Decoder enigma 2 problema modifica orbite satellitari
Cosa vuoi dire? Puoi anche modificare un satellite che non ricevi o non usi...
C´é la possibilitá di impostare anche altro numero di un satellite che non esiste nella lista ?
Cosa sono Bat e ONID (no ) ?
Devo aggiungere due satelliti in banda C
47,5 e 55,5 Ovest...
da aggiungere al satellites.xml ...
Codice:
<sat name="55.5W C-band Intelsat 34" flags="1" position="-556">
		<transponder frequency="3739000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3768000" symbol_rate="8330000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3774000" symbol_rate="10560000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3792000" symbol_rate="2500000" polarization="0" fec_inner="4" system="1" modulation="1" />
		<transponder frequency="3799000" symbol_rate="6670000" polarization="0" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3805000" symbol_rate="23330000" polarization="1" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3820000" symbol_rate="5000000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3845000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3885000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3885000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3910000" symbol_rate="4632000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3918000" symbol_rate="7915000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3924000" symbol_rate="2080000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3925000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3927000" symbol_rate="2000000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3930000" symbol_rate="4000000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3934000" symbol_rate="2067000" polarization="0" fec_inner="2" system="1" modulation="2" />
		<transponder frequency="3940000" symbol_rate="1300000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="3967000" symbol_rate="15000000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3969000" symbol_rate="7500000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3983000" symbol_rate="16415000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3985000" symbol_rate="15570000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4015000" symbol_rate="30000000" polarization="0" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="4016000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="4055000" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4055000" symbol_rate="32700000" polarization="0" fec_inner="3" system="1" modulation="1" />
		<transponder frequency="4086000" symbol_rate="15000000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4086000" symbol_rate="15000000" polarization="1" fec_inner="2" system="1" modulation="2" />
		<transponder frequency="4099000" symbol_rate="5000000" polarization="1" fec_inner="0" system="1" modulation="2" />
		<transponder frequency="4100000" symbol_rate="7500000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4105000" symbol_rate="4000000" polarization="1" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="4107000" symbol_rate="3333000" polarization="0" fec_inner="4" system="0" modulation="1" />
		<transponder frequency="4109000" symbol_rate="3333000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4111000" symbol_rate="3750000" polarization="0" fec_inner="4" system="1" modulation="1" />
		<transponder frequency="4112000" symbol_rate="2222000" polarization="1" fec_inner="6" system="1" modulation="1" />
		<transponder frequency="4120000" symbol_rate="4167000" polarization="0" fec_inner="7" system="1" modulation="2" />
		<transponder frequency="4126000" symbol_rate="3750000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4126000" symbol_rate="15237000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4131000" symbol_rate="5422000" polarization="0" fec_inner="2" system="1" modulation="1" />
		<transponder frequency="4135000" symbol_rate="1000000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4137000" symbol_rate="2000000" polarization="0" fec_inner="2" system="1" modulation="2" />
		<transponder frequency="4139000" symbol_rate="10000000" polarization="1" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4142000" symbol_rate="5000000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4175000" symbol_rate="30000000" polarization="0" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4180000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" />
	</sat>
	<sat name="47.5W C-band SES 14" flags="1" position="-476">
		<transponder frequency="3740000" symbol_rate="2343000" polarization="3" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="3834000" symbol_rate="15000000" polarization="3" fec_inner="2" system="1" modulation="2" />
		<transponder frequency="3898000" symbol_rate="5000000" polarization="2" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="3965000" symbol_rate="10416000" polarization="3" fec_inner="3" system="1" modulation="2" />
		<transponder frequency="4055000" symbol_rate="30000000" polarization="3" fec_inner="4" system="1" modulation="2" />
		<transponder frequency="4095000" symbol_rate="30000000" polarization="2" fec_inner="2" system="1" modulation="2" />
	</sat>
Codice:
	</sat>
	</sat>
Grazie ma non ho la minima idea come si fa , ca. un anno fa avevo tolto le vecchie e rimesse le nuove passatami dal mio amico ma non funzionava
Figuriamoci aggiungere nuove nelle lista gia fatta , non ci capisco un tubo , a meno che mi dai passo - passo come fare
Per entrare nel menu di questa foto cosa devo fare
Se dalla lista satelliti klicco su menú mi esce questo , cosa clicco dopo
No, quella schermata non va bene x modifiche ai satelliti.
Si arriva da: Menu/impostazioni/tuner e ricerca canali/xlm editor: Premi 1 x modificare, rimuovere o aggiungere un satellite.
Una volta fatte le modifiche e memorizzate, le nuove modifiche ti appaiono nella lista dei satelliti in uso: qui la modifica del satellite che avevo chiamato Hotbir rinominato Hotbird2 e dato il numero 54B
Come prevedevo non ho cavato un ragno dal buco , i miei due satelliti che mancano ad ovest si trovano gia nella lista in quel sotto menú , ho provato a modificare il 55,5 Gradi e scrive la nuova posizione sempre numero 121 ma non appare nella lista dei satelliti principale in modo da andare a prenderlo e caricare i canali :crybaby2:
Puoi fare questo tentativo se ti esce questa schermata in configurazione tuner: selezioni i satelliti con la spunta e memorizzi con tasto verde e vedere quando poi fai la scansione se i canali restano memorizzati
Non uso usals ma disecq 1.2
Come motore uso il Titanium ASC1 che commuta la funzione Disecq 1.2 , ha anche il polarizzatore meccanico
Oggi ho provato a clonare il satellite , Turksat 50 est, perché mi serve il Jamal 49 Est in banda C , ho dato 50.3 est
, ma quando esco per memorizzare mi dice che il numero é gia occupato, come faccio a cambiare numero ?
Salve e grazie a tutti per aver arricchito con tanti spunti questa mia discussione.
Il problema per cui avevo avviato la discussione è proprio questo, non riesco - per mia incapacità - a far dialogare il mio decoder Enigma2 (Hitube 4K combo) col mio pc che è collegato ad internet via wifi 4g.
Ho trovato il file satellites.xml e sono riuscito ad editarlo modificando le orbite secondo le mie necessità, ma, posto il problema di collegamento decoder/pc, ho messo il file su una chiavetta ma non so ora come caricarlo nel decoder.
Help.....
Help.....
Bisogna prima cancellare quelli vecchi che sono dentro in due posti differenti , poi si procede col caricamento sullo stesso posto trascinando il file dentro
Io avevo usato il programma DCC- E2 V.2.40 che é facile da fare
:evil5:
Le directory sono
etc/tuxbox
etc/enigma2
Grazie egis, ma mi spieghi (più chiaramente possibile, per i profani come me) come hai fatto a far dialogare il pc con il decoder? E' questo che non mi riesce fare...
:evil5:
Le directory sono
etc/tuxbox
etc/enigma2
Devi scaricarti il programma DCC-E2 v. 2.40 sul computer e configurarlo per E2 e inserire il tuo IP che hai messo nel decoder
Poi accendi il tuo decoder , dopo apri sul computer il DCC-E2 , se é tutto a posto vedi la barra verde che ti da OK della connessione con tutti i dati del tuo decoder
Poi vai su , clicci su FTP e ti escono al centro due frecce una a sinistra e una a destra
A sinistra ci sono i dati del decoder a destra i dati del computer , basta evidenziare sul computer il file e evidenziare la directory sul decoder
Dopo clicchi sulla freccia verso sinistra
( Decoder ) e il gioco é fatto
Importantissimo prima devi cliccare , andare sul File etc/tuxbox e trascinare il file sul Deskop del computer dovresti vedere e aprire i dati XML-satelliten
Poi IMPORTANTISSIMO cancelli i due file nella etc/tuxbox e etc/enigma2
Se clicchi su HTTP sopra a destra puoi vedere la lista dei tuoi canali , poi clicca sul televisorino e vedi la TV sul computer col programma VLC
mah scusami... sarà perchè ormai e2 lo mastico ogni giorno ma non trovo niente di più semplice.....da un lato hai il pc dall altro il decoder.... poi fai tu
Si lo so ma quel programma non mi ispira sicurezza al 100% e se sbagli a caricare sono guai seri ,piú´sicuro il DCC-E2 c´é la freccia e non puoi sbagliare da A a B
