Nighteagle
Digital-Forum Gold Master
>>>>>> AltDVB 2.2 <<<<< 2006-10-22
Warnings:
- Premium cards (SkyStar1) not supported anymore.
- Old interfaces (Dev_???.int) are not compatible with new app.
Application:
* MPEG4/AVC Stream parser & demultiplexer
* Multi-monitor support
* Support for DVB-C/DVB-T/ATSC
* Multiple cards selector
* EPG/Channel (in main window)
* Mouse wheel actions
* New configuration window
* Process priority option
* Improved channel scanner
* Popup menu from tray icon
* Channels list can be filtered by satellite
* PIP1-3 selection buttons
Interfaces:
* New: BDA Driver
- DiseqC: Raw diseqc support for Twinhan BDA drivers
- DiseqC: LNB1-4 select for DvbWorld
- DiseqC: LNB1-4 select for Technotrend (via put_Range() )
* New: DVBWorld
- RawDiseqC not suported now. (see Dev_DvbWorld.cfg)
* SkyStar2 :
- RawDiseq for SS2 new driver (4.4.0)
- Many changes in "Internal" PID filter
Fixed:
* Signal indicator for SS2 & driver 4.4.0
* Popup menu exception on ES/CA window if no ch. selected
* Adjust GOTO with location NOT saved !
* Fixed CPU usage indicator for dualcore/HT processors
* Fixed PTS in DvbAvSrc.ax
* + many others
Proporrei di segnalare in questo thread l'esito dei vari test
Warnings:
Application:
Interfaces:
* New: BDA Driver
* New: DVBWorld
* SkyStar2 :
Fixed:
* + many others
