skygioppi
- 13 Novembre 2012
BlackPole V1.0 OE 2.0
Black Pole 1.0 has been entirely recoded under the latest Open Embedded 2.0.
The OE core of Black Pole images is original and totally new.
The gui of Black Pole images is derived from the latest updates of OpenPli enigma2, Black Hole gui and the official Vu+ gui.
The result is an image with the best performance and also a complete set of features and plugins.
There are far to many changes to Black Pole to list all the new features and a changelog.
So we will let you discover for yourself all the changes and the enhancements.
Because the image is entirely new please test Black Pole fully and report to us all your feelings and impressions.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
The image MUST be installed in the flash.
Black Pole can not support images not installed in the flash.
Main functions of the buttons on the remote
OK button = Skin with simple information
OK button x 2 = Extra Info Skin
Blue button = Black Pole Blue Panel
Blue button and then Red button = Black Pole Epg Panel
Blue button and then Yellow button = System Monitor Panel
Blue button long press = Extensions
Yellow button = Time Shift
Green button = Black Pole Green Panel
Green button long press = Subservices
Green button and then Red button = Fast Plugin Setup
Green button x 2 = Fast Plugin
Button Red = Start Record
Addons
Green button and then Yellow button takes you to:-
Dedicated server for Black Pole addons Feeds
Infobar / OSD
Analog Clock Gui
Channel orbital location
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar picons
Characteristics of Black Pole Panels
Blue Panel
Extra Settings
Devices Manager & Mountpoints
Network Browse & Mountpoints
Dlna Browser & UPnP Client
Dlna Server Minidlna
Usb Format Wizard
Swap File settings
OSD Settings
OSD Position setup
OSD 3D setup
Internal Epg Settings
Record settings
Recording paths
Subtitle settings
Auto Language Settings
Info Panel
Box Info
Memory info
Storage info
Software info
EPG Panel
Crossepg settings
Green Panel
Fast Plugin Setup (Configure quick access to your favourite plugin)
Fast Plugin (Access your favourite plugin)
Addons (added)
Online Feeds Extensions
Online Feeds all Packages
Online Black Pole image update
Manual install Bp Packages
Manual install Ipk Packages
Addons Uninstall Panel
Credits
Thanks to the group of Beta Testers.
Special Thanks to Pli team and expecially to pieterg Milo and hemertje for their support and for the big work they are making for all us.
Thanks to Skaman (Sif) andyblac (Vix) e plnick (Vti) for their friendly support and suggestions.
DISCLAIMER
THE BLACK POLE IMAGE IS BASED ON THE OPENPLI DISTRO AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE BLACK POLE IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE BLACK POLE IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE
THIS IS OPEN SOURCE SOFTWARE.
YOU CAN REDISTRIBUTE IT AND/OR MODIFY UNDER THE TERMS OF THE
GNU GENERAL PUBLIC LICENSE VERSION 2 AS PUBLISHED BY THE FREE
SOFTWARE FOUNDATION.
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.
Scaricabile su vuplus community,,,
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Usb Format Wizard
Swap File settings
OSD Settings
OSD Position setup
OSD 3D setup
Record settings
Recording paths
Subtitle settings
Info Panel
Box Info
Memory info
Storage info
Software info
EPG Panel
Crossepg settings
Green Panel
Addons (added)
Credits
DISCLAIMER
LICENSE
