Lanus
Digital-Forum Platinum Master
Che PID VIDEO e PMT utilizzano ?Sì hai ragione su alcuni apparati è ok su DM900 no
Info 2000
Info 2000
Quindi non è nemmeno questo il problema, anche sul MySkyHD non lo ricevono sul Terrestre.PMT : 408
VPID : 2570
APID : 2571
(Decimali)
todayaggiorna satellite.xml
<sat name="Eutelsat9A (9.0E)" flags="2" position="90">
<transponder frequency="11727480" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="11760000" symbol_rate="14325000" polarization="1" fec_inner="4" system="0" modulation="1"/>
<transponder frequency="11785000" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11804200" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11823380" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11843000" symbol_rate="27500000" polarization="1" fec_inner="7" system="1" modulation="2"/>
<transponder frequency="11861740" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11880920" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="11900100" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11919280" symbol_rate="30000000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="11938460" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11957640" symbol_rate="27500000" polarization="1" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11976820" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="11996000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12015180" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12034360" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="12053540" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12091900" symbol_rate="27500000" polarization="0" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="12111080" symbol_rate="27500000" polarization="1" fec_inner="0" system="1" modulation="0"/>
<transponder frequency="12111080" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="1"/>
<transponder frequency="12111080" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="3"/>
<transponder frequency="12111080" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="4"/>
<transponder frequency="12111080" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="5"/>
<transponder frequency="12130260" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12149440" symbol_rate="27500000" polarization="1" fec_inner="0" system="1" modulation="0"/>
<transponder frequency="12149440" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="1"/>
<transponder frequency="12149440" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="2"/>
<transponder frequency="12149440" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="3"/>
<transponder frequency="12168620" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12187800" symbol_rate="27500000" polarization="1" fec_inner="0" system="1" modulation="0"/>
<transponder frequency="12187800" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="1"/>
<transponder frequency="12187800" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="2" pls_mode="1" pls_code="262140" is_id="2"/>
<transponder frequency="12206980" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12226160" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="16"/>
<transponder frequency="12226160" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="20"/>
<transponder frequency="12245340" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12265000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="10" t2mi_plp_id="0"/>
<transponder frequency="12265000" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="20" t2mi_plp_id="0"/>
<transponder frequency="12265000" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="11"/>
<transponder frequency="12265000" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="12"/>
<transponder frequency="12265000" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="15"/>
<transponder frequency="12283700" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12302880" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="30" t2mi_plp_id="0"/>
<transponder frequency="12302880" symbol_rate="30000000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="40"/>
<transponder frequency="12302880" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="18"/>
<transponder frequency="12322060" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12341240" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="13"/>
<transponder frequency="12341240" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="14"/>
<transponder frequency="12341240" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="17"/>
<transponder frequency="12341240" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="111"/>
<transponder frequency="12360420" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12379600" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="23"/>
<transponder frequency="12379600" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="24"/>
<transponder frequency="12379600" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="25"/>
<transponder frequency="12398780" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12417960" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="16"/>
<transponder frequency="12417960" symbol_rate="31400000" polarization="1" fec_inner="2" system="1" modulation="0" pls_mode="1" pls_code="262140" is_id="20"/>
<transponder frequency="12437140" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
<transponder frequency="12465600" symbol_rate="41950000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="33"/>
<transponder frequency="12465600" symbol_rate="41950000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="34"/>
<transponder frequency="12465600" symbol_rate="41950000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="35"/>
<transponder frequency="12465600" symbol_rate="41950000" polarization="1" fec_inner="4" system="1" modulation="2" is_id="36"/>
<transponder frequency="12475500" symbol_rate="27500000" polarization="0" fec_inner="2" system="1" modulation="2"/>
</sat>
Receivers are required to support at least the following service types:
service_type = 0x01, digital television service
service_type = 0x02, digital radio sound service (MPEG-1 Layer 1 or 2 audio)
service_type = 0x0A, advanced codec digital radio sound service
service_type = 0x16, advanced codec SD digital television service
service_type = 0x19, advanced codec HD digital television service
Non saprei cosa dirti...
L'unica "stranezza" che vedo è il Service Type= 0x16 nella NIT e 22 nella SDT,
mentre tutti gli altri usalo l'accopiata 0x01 - 1 o al massimo 0x19 -25
EDIT2:
Invece ptrebbe essere quello perchè più avanti nel documento si legge che il service type 0x16 è riservato al dvb-t2!
Credo ci siamo riusciti anche con INFO 2000
non ancora
FEC , Modulation
Controlla se è stato modificato....Quindi era il service type??
Io ho inviato il problema service type.
Mux Piemonte ?mi rinfrescate la memoria su quale tipo di problema reindirizzandomi al post? non lo trovo...
mux piemonte ?
