Aggiornamento decoder
tdome
27 Agosto 2007
Ciao a tutti. Possiedo un Winstec RDS CI 2000 per il quale non ho trovato alcun Fw o patch per poterlo aggiornare. C'è qualcuno che mi può dare indicazioni in merito o almeno le istruzioni su come caricare il FW (che ho trovato su un sito Turco) e aggiornare le key?
Questi sono i dati del Winstec Rds 2000:
General FEATURES
1. 6000(5000TV, 1000Radio)Channels,
500Pre-programmable channels
2. 2slots common Interface with Viacess, Irdeto, Nagravision, Conax Crypto Works and etc
3. Picture in Graphic(PIG)
4. 1-45 Ms/s Symbol Rate
5. Multi-Lingual Function
(English, German, French, Spanish, Italian, Arabic, Turkish,Russian)
6. DISEqC1.2 LNB Control Technology
7. Bi-Lingual Selection
8. Display Electronic Program Guide (EPG)
9. General and Network Search Programming
10. Simple Operation Through On Screen Display
11. Teletext Function
12. Favorite Channel Folder Function
13. SCPC/MCPC Channel Receivable from C/Ku Band Satellites
14. Last Channel Recall Function
15. 2SCARTS for TV and VCR
16. Video Out RGB/CVBS Selectable
17. RS232 Serial Link for Interaction with Computer
18. 0/12V.
19. S-VHS Output
20. PLL Modulator
Technical SPECIFICATION
Tuner
Frequency 950-2150MH
Signal Lavel -65dBm - 25dBm
Impedance 75ohm
Band Switch Control 22KHz Mode ON/OFF
DiSEqC1.2
0/12Volt Control
Demodulator
Waveform
QPSK
Symbol Rate 1-45MSymbol/s
Code Rate Auto Selection
Video
Transport Stream
MPEG-2 ISO/IEC 13818
Decoder MPEG-2 MP@ML
Input Rate Max.60Mbit/s
Aspect Ratio 4:3, 16:9
Resolution 720x576(PAL)
1XRCA, 1XS-VHS
2XSCART
Audio
Decoder
MPEG Layer 1,2
Channel Stereo, Mono
Bi-Lingual
Sampling 32/44. 1/48KHz
Quality 18bit
Output 2 x RCA (Stereo)
2 x SCART
Frequency Response 20Hz to 20KHz
Data Interface
RS-232 192kbps(TXD, RXD)
Dimensions
Dimension 60x370x240
Weight 2.0Kg
Capacity
Transponders Up to 500TP
Channels Up to 3000Ch
Flash Memory 2M Bytes
DRAM 2M Bytes
SDRAM 8M Bytes
Power
Input
50/60Hz, 90/260
Power Consumption Max.30W, standby.abt5W
Back Panel Connectors
LNB Input F-TypeLoop-Through
14Volt / 18Volt
RF Modulator IEC male and female:
Terrestial
TV Antenna Input and
Output
S-VHS Video Output Din-Type, 4 Pins
Video Output
RCA-Type
Audio Output RCA-Type
Left and Right
0/12 Volt Control RCA-Type
Power AC Fixed Type
VCR Output Euro Scart
TV Output Euro Scart
Antenna Switching
22KHz Tone
Frequency: 22±4KHz
Amplitude:0.6±0.2V
DISEqC1.2 Positioner Support
Mini Port Support
4 Port Support
0/12Volt Relay Switch Support
aiuto iotronic 7121
buon pomeriggio a tutti non so se e la sezione giusta percio vi chiedo scusa o un decoder iotronic 7121 che vorrei aggiornare ce in giro qualche firmware e lista canali sia orbit che astra x questo decoder grazie anticipatamente x la risposta vi chiedo scusa e vi porgo un caloroso saluto a tutto il forum ciao
iotronic 7121
ciao antoniosky questo è un clone del fonestar rds 540 vedi che dovresti trovare un bel po di materiale per il fonestar cerca in giro .
