Cerco programmi per testare lo stato di conservazione dei dati su DVD e CD
Cotechinho
Digital-Forum Master
4 Maggio 2004
42,6° N, 13,6° E
Salve, ho cercato nel forum e in rete ma non ho trovato nulla.
Cerco un programma che mi dica se i dati su DVD e CD sono ancora integri o se su una parte delle tracce i dati sono andati perduti, e possibilmente dica anche su quali tracce.
Possibilmente free, ma accetto ogni consiglio, anche su programmi a pagamento.
Grazie in anticipo.
Ho trovato CdCheck http://www.kvipu.com/CDCheck/ ma non si capisce fino a che punto è freeware.
Product: CDCheck
Version: 3.1.12.0 stable release
Author: Mitja Perko
License type: freeware/shareware (details)
Supported OS: Windows 95, 98, ME, NT, 2000, XP, 2003
Available languages: Arabic, Belarusian, Czech, English, French, German, Greek, Hungarian, Indonesian, Italian, Polish, Portuguese, Romanian, Russian, Serbian, Slovak, Slovene, Spanish, Taiwan, Ukrainian
Installation support: Yes
Installation size: 1MB
Required disk space: 2MB
Category: utilities - diagnostic
Purpose: file damage prevention, detection and recovery
Strongly recommended to: users of CD/DVD-Recorders, ZIP drives...
Short description (details): CDCheck is utility for prevention, detection and recovery of damaged files with emphasis on error detection. It offers readability verification, creation and checking of MD5, CRC-32, SHA... hashes (in file formats SFV, MD5 and CRC), extremly efficient file compare (faster than in most other programs) and recovery. CDCheck can be used on all files visible by the operating system. This means all files that you can see in Windows Explorer (CDs, DVDs, disk drives, floppy disks, ZIP drives, USB keys...). Apart from this it also works with audio CDs and provides information about inserted CD/DVD (manufacturer, media type...).
Longer description (details): CDCheck is utility for prevention, detection and recovery of damaged files with emphasis on error detection. It can check each your CD/DVD (or any other media) and indicate which files are corrupted. CDCheck reporting features tell you exactly where the problems are. Files on CDs, zip drives, USB keys etc. can get damaged in a number of ways, so the program helps you determine whether your data is safe before it's too late. The program also provides extremly fast binary compare for effectively checking that file transfers (burning, copying...) were accomplished successfully and alerts you of differences. Besides that CDCheck supports creation and checking of MD5, CRC-32, SHA... hashes in SFV, MD5 and CRC file formats. This provides means to check backups for possible loss of information or verify file transfers where comparing is not possible (transfer over mail etc.). The program can be used with all local or removable media (CDs, DVDs, disk drives, floppy disks, ZIP drives, USB keys...) visible by the operating system (Windows Explorer) and also with audio CDs. In addition CDCheck also gives detailed information (manufacturer, type, capacity...) about inserted CD or DVD media.
Key features (details):
hash creation and checking
file/directory checking
binary file/directory compare
file/directory recovery
audio CD support
data DVD support
CD/DVD information with media ratings
CDCheck does not provide:
recovery of files that cannot be seen by Windows Explorer
(audio CD recovery is possible but not recommended)
recovery of deleted files (from disk, floppy drive...)
Grazie mille frankie62, è totalmente free (basta registrarsi), e sembra anche abbastanza buono, valuta il numero di errori che trova nel supporto.
Io comunque cercavo qualcosa di leggermente diverso, cioè un programma che ti dica quali tracce siano ancora utilizzabili e quali no, in relazione alla durata fisica del CD e del DVD. Vedevo a Quark qualche settimana fa un programma che illustrava le tracce integre e quelle "andate" di un DVD, evidenziandole in colori diversi. Mi servirebbe per valutare la durata dei miei DVD e CD, e il lasso di tempo dopo il quale mediamente si configura la necessità di fare dei backup di sicurezza.
Anche questo però potrebbe fare al caso, se riesco a stabilire empiricamente quanti errori siano fisiologici di ogni DVD e CD e quanti invece evidenzino un deterioramento del supporto.
