CASTLE 1.06 DB 7000
Linux version 2.6.9 (gcc version 3.4.4)
1.10 head.ko
You can use it in multiboot in USB, NFS, CF or flash without any problem
Function Buttons:
No key included No softcam included
La potete scaricare nel Nostro Portale
o su TuttoDreambox
BUON Natale da Castle Group
1.10 head.ko
Function Buttons:
- BLUE - Castle Panel (CP)
- 2x BLUE - CP -> Addons
- YELLOW – Plugins
- RED - EPG list for active channel
- 2x RED - EPG style menu
- GREEN – subservices
- Castle EMU Manager 1.1.0
- Independent Start & Stop EMU / CARDSERVER
- Inadyn service configuration
- Swap file configuration
- Setting PVR movie folder
- Advanced daemons control (you can start / stop by panel, and start at boot. You can create your own autostart boot script, see /var/etc/sample_boot.sh)
- Support for sigboost, gSUB via advanced deamons control (Use only castle plugin)
- Advanced User Script (You can run script outside Enigma)
- Advanced System info (User can personalize it, see /var/etc/script.xml)
- Advanced Emu info (User can personalize it see /var/etc/emuscript.xml)
- Advanced HardDisk setup
- Parental control shortcut
- Castle news
- MediaHighwayEpg
- emm, ecm support
- Display Snr, Agc, Ber
- Display video info (depends on skin you use)
- Display frequency, polarization, symbol rate
- Display service providers name
- Advanced addons Manager
- Internet addons download with Proxy support
- Manual addons install
- Remove installed addons
- Expert web-if 5.9.7
o su TuttoDreambox
