Crash improvviso all'avvio del pc
otreblax 90
Digital-Forum Master
1 Dicembre 2011
Accendendo il pc ho avuto questo improvviso crash il cui il monitor rimaneva in stand by ed il pc si e riscaldato come se avessi giocato, allora lo riavviato dal pulsantino del reset ed ha fatto il ripristino del sistema ed adesso funziona correttamente.
Ho installato who crashed ma non so usarlo bene, lo aperto e cliccato su analyze poi e venuto fuori un breve messaggio ed ho cliccato ok e scorrendo con il mouse sotto leggo questo:computer name: FOTI-PC
windows version: Windows 7 Service Pack 1, 6.1, build: 7601
windows dir: C:\Windows
CPU: AuthenticAMD AMD Phenom(tm) II X4 955 Processor AMD586, level: 16
4 logical processors, active mask: 15
RAM: 4292993024 total
VM: 2147352576, free: 1928081408
Crash Dump Analysis
Crash dump directory: C:\Windows\Minidump
Crash dumps are enabled on your computer.
On Fri 11/10/2013 20:14:30 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101113-20607-01.dmp
This was probably caused by the following module: kneps.sys (0xFFFFF880046D019C)
Bugcheck code: 0xD1 (0x10, 0x2, 0x0, 0xFFFFF880046D019C)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\drivers\kneps.sys
product: Kaspersky™ Anti-Virus ®
company: Kaspersky Lab ZAO
description: KNEPS Power [fre_wnet_amd64]
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: kneps.sys (KNEPS Power [fre_wnet_amd64], Kaspersky Lab ZAO).
Google query: Kaspersky Lab ZAO DRIVER_IRQL_NOT_LESS_OR_EQUAL
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: kneps.sys (kneps+0x319C)
Conclusion
2 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination the errors that have been reported for these drivers and include the brand and model name of your computer as well in the query. This often yields interesting results from discussions from users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is actually responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Cosa vuol dire ? come mai mi riporta un errore del 11/10/2013 se l'errore e avvenuto oggi 31/12/2013 ? cosa può essere stato ?
ciao e Buon Anno
Il problema è causato dall'antivirus.
Assicurati di avere l'ultima versione, in ogni caso ci sono diverse segnalazioni in giro riguardo quel problema che può causare Kaspersky
Si e l'ultima versione ossia la pach d, il crash e avvenuto oggi come mai mi da una data vecchia il rapporto di who crashed ?
Verifica se è stato solo un caso isolato o se si ripresenta ancora
