Dream Elite BH 1.3 OE1.6 DM800 Multiboot Usb Tuner
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
WHAT IS NEW ?
Updated: Dreambox Dvb drivers: 20100414
Updated: Enigma2 CVS: Experimental 15 april 20010
New Skin: Army Class Plus HD
Fixed: Device Panel minor bugs
Included: networkbrowser, mytube, videoenhancement, autoresolution and DVDPlayer
NEW NEW NEW NEW NEW NEW NEW NEW NEW NEW
Usb tuner Dvb-T native support and dedicated panel in Extra-settings.
TO BE SURE THAT YOUR USB TUNER IS SUPPRTED USE:
Hauppauge WinTV-Nova-T (HD)
Instructions to use Usb Dtt Tuner:
1) Insert your usb tuner stick
2) Goto blue -> blue -> Usb-Dvb-T Tuner Panel
3) Activate
The Usb Drivers will be Extended and Updated via Addons Manager.
Currently included Anglofsky1980 Driver Module DIB0700:
AVerMedia AVerTV DVB-T Volar
Compro Videomate U500
Uniwill STK7700P based (Hama and others)
Leadtek Winfast DTV Dongle (STK7700P based)
AVerMedia AVerTV DVB-T Express
Gigabyte U7000
Hauppauge Nova-T 500 Dual DVB-T
Pinnacle PCTV 2000e
Terratec Cinergy DT XS Diversity (Test OK)
Hauppauge Nova-TD Stick/Elgato Eye-TV Diversity (Test NOK )
ASUS My Cinema U3000 Mini DVBT Tuner
Pinnacle PCTV DVB-T Flash Stick
Artec T14BR DVB-T
ASUS My Cinema U3100 Mini DVBT Tuner (Test NOK)
Hauppauge Nova-T Stick (70019) (test OK)
Hauppauge Nova-T MyTV.t
Pinnacle PCTV Dual DVB-T Diversity Stick
Warning: DON'T INSTALL EXTERNAL DRIVERS IN THIS IMAGE OR THE USB TUNER PANEL WILL STOP TO WORK. YOU CAN INSTALL IN THIS IMAGE ONLY DEDICATED DREAM ELITE DRIVERS PACKAGES
Warning: Old plugins for OE 1.5 cannot work in OE 1.6, you have to ask to plugin authors to update. This is not an image problem. DON'T REPORT HERE FOR PLUGINS. WE ARE NOT PLUGINS AUTHORS
Warning2: THIS IMAGE HAVE THE NEW DRIVERS AND CANNOT BE INSTALLED IN MULTIBOOT USING PREVIUS IMAGES. THIS IMAGE HAVE TO BE INSTALLED IN FLASH
Warning3: AFTER IMAGE INSTALLATION GOTO DEVICES PANEL AND MAP YOUR DEVICES. REMEMBER TO INSTALL MEOBOOT ONLY AFTER YOU HAVE MAPPED YOUR DEVICES.
Warning4: ONCE YOU HAVE INSTALLED MEOBOOT DON'T MOVE DEVICE IN WICH MEOBOOT IS INSTALLED. (AS FOR EXAMPLE IF MEOBOOT IS INSTALLED ON USB DON'T REMAP THE DEVICE OF MEOBOOT ON USB2)
Warning5: YOU CAN INSTALL IN MULTIBOOT WITH THIS IMAGE ONLY IMAGES OE 1.6 WITH THE NEW KERNEL.
This image is a final Black Hole serie, to have maximum stability and performance.
We remember that black hole serie images have the best epg system available:
- Integrated Openepg for Sky-it Sky-uk Sky-Au
- Latest CVS enigma2 Epg features
- New external epg.dat system.
Therefore, each board or community can create its favourite EPG data files, and upload it to a web space. Community members can then download it from that server.
This feature offers additional benefits, such as:
EPG download increased speed
EPG download from any channel
EPG scheduled download also during standby
User set EPG Providers Add/Remove
WARNING: THIS IMAGE INCLUDE THE NEW KERNEL 2.6.18-7.3. FOR THIS REASON YOU HAVE TO INSTALL IN MULTIBOOT ONLY LATEST IMAGES BASED ON OE 1.6 WITH NEW KERNEL.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Dream ELite Blue Panel
Button 1x Blue + 1x Red = Dream Elite Epg Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Blue-Long-Push = Extensions
Button Green = Dream Elite Green Panel
Button Green-Long-Push = Subservices
Button 1x Green + 1x Red = CCcam Info
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Download and install additional packages from Dream Elite server​
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Dream Elite Panels features
Blue Panel
Extra Setting
Black Hole Cron Manager
OSD Settings
Devices Manager
Kernel Modules Manager
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Black Hola Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process
AutoCam
Select EMU by Channel
EPG Panel
Global setting
Provider Setting
Green Panel
CCcam info
Fast Plugin
Addons
Addons Download Manager
Manual Install Del packages
Manual Install IPK packages
Addons Uninstall Panel
Dream Elite Statistics
Scripts
Many thanks to the Beta Testers Team.
Many thanks to Rytec for all the epg servers providing precompiled Epg.dat for Dream Elite Image (add skyIta and SkyDe).
Credits
Many Thanks to Rytec for external epg
E2 Sky Epg loader integration by MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
Many thanks to Reinh@rd for the satellites.xml file.
MANY THANKS TO ANGELOFSKY1980 FOR USB DVB-T DRIVERS
ATTENTION!
THIS IMAGE HAVE TO BE INSTALLED IN FLASH.
THIS IMAGE CANNOT WORK IN MULTIBOOT WITH DIFFERENT IMAGES IN FLASH. DREAM ELITE TEAM WILL NOT SUPPORT IMAGES NOT INSTALLED IN FLASH.
Known bugs:
Hdd temperature is not working in OE 1.6 and the result is unpredictable
Backups or other modified Images are not supported!
This Images doesn't contain any keys nor softcams.
La piccola scatoletta di sardine è diventata una grande macchina da guerra :evil5: un particolare ringraziamento all'Equipe che ha sviluppato il tutto ;)
Confermo l'ottimo lavoro svolto da questo team:
con questa pennetta
WINTV NOVA-T-HD stick
model su confezione 368, codice su penna 70019 rev. D1F4
va che è una meraviglia :D :D :D
Acquistata la AverTv Volar Black HD A850. Scaricati e installati i driver di Dpeddi e la pennetta va a meraviglia. Purtroppo il segnale Dtt qui fa veramente pena!
