • Eutelsat 12380 V 31400 3/4 PLS Gold 262140 str 23 Mediaset5 (test)
  • Eutelsat 12380 V 31400 3/4 PLS Gold 262140 str 111 Mediaset5 (test)
  • Eutelsat 12380 V 31400 3/4 T2-MI PLP0 str 125
Update odierno al primo post
  • Eutelsat 5West A tp 12585 H 35500 2/3 PLS Gold 262140 str.11 RL Sardegna1
Update 09/03 al primo post
  • Eutelsat 12380 V 31400 3/4 PLS Gold 262140 str 25 RL Calabria 1
  • Eutelsat 12417 V 31400 3/4 PLS Gold 262140 str 20 RL Toscana 1
Update 15/03 al primo post
  • Eutelsat 12225 V 31400 3/4 PLS Gold 262140 str 16 RL Valle d'Aosta 2
  • Eutelsat 12225 V 31400 3/4 PLS Gold 262140 str 20 RL Toscana 1
  • Eutelsat 12303 V 31400 3/4 PLS Gold 262140 str 18 RL Liguria 1
Mi scuso se la domanda è stata fatta più volte. Malgrado ho scaricato i setting dal noto sito ed aggiornato il file satellite.xml dalla prima pagina di questa discussione, non riesco a vedere alcuni canali del 9 est in paricolare quelli di Persidera (12466 V). Anche selezionando il trasponder e facendo la ricerca manuale non si ha visione su nessuno. Potrebbe essere il puntamento, dice qualcuno, Ma allora perchè i canali Mediaset si vedono bene? Grazie a chi mi fornirà una risposta
non dipende dal file ma come ti hanno detto dal puntamento la frequenza è quasi al limite
Io avevo lo stesso problema. Ma, nel mio caso, il problema è del file satellites.xml di lyngsat. Ho fatto il blind scan con il ricevitore e i 4 stream della frequenza 12466V sono comparsi con relativa sintonizzazione dei canali.
bisognerebbe capire quale è il noto sito, premesso che quello messo in questo thread è perfettamente funzionante
Il problema del file di lyngsat, almeno per la frequenza citata, è l'id che non è corretto. Su tutti i 4 stream riporta "1" mentre è corretto quello del tuo file (da 33 a 36)
