Intelsat 11 @ 43.1°W
bisui
Digital-Forum Master
30 Settembre 2006
45.8Nord-12Est
Vi segnalo un considerevole aumento del segnale di questo sat, sicuramente non più fuori portata dall'Europa.
Feed Update
Ciao,
first time for me to get PAN AMERICAN beam on TP 13 at 4084 V 6600 3/4 with channel name ESPN PAS3 HIGHLIGHTS with SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / ONID 65535 / TID 1 in DVB-S MPEG-2 4:2:2 in clear.
Testcard active now. Signal very low with 1,5-2,3dB and 17-18% on Openbox X810 and 366cm mesh.
EDIT: Oops, maybe a moderatori could make my screenshots a little bit smaller. Grazie!
Edgar.
Europa beams on?
Ciao,
there must be some beam changes, because a lot of transponders now with strong signal yet!
Here with 366cm mesh and Openbox X-810:
3718 V 21260 3/4 6,0dB and 53%
3785 H 30800 7/8 7,4dB and 60%
3854 V 5945 3/4 3,1dB and 27%
3930 H 2812 7/8 6,1dB and 54%
3971 H 21090 3/4 6,0dB and 52%
3980 V 3300 3/4 8,5dB and 77%
3994 H 21091 3/4 7,4dB and 60%
4040 H 30800 7/8 10,3dB and 95%
4084 V 6600 3/4 ~2dB and ~18%
4106 V 26471 3/4 7,5dB and 71%
Edgar.
Ciao,
in DVB-S2 are active:
3865 V 10560 5/6 MPEG-4/H.264 8PSK with 58% on Clarke-Tech HD 5000 Combo Plus -> with Voom HD Latin America and Voom HD Brazil in High Definition
3966 V 7068 2/3 MPEG-4/H.264 8PSK with 60% on Clarke-Tech HD 5000 Combo Plus
Edgar.
Feed Update (at moment Testcards)
Ciao,
on 3836 H 20771 3/4 are two Intelsat Feeds with channel names AdHoc 2 (SID 2 / PMT 5002 / V 1270 / A 1230 / PCR 1270) and AdHoc 3 (SID 3 / PMT 5003 / V 1360 / A 1320 / PCR 1360) in MPEG-2 4:2:0 and clear.
Edgar
Feed Update
Ciao,
Feed (Telepuerto Monterrey) on 3935 H 6250 7/8 with channel name FUTBOL PROGRAM MTY (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / TID 1 / NID 65535) in DVB-S MPEG-2 4:2:2. Signal with 7,5dB and 75% on Openbox X-810 and 366cm.
Edgar.
Feeds update
Hello,
encrypted feed on 3957 V 5632 3/4 with channel name ATL ENC 05 SD (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / TID 1 / NID 1). Signal with 6,1dB and 55% on Openbox X-810 and 366cm.
Feed in clear DVB-S MPEG-2 4:2:0 on 3939 H 9375 7/8 Tandberg Service (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / ONID 65535 / TID 1). Signal with 7,5dB and 67%. World Football Challenge Inter Mailand vs AC Milan.
Edgar.
Update
Hello,
3827 V 6620 7/8 in DVB-S MPEG-2 with FPC (SID 2 / PMT 32 / V 308 / A 257 / PCR 8190 / TID 1 / NID 1) and Global Pro TV (SID 3 / PMT 327 / V 309 / A 258 / PCR 8190) both encrypted in Irdeto. Signal with 6dB and 49%.
Edgar.
Dx qwer ha scritto:
Hello,
Edgar.
Hello,
Car Racing: Nascar@3957v ;)
Feed Update
Hello,
3836 V 5631 3/4 ATL_ENC3 (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / TID 1 / NID 1). Signal in clear and DVB-S MPEG-2 4:2:0 with 7,5dB and 59%.
Indycar Series Edmonton Grand Prix.
Edgar.
Update
Hello,
changing frequency on Televisa Monterrey. Now on 3945 H 2812 7/8 in DVB-S MPEG-2 4:2:2. 3930 H is down.
PIDs: SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / NID 65535 / TID 1.
Signal with 7,5dB and 72% on Openbox X-810 and 366cm.
Edit: Btw. thanks @STANLEY_CASSIDY
Edgar.
Feed Update
Hello,
active feed for Televisa Deportes Monterrey on 3939 H 6250 7/8 with channel name ELLAS C/LAS STRELLAS (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190 / ONID 65535 / TID 1) in DVB-S MPEG-2 4:2:2. Signal with 7,5dB and 71%.
Edgar.
Americas & Europe beam
