EDG-NEMESIS 4.4 for DM500, 500plus, 600pvr e 5620
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
EDG-NEMESIS
Technical Infos:
* Enigma of: 21.11.2008
* Linux version 2.6.9
* GCC 3.4.4
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
* for use in flash or MB (via NFS, HDD)
* Date image 24.12.2008
* OE 1.5
* Bitbake 1.6.8
Function Buttons:
* BLUE - Nemesis Panel
* BLUE > 1s - ECM INFO, EMM INFO e PID INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – EMU - CS Info
* GREEN – subservices
* GREEN > 1s – EPG Control Center
* RED - EPG list for active channel
* 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
Global News:
* Fix CVS for minor bugs about USB 2.0 port
* Nemesis Panel 4.4
* Cam Manager 4.4
* Fix green button in play mode
* Minor bug fix
New CVS feature:
* Add Plugin reorder
* Add Plugin rename
* Add listbox shortcut (0-9, red, green, yellow and blue)
* Add Permanent timeshift (beta)
* And lot of bug fix (see http://cvs.tuxbox.org for more info)
EPG Control Center:
* Hard recoded
* Integrated EPG loader directly form Sat, (Upgradable)
* Full support for EPGui, MVepg, WeekEPG and EPGFind.
* Manual EPG download
* Scheduled EPG download, via Enigma Timer list
* Select channel to download
* Reorder channel for EPGui via GUI interface
* Update EPG channel list, and channel name
* Full support for EPG Themes (Upgradable)
* Lot of EPG loader info
User Script:
* Partially recoded
* Add script cancel button
* Minor bug fix
Move var:
* Partially recoded
* Minor bug fix
Special Thanks to our developper MaxZ4 for EPG loader
Special Thanks to Lukkino for opentv source code
Regards:
- developper and betatester.
- Skin by Matrix10
- New Bootlogo 4.4 and graphics by Server
!!! ATTENZIONE - IMPORTANTE:
!!! QUESTO FIRMWARE NON CONTIENE ******, NE' EMULATORI, NE' INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
!!! EDG-NEMESIS NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
