Edg-nemesis 4.0
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
Anche per 500, 500+ e 600pvr.
Technical Infos:
* Enigma of: 10.03.2008
* Driver: 3.2
* OE , BB etc = 3.2
* Linux version 2.6.9
* GCC 3.4.4 Original CVS 1.1.0
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
* for use in flash or MB (via NFS, USB, HDD or CF)
* Date image 14.03.2008
Function Buttons:
* BLUE - Nemesis Panel
* BLUE > 1s - ECM INFO, EMM INFO e PID INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – xxx - CS Info
* GREEN – subservices
* GREEN > 1s – EPG Control Center
* RED - EPG list for active channel
* 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
Features:
* Add move skin, with skin preview
* Add clear zap playlist and playlist.epl
* Add enble/disable blu panel programms at boot
* Add new utlity panel
* Add some feature from new cvs
* Add support from vclf
* New class eChannelInfo with extended info
* Removed permanenettimeshift new class from CVS, is unstable
* Removed swapmager class from CVS, we have our own
* Fix bug in change between lite and full skin
* Fix 3 logo at boot in OE version
* Fix Epgmanager to manage scheduled download by new plugin SkyEpgdownloader 1.1
* Fix green button in video mode
* Minor bug fixed
* VLCF 1.8.0 included
* Implemented recording DVR by timer used with CIFS NFS ecc...,before recording to insert
a PVR mode buttons blue + yellow; the buttons are modified in: "help=video radio=rec tv=stop"
* Nemesis xxx Manager 4.0.0
* Nemesis Web-If xxx Manager
* Nemesis xxx Manager in italian & English
* Independent Start & Stop xxx / xxxxxxxxER
* Advanced Inadyn service configuration, with log manager
* Path manager panel
- Setting PVR Movie folder
- Setting Picon folder
* Iptables/Firewall Panel
- Start/Stop firewall
- Firewall configuration
- You can add/remove yours rules directly from panel
* Picon support included in Enigma
- You do install only Picon Images from blue Panel
- You can install Picon images in FLASH
* Syslog panel
- Start/Stop syslog daemon
- Syslog configuration
- Debugging enigma directly to syslog, no reboot needed!
* EPG Control Center Panel
- You can download and store, manually or scheduled, EPG data for:
- Enigma EPG Cache
- MvEPG
- WeekEPG
- EpGUI
- Please install the plugin only from EDG-Nemesis addons by blue panel
- You can find a guide in our forum
* Autostandby/autoshutdown (to manage a unwanted reboot)
* Advanced external programs control
* Can start / stop your own binary by panel (see /var/etc/sample_startup.sh)
* Can create your own autostart boot script (see /var/etc/sample_startup.sh)
* Support for gSUB via advanced external programs control
* Advanced User Script
* Can run script in kernel mode
* Autofs (see /etc/auto.net)
* Crond (see http://www.dreamboxonline.com/forums...11&postcount=6 for guide)
* Automount (see /var/script/mount.sh)
* Advanced System info (see /var/etc/script.xml)
* Advanced *** info (see /var/etc/xxxscript.xml)
* Parental control shortcut
* EDG-Nemesis news
* emm, ecm support
Display Function:
* New Skin Black-Matrix EDG Nemesis Version By Matrix10
* Skin Lite on Button OK press
* Display Snr, Agc, Ber
* Display video info
* Display frequency, polarization, symbol rate
* Display *** in use
* Display service providers name
* Display CaID, ProvID, PID, ecm time, hops
* Display Decoding Source (you can hide if you want)
* Display DC as IRDETO in OSD
* Display long date format
* Web-if and other graphics content modified (by Server)
Addons:
* Advanced addons Manager
* Internet addons download with Proxy support
* Manual addons install
* Remove installed addons
Misc:
* Support modules for openvpn (tun.ko) included
* Samba client
* NFS Client
No xxxs, No xxxs included
Regards:
- developper and betatester.
- MaxZ4 to support for WeekEPG
- Skin by Matrix10
- New Bootlogo 4.0 and graphics by Server
!!! ATTENZIONE - IMPORTANTE:
!!! QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' xxxLATORI, NE' INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
!!! EDG-NEMESIS NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE xxxS, NOR xxxLATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
