Fidati che lo Zgemma H9.2H SE, Non ha lo slot per la Cam!
Specifiche prese dal sito del produttore!
Linux + Android Dual System
ARM processor with 1500MHz Quad-core CPU
Hi3798MV200 Main chipset
More than 4.10x linux kernel
DVB-S2X+DVB-T2/C combo tuner built-in
Support 4K- 2160p
16GB EMMC FLASH / 1GB DDR3 Memory
1x Smart Card
WIFI 300MHZ Built-in
SD card (TF card) for recording, 8GB, 64GB, 128GB (optional)
1 x USB2.0
1x HDMI 2.0
MPEG-2 / H.264 and H.265 Hardware Decoding
HEVC / H.265 2160p60 Main-10 multi-format decoder
10/100 Mbit Ethernet Interface
Multimedia plug-in supported
Advanced EPG (Electronic Program Guide)
User-friendly linux Menu system
Full automatic service scan
Various OSD skins supported
Various Channel Editing Programs
Easy and fast software-upgrade via USB
Low deep-standby power consumption under 1 W
Parental Control
Plugin Service
Excellent sound quality in Dolby Digital
OSD into many languages and graphics (Skins)
Web interface, WEB Remote control
DiSEqC 1.0 / 1.1 / 1.2 and USALS
Tu ti confondi con lo slot per la card! Che su quel modello è dietro.
Foto presa da amazon
