[DM 500 - DM 5620] SIF TeAm 1.8.4 maxvar
GiacomoMassucco
Membro dello Staff
Collaboratore
20 Aprile 2006
Casarza Ligure (Genova)
DB500:
Usable to flash
* Enigma of: 16.10.2007
* Linux version 2.6.9
* GCC 3.4.4 Original CVS
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
DB5620:
Usable to flash
* Enigma of: 04.10.2007
* Busybox 1.01
* Tuxtxt v. 1.99
Buttons:
* BLUE - Blu-Panel
* BLUE > 1 sec. ..start plugin called BlueRelease (you rename another if want)
* 2x BLUE - Emu-Panel
* YELLOW - Plugins
* BLUE - YELLOW > Addons
* BLUE - GREEN > Scripts
* RED - WEEKEPG (thanks to MaxZ4)
* GREEN - subservices
Features:
* Advanced FIREWALL with graphics start/stop/configuration
* Advanced SWAP file configuration, you can set swap in USB, CF or HDD (16mb or 32 mb)
* Advanced DNS with graphics start/stop/configuration
* Advanced FILES visualizations
* Advanced BACKUP with graphics start/stop/configuration
* Set CROND start at any boot
* Advanced crond system
* Set SAMBA start at any boot (7000 have to install samba-plugin)
* Advanced WEEKEPG options ( ...if you want use standard, set to blu-panel->options->weekepg )
* Automount HDD USB CF
* Advanced HDD ..set sleep and acoustic options
* Advanced SCRIPT options for personal set
* Advanced OpenVpn with graphics start/stop/configuration
* Advanced AMULE with graphics start/stop
* Advanced TORRENT with graphics start/stop/configuration (thanks to MaxZ4)
* Set personal AUTOSTART program
* Color set to RGB from default ( for lcd TV)
* Simple Set directory for picon and part of /var (bin and tuxbox, moved where you want)
Display Function:
* Set zap without OSD (if press OK return OSD)
* Set OSD always on when OK is pressed (required from nokia9k8)
* Display Snr, Agc, Ber
* Display video information
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID (you can hide from options)
* Display Decoding Source (you can hide from options)
* Display long date format
* Picon, already inserted to enigma code (thanks to jlmota)
* SkinPreview (thanks to jlmota)
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
* Set off/on and houres/minutes for autorestart CAM
Addons:
* Internet addons download
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Skin default - tux ...from porto
* Picon is already installed (DB7000, IPBOX250, IPBOX350 ..have only default.png)
* Several Plugins/Games/Addons installed
* IPBOX250S IPBOX350S ...have to set mID 25 and 26
* IPBOX200S ...autoset mID
* IPBOX200S have UHF in/out
* IPBOX200S ...for free memory (if is necessary):
1) Go to free channel
2) Restart enigma
3) Click to "Free Memory"
...now is possible to start/stop install/remove visualize script ecc..
THANKS TO:
DB500 > frog68.
DB7000 > ngc1927, MaxZ4.
DB7020 > ngc1927.
IPBOX200S > ngc1927.
IPBOX250S > astemio.
IPBOX350S > ngc1927, genge, voodo3
All IPBOX > ..special thanks to sandali for its branch of development ..and at Blakskettle for info and help.
FOR ALL > jlmota, porto, JoeBlack® ...and other?
VARIOUS:
This image is based, beyond that my "much" code and hard work, to Dream-cvs, parts of old Hydra
source (EMU/ADDONS ...emubroker is this) to little EasyEmu parts ...and other?
ATTENZIONE:
QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE'
INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
L'AUTORE NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE
GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR
URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
AUTHOR IS NOT RESPONSIBLE IN ANY WAY FOR WHAT
THE USERS WILL DO WITH THIS FIRMWARE.
Scaricabili dal SIF ;)
