Chaparral corotor - golden ring help
zuchnet
22 Luglio 2009
Poland
Hello my friends I buy Chaparral Corotor II Plus Wideband into my dish but I have to use a golden ring because my f/D is 31. I have not this ring and I dont know like this ring seen. If You have a photo this ring friends I will be happy and what use this ring at corotor.
Best regards Zuchnet.
I found only this, sorry...
Golden Ring
Description
The optional golden ring is no longer available, but if you set your Corotor or Polarotor feedhorn to an f/D ratio for .32 the performance will be fine.
It is most important that you make sure the focal length is set correctly.
Generally 95 % effectiveness is having the correct focal position. The rest is a trade-off between gain and system noise.
The golden ring was used to reduce terrestrial interference not to improve the signal gain.
@MISTERSAT
Thank You verry much for this info so I think that this golden ring its not verry important.
