EDG-NEMESIS 4.4 for DM7000
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
Technical Infos:
* Enigma of: 21.11.2008
* Linux version 2.6.9
* GCC 3.4.4
* Web Interface: 6.0.4-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
* for use in flash or MB (via NFS, USB, HDD or CF)
* Date image 24.12.2008
* OE 1.5
* Bitbake 1.6.8
Function Buttons:
* BLUE - Nemesis Panel
* BLUE > 1s - ECM INFO, EMM INFO e PID INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – EMU - CS Info
* GREEN – subservices
* GREEN > 1s – EPG Control Center
* RED - EPG list for active channel
* 2x RED - EPG style menu(Included epgui, MvEPG, WeekEPG you do install it to activate a function)
Global News:
* Fix CVS for minor bugs about USB 2.0 port
* Nemesis Panel 4.4
* Cam Manager 4.4
* Fix green button in play mode
* Minor bug fix
New CVS feature:
* Add Plugin reorder
* Add Plugin rename
* Add listbox shortcut (0-9, red, green, yellow and blue)
* Add Permanent timeshift (beta)
* And lot of bug fix (see http://cvs.tuxbox.org for more info)
EPG Control Center:
* Hard recoded
* Integrated EPG loader directly form Sat, (Upgradable)
* Full support for EPGui, MVepg, WeekEPG and EPGFind.
* Manual EPG download
* Scheduled EPG download, via Enigma Timer list
* Select channel to download
* Reorder channel for EPGui via GUI interface
* Update EPG channel list, and channel name
* Full support for EPG Themes (Upgradable)
* Lot of EPG loader info
User Script:
* Partially recoded
* Add script cancel button
* Minor bug fix
Move var:
* Partially recoded
* Minor bug fix
Special Thanks to our developper MaxZ4 for EPG loader
Special Thanks to Lukkino for opentv source code
Regards:
- developper and betatester.
- Skin by Matrix10
- New Bootlogo 4.4 and graphics by Server
!!! ATTENZIONE - IMPORTANTE:
!!! QUESTO FIRMWARE NON CONTIENE ******, NE' EMULATORI, NE' INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
!!! EDG-NEMESIS NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE ****, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG-NEMESIS IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE.
sarà che ormai sono troppo abituato ad usare immagini EDG per Enigma1,
ma anche questa mi sembra semplicemente PERFETTA!!!
Ciao :D
Ragazzi, ho bisogno di un po' di aiuto.. Qualunque combinazione usi per il card reader e sua controparte non mi aggiorna mai i diritti della card "azzurra"..
Spesso risolvo con una nottata nello skifobox acceso, ma a volte mi tocca telefonare (a pagamento) per risistemarla...
Poi vorrei sapere se c'è un file di configurazione per epgui che abbia la lista aggiornata dei canali cinema... sono stati rivoluzionati.
Aggiungo un grazie al team EDG-Nemesis... Il mio dreambox morirebbe senza le loro immagini :)
Se hai l'ultima, la 0002 , anche con la giusta combinazione non è detto che aggiorni.
Con la versione 4.0 non ho problemi a controllare gli aggiornamenti sky con il CCcaminfo,scheda 0001 mentre con la nemesis 4.4 mi scarica il plugin ma non lo riconosce,come posso fare?Grazie
devi tenere premuto il tasto giallo 1 secondo per visualizzare i plugin speciali.
No ho la 0001... che accoppiata devo usare?
Per quanto riguarda il config di Epgui dove devo cercare?
Ti consiglio mgcamd accoppiato a newCS per quella versione.
Lo farei, ma a quanto pare oggi è saltato "xario"... C'è una modifica da fare o è una cosa temporanea?
E' tutto ok, bisogna solo sostituire il vecchio url oppure editarlo mettendo addons al posto di xario.
Grazie Ang, prezioso come al solito... Ho messo Mg e newCs sulla 4.4... vediamo se funge...
Funge sicuramente perchè ho usato questa accoppiata fino alla settimana scorsa :)
