£109 Technomate TM-9100 Linux PVR Ready
Pumahost
Digital-Forum Junior Plus
26 Dicembre 2006
Cerveteri RM
Brief Specification ;)
Linux Home Multimedia Center running on Enigma
PVR Ready
9in1 Memory Card Reader
Ethernet Communication Port
Unlimited Channel Memory
2x Smart Card Readers
1x Common Interface (CI)
The TM-9100 is a PVR ready Satellite Receiver that uses a Sharp tuner which is both sensitive and fast, having a low-threshold which enables it to find and capture weak signals.
The booting of the TM-9100 is very fast, taking less than 10 seconds from power OFF. In Standby Mode, when the TM-9100 is turned ON, the booting is instantaneous, taking less than 1 second.
The TM-9100 can be updated via memory card by the 9in1 card reader, being able to upload and download (backup) data, view photos, play music, etc. This can be used simultaneously with the Hard Drive. Multi Booting from the HDD, Memory Card and Flash is also available.
The TM-9100 has a built-in fan which is quiet and is only active when the hard drive overheats.
The TM-9100 is based on Enigma open source and is capable of: Tuxbox project, Telnet, etc.
Specification
· Fully DVB compliant
· Linux open source ; Standard Linux API
· Getting various Linux applications
· 252MHz IBM PowerPC Processor (350MIPS)
· Internal Hard Drive (HDD) support for PVR
· Multi-Slot Flash Memory Card: SD, Olympus, Memory Stick, MMC, Smart Media Card etc. supported
· 10/100M Ethernet interface
· 2x Smart card slots
· S/PDIF interface (Optical & Coaxial) for Dolby bit stream out
· Sharp Tuner (2~45 Msps, SCPC scan)
· 1x Common Interface (CI) slot
· Firmware/Software upgrade through: Serial (RS232C), Memory Card, Ethernet & Internet
· Unlimited TV/Radio channel storage
· Very quick channel change time ; < 1 second
· Support multiple LNB switching control (DiSEqC 1.0, 1.1 & 1.2)
· Full automatic satellite/service scan
· Smart Electronic Program Guide (EPG)
· OSD & VBI Teletext
· Variable aspect ratio (4:3, 16:9)
· 24 OSD Language menu
· Programmable event timer
· Subtitle
· Parental Control
· C & Ku band reception
· Video Out: RGB, CVBS, S-Video & YPbPr selectable
