Gemini2 Project 1.10 7025
  • Creatore Discussione Creatore Discussione Neri73
Neri73
Membro dello Staff
Collaboratore
19 Gennaio 2003
Brescia
Gemini2 v1.10:
Technical Infos:
* Enigma vom: 02.03.2006
* GCC 3.4.4 Original CVS
* Busybox 1.01
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* RED - Record
* GREEN - Subservices
* TEXT - VideoTXT (Tuxtxt 1.96 for 7025 - Beta)
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via Internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
* Dreambox can be used as printserver
* Kernel modules can be reload separately
* Create your own Satellites.xml
* Support for CDROM/DVD, no matter if IDE or USB port
New:
* SWAP setup and start automatically
* HDPARM values for harddisk can be changed via menu
* SMB/CIFS modul
* Stream rates of current channel
Fix:
* VideoTXT
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Attention ! Your frontprocessor will be automatically updated. This update will take place on your own risk !
ciao :D :D
