[FR + sped] Vendo Rotore "Megasat Diseqc Motor Nr. 1"
kernelfree
Digital-Forum Senior
1 Marzo 2015
Vendo questo rotore per parabole fino a 120cm
Usato meno di una settimana, perfettamente funzionante.
49€ Spedito
Pagamento: Paypal/Postepay
https://www.megasat.tv/en/produkte/megasat-diseqc-motor-no-1-2/
Dal sito del produttore
Switch easily between the satellites
With the DiSEqC motor No.1 you can switch between the satellite antenna without manually adjust the dish. There are no additional power or control cables required. The motor is controlled via the coaxial cable. The control is possible via any conventional satellite set-top box that supports the DiSEqC control 1.2 or 1.3 (USALS). The DiSEqC motor is suitable up to a dish size of 120 cm. 60 satellite positions can be stored, of which 26 are already preinstalled.
