Purtroppo il mio bell'800HD (originalissimo) è defunto con quell'errore. Non so se sia stato un problema di flash o di stacca/attacca corrente.
Come lo risolvo? Ho trovato diverse guide ma sono tutte per i cloni. Il mio invece è originale. Posso flashare un'immagine completa via seriale?
Sul forum ufficiale ho trovato questo suggerimento:
- Unplug all connections from DM, only leaving ethernet cable (straight cable if going to a router) and serial connection to your PC, If using a USB --> Serial converter, make sure you have correct drivers installed (Confirm in control panel --> System--> Device manager --> Ports on XP). Note your COM port of your connection.
- Ok firstly use dreamup1.3.3.4, make sure you got 'network' box checked and enter an IP address in the same subnet as your router. this will be the same first 3 digits only altering the last digit (as your subnet mask will be 255.255.255.0), enter a value you know to be free (I chose 100)
- Confirm that you have correct COM port selected
- Select CONNECT
- Plug back in mains on DM (dreamup should load the flashloader and then display the error CA error etc, press OK)
- Dont waste your time on 'Enforcer' or 'dream_fix' (ie. the tools that activate the flash button within dreamup), you will only get the error message that says 'File Too Big' error.
- Press OK on error message (you should now have an IP address assigned to your DM and displayed in the front panel of your DM)
- Open browser window and type in DMs IP in the address bar
- Wait for DM welcome window (I found this took a long time to load, more so after selecting a .nfi image that had a different Second stage BL to my corrupt version, so be patient! :sleeping: )
- Note the value of the secondstage bootloader (this is very valid if this is your first attempt at trying the repair and no other firmwares have been loaded)
- Press on 'device upgrade' select a .nfi build that has the same second stage loader that was on your DM before the 'CA error' (If you dont know you'll have to keep rebooting and repeating the process, trying different .nfi images until you match it ;( )
- Once the secondstage BL match is made, you'll find that the unit boots past the 'error' message and all appears as it should
Vi sembra ragionevole?
- Select CONNECT
