Gemini 2.90 per 500
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
Appena uscita per il piccolino....
Gemini v2.90:
Technical Infos:
* Enigma of: 03.05.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.01
* Tuxtxt V1.98
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming, multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Downloading and installation of additional features via Internet from Gemini server
* System Info: Many extra box infos (for example harddisk-temperature or all Enigma-settings)
* Download of Gemini news in background
* JPEGs can be rotated and the EXIF tags can be displayed ( >=7000 )
* Support for OGG/Vorbis
* Random function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB port ( >=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted harddisk (only working if there is no harddisk inside,
mountpoint set to "/mnt/usb" and at least 3GB disk space)
* Extra Menu: Settings for many extras like Inadyn, HTTPD, EPG-Cache, swap-out of "/var" and many more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Backround pictures for Radio, MP3 and SCAN can be choosen via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via .../gemini_cal.conf)
* MVI's can be converted and tested (from JPG, BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabian
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be created for the filemenu (BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver(BP->Extras/Settings->Printer (LPD), FAQ can be found in the database
* Alarm clock with volume offset adjustable playing your own WAV-files.
* Display of current channel stream rates ( >=7000 )
New:
* Dreamnetcast based on the new xml
* cifs-1.42b
Fix:
* Attend CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL = Nummer des Cams)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
Gemini v2.90:
Technical Infos:
* Busybox 1.01
* Tuxtxt V1.98
Function Buttons:
Features:
* smbmount
* Backup function
New:
* cifs-1.42b
Fix:
* Attend CVS
Interfaces WebIF:
scusa ma a che si riferiscono quei link alla macchina ?
ciao
Codice:
[B]Gemini 2.9 MaxVar 	[/B]
- lzma kompresion
- VAR mit groesse 3MB
- busybox v1.01 von 20.1.2006
- dropbear 0.44 - generieren von rsa schlussel bei jedem restart nach /var/etc/dropbear/dropbear_rsa_host_key
- ssh client (dbclient) ssh root@192.168.x.x
- added script smbmount.sh fuer mount samba server
- added bootlogo GP
- die moeglichkeit ihre eigene Logo benutzen (/var/tuxbox/config/enigma/pictures/mylogo)
- vorbereitung fuer addon Midnight Commander 4.61
MD5 : FE39BFC9CF984A8109AD255D49590BA9 gemini290modifi_dm500.img
Size 4 947 968
Diese image ist nicht von mir. Sie ist von rozko aus C.S.F.
Viel spass!
La trovate su i-have
Ciauz!
