DS² 1.0 powered by DBF soon on your 7025
Ferbius
Digital-Forum Silver Master
2 Marzo 2002
Image per FLASH / USB / HDD / CF
+ CVS Enigma2 2008.02.05
+ Kernel v. 2.6.12.6
+ BusyBox v1.01
+ Gcc 4.1.1 Original CVS
+ Dvb-modules 2007.11.26
New mapping of Buttons:
+ BLUE Button - EmuManager
+ LONG BLUE Button - Extensions
+ YELLOW Button - Timeshift
+ LONG YELLOW Button - DS Extras
+ GREEN Button - Subservices (NVOD)
+ AUDIO Button - Audio Selection
+ TEXT Button - Videotext
+ RED Button - Record
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING
ILLEGAL STUFFS OF ANY TYPE. ONLY WITH ORGINAL DREAMCRYPT SUPPORT!!
!!! DS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS
FIRMWARE.
Our ideas, durning creating this image?
well,
We would like to make fast and stable image. Our point was to make all stuff, like in Enigma 1 images for DM7000/56x0/500 TM9100/9100 ITGATE100/110/200/220.
So here is the result
- Same emu changing logic ( emulist.xml and emu_scripts also in xml )
- Same installer ( emus )
- Same Management Addons
- Same functions ( not all yet )
- Same look
- Same STABILITY
- SAME SPEED
Also, we DON'T touch any CVS source, we only ADD our functions, so, to update cvs is very easy now. And CVS things must works like in other images.
We hope you will enjoy this image on your DM7025 or DM7025+.
News:
- DS MultiLine 9 as a default skin by Mimi74
Infobar Aviable Informations:
+ Active EMU in Skin
+ Active Cryptinfos in Skin
+ SNR & AGC & BER in Skin
+ Provider name in Skin
+ Video Resolution in Skin
+ Fr, SR, Pol, Fec Info in skin
+ Decoding Source
+ Display Multi-audio and Teletext on OSD
+ Caid in Skin
+ Provider ID in Skin
+ Date in Skin
+ Ecm Time
+ Hops
+ Source
+ **** Name
In Menu->DS Extras
+ Addon Manager
- Download Addons
- Remove Addons
- Manual installation
Management Addons Logic:
As you know we use XML installer on Enigma 1 images, also here we include this function to install emus, to install other plugins we use IPK package manager.
Codice:
root@dm7025:~# installer
usage: installer [--version] [--help] [--add /usr/uninstall/EMUNAME] [--remove EMUNAME]
--add /usr/uninstall/EMUNAME = add EMUNAME configuration from /usr/uninstall/EMUNAME/emulist.xml
--remove EMUNAME = delete given emu configuration from /usr/tuxbox/config/emulist.xml
--version = show version and exit
root@dm7025:~#
After Emu install enigma2 will reboot to have aviable to choose all emus!!
+ Stream Advanced informations
- PAT info
- CAT info
- NIT info
- SDT/BAT info
- EIT/TOT/TDT info
- PMT info
- ECM info
- Help
+ Samba Manager
+ SyslogD & KlogD Manager
+ OpenVPN Manager
+ DropBear SSH Manager
+ Inadyn Setup
+ HTTPD Setup
+ System Information
- Free Ram Memory
- Free JFFS2 Memory
- Free Flash Memory
- Free HDD Memory
- Free USB Memory
- Free CF Memory
- Running Processes
- Active internet Connections
- View and Clear Timer Log
- Lan settings info
Mount manager based on Ronaldd code
+ Emu Manager
+ Reset CS
+ Reset EMU
+ Reset Both
+ Filecheck ( pressing RED button on EmuManager you can see, that all files are on right place, then emu can start )
+ DSemud Info ( information about started daemons )
+ Extended
+ **** File Viewer
+ **** File Converter
+ **** File Update
+ Extended informations for:
- CCcam
- GBox
+ Devices Setup
- HDD Info
-- Current information directly
-- Perform cache read timings
-- Perform device read timings
-- Device Temperature info
-- Updating Device List
- HDD Setup
-- Put Harddisk to start
-- Put Harddisk in standby mode
-- Setup standby timeout
-- Setup acustic
-- Harddrive informations
- USB Settings
--Format usb storage in Auto mode/ DISK / PART1
+Infobar Setup
- Use Lite-Skin
- Show Emu Name in Skin
- Show Provider ID and Ca ID in Skin
- Show NetCard Info in Skin
- Show Decoding Source in Skin
- Show Expert Tuner Info in Skin
- RC-Setup (enable after reboot) enigma/neutrino
- Show Zap-Errors
- Display Spinner
- Maximal zap history entries
- Picon
- Use Picon
- Directory:
+ Swap Maneger
+ Daemons Setup
- Enable DropBear
- Enable SyslogD & KlogD
- Enable Inadyn
- Enable CronD
- Enable Samba
- Enable BusyBox HTTPD
- Enable OpenVPN
+ Added "Restart enigma2" on shutdown menu
+ DS NEWS - you will be all the time on the time
+ SmartScript - /usr/scripts/*_smartscript.sh
+ DS Multline 9 Turkoise by mimi74 exclusive only for DS, also a lot of 3D picons 13°, 19° and 28° only for DS images by mimi74 !!
Many thanks for his help. Also a lot of skins are downloadable via MENU->DS EXTRAS->ADDON MANAGMENT->DOWNLOAD ADDONS->SKINS
OR
LONG YELLOW -> RED -> ADDON MANAGMENT->DOWNLOAD ADDONS->SKINS
most of them was modded by mimi74.
Informations For Skin Makers:
<screen name="DSZapInfoBar" .... />
DS informations on skin:
<widget name="emuname" ... />
<widget name="ExpertTunerInfo" ... />
<widget name="ExpertEmuInfo" ... />
<widget name="decode_provider" ... />
<widget name="decode_card" ... />
<widget name="decode_int" ... />
<widget name="decode_net" ... />
<widget name="XXX_off" ... />
<widget name="XXX_ecm" ... />
<widget name="XXX_dec" ... />
In
<screen name="ChannelSelection"
added
<widget name="ServiceName" ... />
<widget name="EventName" ... />
<widget name="EventTime" ... />
<widget name="EventInfo" ... />
<screen name="EpgSelection" ... />
added
<widget name="date" ... />
<widget name="description" ... />
<widget name="video" ... />
<screen name="MovieSelection" ... />
added
<widget name="channel" ... />
A lot of thanks to
1) French by mimi74
2) Lithuanian by Adga
3) Spanish by titovich
4) Deutch by djeryk
5) Russian by enigma
for native language translations
It is up to the enduser to add them should he wish to use this image other
than with a legal subscription card.
The DS TEAM is NOT responsible for any unauthorised use of this firmware.
FIRMWARE.
Quando sarà rilasciata vedremo, per il momento dalle descrizioni e dagli screen promette bene
ciao
