Dreambox 520HD bloccato
longior
11 Luglio 2009
Roma
Saluti a tutti, purtroppo il decoder si è bloccato dopo un aggiornamento software. Non riparte ed è bloccato sulla luce rossa del pulsante; c'è una soluzione?
Appena dai corrente tieni il dito sul tasto rosso se e come il 900 va in recovery eccc...
Niente da fare, non va.
L'ho collegato al PC ed ho avviato Putty, di seguito il codice che restituisce;
Codice:
Dreambox DM520
M0CZS
L2=1
LLMB=1
BrCfg=E30FB7C6
BCM973625A0 CFE v15.3, Endian Mode: Little
Build Date: Fri Jun 24 16:38:03     2016 (Jann@Cynric)
Copyright (C) Broadcom Corporation.
card if inited
Enabling NAND flash at CS2: A5U4GA31ATS(DEVICE ID=0xC8DC9095), ECC Level=4, Spar        e Area Size=16
MACRONIX SPI flash detected: Size = 16MB, Sector Size 4096, Page Size 256
CPU speed:            751MHz
DDR Frequency:        1061 MHz
DDR Mode:             DDR3
Total memory(MEMC 0): 512MB
MEMC 0 DDR Width:     16
Boot Device:          SPI
Total flash:          16MB
RTS VERSION:          rts_hevc10_1067
ETH0_PHY:             INT
ETH0_MDIO_MODE:       1
ETH0_SPEED:           100
ETH0_PHYADDR:         1
DM init finalization
yxml: processing file of 131072 bytes... succeeded!
no file loaded, create xml restoring default xml
loaded network params of: DHCP, 192.168.0.219, 255.255.255.0, 192.168.0.1
[1] type 3, dev nandflash0.kernel, loader elf, filesys raw, file , options
[2] type 3, dev flash0.kernel, loader elf, filesys raw, file , options
[3] type 1, dev eth0, loader elf, filesys tftp, file , options bmem=192M@64M con        sole=ttyS0,1000000 root=/dev/nfs ip=dhcp
added 3 sources to autoboot list
init fp
Initializing USB.
CFE initialized.
found card in unknown state
ca valid!
***** DREAMBOX SSBL *****
Not interrupted yet, trying autoboot or rescue loader, hit any key in the next 5        00ms to cancel
USB: New high speed device connected to bus 0 hub 1 port 1
USB: Locating Class 08 Vendor 0951 Product 1643: Mass-Storage Device
USBMASS: Unit 0 connected
Proceeding with autoboot.. You can try aborting with Ctrl+C
*** Autoboot: Trying device 'nandflash0.kernel' file  (raw,elf)
Ethernet Cable unplugged
Loader:elf Filesys:raw Dev:nandflash0.kernel File: Options:
Loading: 0x80001000/8440000 0x8080d8c0/258096 Entry address is 0x80673c50
Closing network eth0
Starting program at 0x80673c50
[    0.248000] console [ttyS0] enabled, bootconsole disabled
[    0.252000] loop: module loaded
[    0.253000] brcmstb_nand: NAND controller driver is loaded
[    0.375000] bcmgenet: configuring instance #0 for internal PHY
[    0.395000] bcmgenet bcmgenet.0: (unregistered net_device): link down
[    0.396000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.397000] ehci-brcm ehci-brcm.0: Broadcom STB EHCI
[    0.397000] ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus numbe        r 1
[    0.429000] ehci-brcm ehci-brcm.0: irq 66, io mem 0x10480300
[    0.435000] ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
[    0.436000] hub 1-0:1.0: USB hub found
[    0.436000] hub 1-0:1.0: 2 ports detected
[    0.437000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.438000] ohci-brcm ohci-brcm.0: Broadcom STB OHCI
[    0.438000] ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus numbe        r 2
[    0.439000] ohci-brcm ohci-brcm.0: irq 67, io mem 0x10480400
[    0.505000] hub 2-0:1.0: USB hub found
[    0.505000] hub 2-0:1.0: 2 ports detected
[    0.506000] Initializing USB Mass Storage driver...
[    0.507000] usbcore: registered new interface driver usb-storage
[    0.508000] USB Mass Storage support registered.
[    0.508000] i2c /dev entries driver
[    0.509000] lirc_dev: IR Remote Control driver registered, major 253
[    0.509000] usbcore: registered new interface driver btusb
[    0.511000] TCP: cubic registered
[    0.511000] NET: Registered protocol family 10
[    0.513000] NET: Registered protocol family 17
[    0.513000] Bluetooth: RFCOMM TTY layer initialized
[    0.514000] Bluetooth: RFCOMM socket layer initialized
[    0.515000] Bluetooth: RFCOMM ver 1.11
[    0.515000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    0.516000] Bluetooth: BNEP filters: protocol multicast
[    0.516000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    0.517000] L2TP core driver, V2.0
[    0.517000] Registering the dns_resolver key type
[    0.518000] PM: CP0 COUNT/COMPARE frequency does not depend on divisor
[    0.520000] EBI CS2: setting up NAND flash (primary)
[    0.521000] NAND device: Manufacturer ID: 0xc8, Chip ID: 0xdc (Unknown NAND 5        12MiB 3,3V 8-bit)
[    0.522000] brcmnand brcmnand.0: 512MiB total, 128KiB blocks, 2KiB pages, 16B        OOB, 8-bit, BCH-4
[    0.522000]
[    0.524000] Bad block table found at page 262080, version 0x01
[    0.525000] Bad block table found at page 262016, version 0x01
[    0.526000] nand_read_bbt: bad block at 0x0000006a0000
[    0.527000] Creating 3 MTD partitions on "brcmnand.0":
[    0.528000] 0x000000000000-0x00001f500000 : "rootfs"
[    0.530000] 0x000000000000-0x000020000000 : "entire_device"
[    0.532000] 0x00001f500000-0x00001fa00000 : "kernel"
[    0.534000] EBI CS0: setting up SPI flash
[    0.534000] spi_brcmstb spi_brcmstb.0: 1-lane output, 3-byte address
[    0.535000] spi_brcmstb spi_brcmstb.0: master is unqueued, this is deprecated
[    0.536000] m25p80 spi0.0: found mx25l12805d, expected w25q128bv
[    0.537000] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[    0.539000] UBI: attaching mtd0 to ubi0
[    0.539000] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    0.540000] UBI: logical eraseblock size:    126976 bytes
[    0.541000] UBI: smallest flash I/O unit:    2048
[    0.541000] UBI: VID header offset:          2048 (aligned 2048)
[    0.542000] UBI: data offset:                4096
[    0.739000] usb 1-1: new high-speed USB device number 2 using ehci-brcm
[    0.859000] scsi0 : usb-storage 1-1:1.0
[    1.930000] scsi 0:0:0:0: Direct-Access     Kingston DataTraveler G3  1.00 PQ        : 0 ANSI: 4
[    1.934000] sd 0:0:0:0: [sda] 30233588 512-byte logical blocks: (15.4 GB/14.4        GiB)
[    1.936000] sd 0:0:0:0: [sda] Write Protect is off
[    1.937000] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doe        sn't support DPO or FUA
[    1.943000]  sda: sda1
[    1.946000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    3.692000] UBI: max. sequence number:       14088
[    3.708000] UBI: attached mtd0 to ubi0
[    3.709000] UBI: MTD device name:            "rootfs"
[    3.709000] UBI: MTD device size:            501 MiB
[    3.710000] UBI: number of good PEBs:        4007
[    3.711000] UBI: number of bad PEBs:         1
[    3.711000] UBI: number of corrupted PEBs:   0
[    3.712000] UBI: max. allowed volumes:       128
[    3.712000] UBI: wear-leveling threshold:    4096
[    3.713000] UBI: number of internal volumes: 1
[    3.713000] UBI: number of user volumes:     1
[    3.714000] UBI: available PEBs:             0
[    3.714000] UBI: total number of reserved PEBs: 4007
[    3.715000] UBI: number of PEBs reserved for bad PEB handling: 40
[    3.716000] UBI: max/mean erase counter: 7/4
[    3.716000] UBI: image sequence number:  2028306359
[    3.717000] UBI: background thread "ubi_bgt0d" started, PID 59
[    3.719000] ALSA device list:
[    3.719000]   No soundcards found.
[    3.770000] UBIFS: recovery needed
[    3.901000] UBIFS: recovery completed
[    3.902000] UBIFS: mounted UBI device 0, volume 0, name "dreambox-rootfs"
[    3.903000] UBIFS: file system size:   501809152 bytes (490048 KiB, 478 MiB,        3952 LEBs)
[    3.903000] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEB        s)
[    3.904000] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    3.905000] UBIFS: default compressor: lzo
[    3.905000] UBIFS: reserved for root:  0 bytes (0 KiB)
[    3.907000] VFS: Mounted root (ubifs filesystem) on device 0:12.
[    3.910000] devtmpfs: mounted
INIT: version 2.88 booting
/etc/init.d/rc: line 72: stty: command not found
/etc/rcS.d/S02sysfs.sh: line 17: grep: command not found
/etc/rcS.d/S02volatile-media.sh: line 13: grep: command not found
/etc/rcS.d/S04mdev: line 3: grep: command not found
/etc/rcS.d/S04mdev: line 4: grep: command not found
/etc/rcS.d/S04mdev: line 8: rm: command not found
/etc/rcS.d/S04mdev: line 9: mknod: command not found
/etc/rcS.d/S04mdev: line 10: mkdir: command not found
mount: mount point /dev/pts does not exist
/etc/rcS.d/S04mdev: line 19: touch: command not found
/etc/rcS.d/S04mdev: line 23: mdev: command not found
/etc/rcS.d/S04modutils.sh: line 19: uname: command not found
/etc/rcS.d/S04modutils.sh: line 29: cat: command not found
/etc/rcS.d/S05modload.sh: line 6: find: command not found
/etc/rcS.d/S05modload.sh: line 6: grep: command not found
/dev/dvb/adapter0/video0: No such file or directory
/etc/rcS.d/S06checkroot.sh: line 145: ln: command not found
/etc/rcS.d/S06hotplug.sh: line 3: mdev: command not found
/etc/rcS.d/S37populate-volatile.sh: line 12: dirname: command not found
/etc/rcS.d/S37populate-volatile.sh: line 13: sed: command not found
/etc/volatile.cache: line 2: mkdir: command not found
/etc/volatile.cache: line 3: chown: command not found
/etc/volatile.cache: line 4: chmod: command not found
/etc/volatile.cache: line 6: mkdir: command not found
/etc/volatile.cache: line 7: chown: command not found
/etc/volatile.cache: line 8: chmod: command not found
/etc/volatile.cache: line 10: mkdir: command not found
/etc/volatile.cache: line 11: chown: command not found
/etc/volatile.cache: line 12: chmod: command not found
/etc/volatile.cache: line 14: mkdir: command not found
/etc/volatile.cache: line 15: chown: command not found
/etc/volatile.cache: line 16: chmod: command not found
/etc/volatile.cache: line 18: mkdir: command not found
/etc/volatile.cache: line 19: chown: command not found
/etc/volatile.cache: line 20: chmod: command not found
/etc/volatile.cache: line 23: readlink: command not found
/etc/volatile.cache: line 37: readlink: command not found
/etc/volatile.cache: line 51: readlink: command not found
/etc/volatile.cache: line 65: readlink: command not found
/etc/volatile.cache: line 79: readlink: command not found
/etc/volatile.cache: line 92: mkdir: command not found
/etc/volatile.cache: line 93: chown: command not found
/etc/volatile.cache: line 94: chmod: command not found
/etc/volatile.cache: line 96: touch: command not found
/etc/volatile.cache: line 97: chown: command not found
/etc/volatile.cache: line 98: chmod: command not found
/etc/volatile.cache: line 100: touch: command not found
/etc/volatile.cache: line 101: chown: command not found
/etc/volatile.cache: line 102: chmod: command not found
/etc/volatile.cache: line 104: touch: command not found
/etc/volatile.cache: line 105: chown: command not found
/etc/volatile.cache: line 106: chmod: command not found
/etc/volatile.cache: line 108: touch: command not found
/etc/volatile.cache: line 109: chown: command not found
/etc/volatile.cache: line 110: chmod: command not found
/etc/volatile.cache: line 112: touch: command not found
/etc/volatile.cache: line 113: chown: command not found
/etc/volatile.cache: line 114: chmod: command not found
/etc/volatile.cache: line 116: touch: command not found
/etc/volatile.cache: line 117: chown: command not found
/etc/volatile.cache: line 118: chmod: command not found
/etc/volatile.cache: line 120: mkdir: command not found
/etc/volatile.cache: line 121: chown: command not found
/etc/volatile.cache: line 122: chmod: command not found
/etc/volatile.cache: line 124: mkdir: command not found
/etc/volatile.cache: line 125: chown: command not found
/etc/volatile.cache: line 126: chmod: command not found
/etc/volatile.cache: line 128: mkdir: command not found
/etc/volatile.cache: line 129: chown: command not found
/etc/volatile.cache: line 130: chmod: command not found
/etc/volatile.cache: line 132: mkdir: command not found
/etc/volatile.cache: line 133: chown: command not found
/etc/volatile.cache: line 134: chmod: command not found
/etc/volatile.cache: line 136: mkdir: command not found
/etc/volatile.cache: line 137: chown: command not found
/etc/volatile.cache: line 138: chmod: command not found
/etc/rcS.d/S37populate-volatile.sh: line 231: ln: command not found
/etc/rcS.d/S38devpts.sh: line 13: grep: command not found
/etc/rcS.d/S38dmesg.sh: line 17: /var/log/dmesg: No such file or directory
ALSA: Restoring mixer settings...
/etc/rcS.d/S39hostname.sh: line 10: /bin/hostname: No such file or directory
/etc/rcS.d/S39hostname.sh: line 19: cat: command not found
/etc/rcS.d/S39hostname.sh: line 19: hostname: command not found
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
vm.dirty_writeback_centisecs = 300
vm.dirty_background_ratio = 1
vm.min_free_kbytes = 8192
vm.dirty_ratio = 60
vm.swappiness = 30
/usr/sbin/alsactl: state_lock:125: file /var/lib/alsa/asound.state lock error: N        o such file or directory
/usr/sbin/alsactl: load_state:1683: Cannot open /var/lib/alsa/asound.state for r        eading: No such file or directory
Starting tpmd/etc/rcS.d/S60tpmd: line 9: start-stop-daemon: command not found
Provi a dare questo comando da telnet "echo rescue > /proc/stb/fp/boot_mode" poi questo"shutdown -r now" e se non risolvi usi solo questo"to-the-rescue" se non hai risolto gia,dovrebbe mandare il box in recovery e installi un nuova image
Ti ringrazio infinitamente per la risposta ma ho provveduto a restituirlo, e lo riacquisterò per la fine del mese.
Credo che i comandi che hai descritto vadano inseriti nella sezione che si apre come da descrizione
Codice:
, o eventualmente, per usi futuri, ti prego cortesemente di specificare in che modo vadano inseriti.;)
