Discussioni su ZONA DAZN (LCN 414 DTT) e ZONA DAZN 2 (LCN 415 DTT)
ALE89
Membro dello Staff
Moderatore
1 Febbraio 2008
Valmadonna (Alessandria)
Come da titolo, sembrerebbe arrivato nel Mux Cairo Due il canale di backup di DAZN per il DTT. Codificato in Nagra.
Bitrate video di 6 Mbps e audio a 192 kbps. Ovviamente in H264 e HD.
Network Name: CAIRO DUE
Network ID: 12295 (0x3007)
Transport Stream ID: 263 (0x0107)
Original Network ID: 8572 (0x217c) Version: 2
Descriptor: Network Name Descriptor
DVB-T Frequency 506.000 MHz
Bandwidth: 8 MHz Constellation: 64-QAM
Hierarchy: non-hierarchical, native interleaver Guard Interval 1/4
Code Rate: 3/4
Current Network: True
Descriptor: User Private Descriptor: 0x83
Logical channel 7 = MPEG service 711 (LA7)
Logical channel 29 = MPEG service 712 (LA7d)
Logical channel 507 = MPEG service 751 (LA7 HD)
Logical channel 529 = MPEG service 752 (LA7d HD)
Logical channel 907 = MPEG service 761 (LA7 TEST)
Logical channel 929 = MPEG service 762 (LA7 Servizi on demand)
Logical channel 888 = MPEG service 763 (LA7 TEST)
Logical channel 998 = MPEG service 764 (LA7 TEST)
Logical channel 999 = MPEG service 765 (LA7 TEST)
Logical channel 807 = MPEG service 790 (LA7 on demand)
Logical channel 829 = MPEG service 791 (LA7 Test)
Logical channel 107 = MPEG service 721 (LA7)
Logical channel 229 = MPEG service 722 (LA7d)
PAT Version Number: 2
NIT: 506.0 MHz
PMT PID 70 (0x0046) - Program 70 Servizio 70
PMT PID 71 (0x0047) - Program 71 Servizio 71
PMT PID 72 (0x0048) - Program 72 Servizio 72
PMT PID 73 (0x0049) - Program 73 Servizio 73
PMT PID 74 (0x004a) - Program 74 Servizio 74
PMT PID 75 (0x004b) - Program 75 Servizio 75
PMT PID 76 (0x004c) - Program 76 Servizio 76
PMT PID 77 (0x004d) - Program 77 Servizio 77
PMT PID 78 (0x004e) - Program 78 Servizio 78
PMT PID 79 (0x004f) - Program 79 Servizio 79
PMT PID 99 (0x0063) - Program 99 Ghost
PMT PID 111 (0x006f) - Program 7/711 LA7
PMT PID 112 (0x0070) - Program 29/712 LA7d
PMT PID 121 (0x0079) - Program 107/721 LA7
PMT PID 122 (0x007a) - Program 229/722 LA7d
PMT PID 151 (0x0097) - Program 507/751 LA7 HD
PMT PID 152 (0x0098) - Program 529/752 LA7d HD
PMT PID 161 (0x00a1) - Program 907/761 LA7 TEST
PMT PID 162 (0x00a2) - Program 929/762 LA7 Servizi on demand
PMT PID 163 (0x00a3) - Program 888/763 LA7 TEST
PMT PID 164 (0x00a4) - Program 998/764 LA7 TEST
PMT PID 165 (0x00a5) - Program 999/765 LA7 TEST
PMT PID 190 (0x00be) - Program 807/790 LA7 on demand
PMT PID 191 (0x00bf) - Program 829/791 LA7 Test
Program Number: 829/791
PCR on PID 1470 (0x05be)
PMT Version: 1
Service name: LA7 Test
Logical channel number: 829
Stream Type: 0x1b H.264 Video
Elementary Stream PID 1470 (0x05be)
Stream Type: 0x04 MPEG-2 Audio
Elementary Stream PID 1471 (0x05bf)
Elementary Stream PID 1470 (0x05be) H.264 Video
Descriptor: CA Descriptor
CA System ID: 6229 (0x1855) Nagravision
CA PID 2933 (0x0b75)
CA System ID: 6212 (0x1844) Nagravision
CA PID 2833 (0x0b11)
Hanno spento La7d HD per mettere il canale di Backup
Il canale di Backup si attiva in automatico, se ci sono problemi sullo streaming e solo se si usa il Tim Box (Tim Vision)
Per i pochi eletti che riusciranno a vederla su questo canale, spero vivamente che durante le partite non rimanga questo bitrate audio/video
Il canale dovrebbe attivarsi solo se ci sono problemi sullo streaming, altrimenti la si vede tutta in streaming la partita.
Non è un normale canale come gli altri
Cosi a naso direi un 720p@50, in linea con lo streaming di dazn
@Ercolino il canale è un normale canale come tutti gli altri è il decoder che switcha in locale sul digitale in caso di problemi.
Certo, però immagino trasmetta sempre (durante le partite). E onestamente io preferirei ricevere liberamente questo canale piuttosto che lo streaming. Per questo ho detto pochi eletti, perché è sicuramente preferibile allo streaming :laughing7:
Forse siamo super OT, ma in caso di partite in contemporanea ci saranno due backup?
Si avviene tutto in automatico, poi bisognerà vedere come effettivamente funzionerà il sistema.....
Solo con il Tim Box, in quanto è il sw del box che gestisce l'automatismo.
Quindi è confermato che in ogni caso serve per forza un collegamento internet funzionante, affinchè si attivi il backup in caso di problemi velocità internet e di streaming?
Si ma il TIMBOX deve avere anche nel suo fw le chiavi Nagra ... su un box android la vedo rischiosa la cosa ...
Ripeto la domanda fatta di la:
Se per assurdo la rete NON va come fa il TIMBOX a mettere in chiaro il canale?
Non penso al suo interno abbia la codifica Nagra nascosta da qualche parte ...
E se il principio di funzionamento è un CS legale senza rete non funziona
Secondo me Il sw del box non può mettere mani Nell'app di dazn, è l'app di dazn che gestirà il tutto e non sarà esclusiva del timbox.
Se così non fosse Dazn ha compraro le frequenze per regalarle a tim?
Ma infatti non sono tanto convinto che passerà dall'app Dazn. Siamo sicuri che i contenuti Dazn non saranno integrati del tutto in TimVision?
Grandissimi: hanno attivato un canale che non può vedere quasi nessuno e solo a discrezione di TIM :badgrin:
Fondamentale
Ma la Quaranta oggi non ha detto che il canale è usufruibile da tutti quei clienti che non posso accedere ad internet? Non centra nulla il Tim box. Magari forniranno una carta DAZN proprio ai residenti in quelle zone remote, certificando in qualche modo appunto l'assenza della rete
