beta8_np67
New PMT for Nokia96xx. Quick switching between channel as coded,so and fta.In this connection request to check capacity to work different CAM.And not only on coded channel,but on fta including.For modules Irdeto FreeCam, Alphacrypt, Conax, under included mode autosvitch is added support of the work coded radio link.In menu "Info"(Guide\9\B) menu PIDs is removed,instead of it is now located menu Option.
The Hidden menu "fonts" under position 9 are removed,instead of it menu "PID Finder".Who did not know,under position 8 hidden menus "Cam Debug".Command Tca_Info_Ca_support is restored under button 1. In menu "SCSI Data" and "PWM/PTS/STC" make-up change.The Menu "Support Id" is moved and found instead of menu "Pid Finder"(Guide\A\9).In addition it is added support of the functioning(working) the provider Numericable. Menu "Scart"(Guide\9\5\A)works correct. Such change and in menu "ECM PID Scan".It Is Eliminated second line menu "page up\page down" and is added in addition line "B" for conclusion ECM.
http://www.wirelessclub.org/public_html/beta8_np67.zip
Se qualcuno ha voglia di testare....(con ncas, ovviamente)
