DivX 6.1.1
ERCOLINO
Membro dello Staff
Amministratore
3 Marzo 2003
Torino
Disponibile un aggiornamento versione il pacchetto dei codec , necessari per visualizzare e comprimere i file video utilizzandoil formato DivX™.
DivX Create Bundle
The DivX Create bundle offers all the tools necessary to create and play DivX videos with groundbreaking interactive features.
DivX Play Bundle
The DivX Play Bundle gives you everything you need to start watching high-quality DivX videos, including DivX® Video-on-Demand movies. All the tools in DivX Play are also available in DivX Create.
New in this version
Fixed a problem where some systems would crash as the Psychovisual Enhancement method was modified in the encoder configuration window.
Improved B-frame decision.
Improved rate control for very high bitrates.
Fixed a problem that caused cropping to reduce performance.
Fixed an issue where adjusting the VBV_bitrate slider in the Feedback Window would reset the VBV buffer occupancy.
Improved Japanese encoder translations.
Fixed a problem where the decoder may fail if both smooth playback and YUV output are enabled in the Decoder Configuration Utility.
Fixed a post-processing issue in the decoder for multi-threading systems.
Fixed a handle leak in the decoder.
Known issues
Info&download qui
