Intelsat 907 @ 27.5°W
Dx qwer
Digital-Forum Senior
13 Gennaio 2009
Rastatt/Germany (48°52´N / 8°11´E)
Intelsat 907 @27,5°W
Hello,
3829 R 5787 3/4 NET RTP with 9dB and 89%. Feed from Sport TV (Portugal).
Portuguese Super Liga with Sporting Braga vs. FC Porto.
Edgar.
Hello,
German ZDF live feed on 3794 L 6111 3/4 chanel name Terra Brazil Encoder 3 (SID 1 / PMT 32 / V 308 / A 256 / PCR 8190) in MPEG-2 4:2:0 DVB-S QPSK.
Signal with 4,5dB and 40%.
Edgar.
Hello,
horse racing feed from Ippodromo di Chilivani (Italy) on 3861 L 4600 3/4 with channel name TELEIPPICA (SID 1 / PMT 4217 / V 4194 / A 54195 / PCR 4194 / ONID 177 / TID 176) in DVB-S MPEG-2 4:2:0.
Signal with 7,2dB and 61% on Openbox X-810 and 366cm.
Edgar.
Hello,
KNR in clear now on 3714 L 2914 7/8 with SID 1 / PMT 100 / V 4194 / A 4195 (left) / PCR 4194 / TID 1 / ONID 0.
KNR Radio with SID 1 / PMT 100 / A 4195 (right) / PCR 4194.
3874 L down now!
Signal with 10,2dB 96% on Openbox X810 and 366cm.
Edgar.
Hello,
some Radiochannels from Czech Republic on 4132 R 1517 3/4.
ONID 8192 / TID 4096.
Channel name Prague_Audios_1-8 with SID 1 / PMT 256 / A 4097-4100 (left-right) / PCR 4097-4100;
Channel name Prague_Audios_9-16 with SID 2 / PMT 257 / A 4101-4104 (left-right) / PCR 4101-4104 and
Channel name Prague_Audios_17-24 with SID 3 / PMT 258 / A 4105-4108 (left-right) / PCR 4105-4108.
Signal with 5,1dB and 47% on Openbox X-810 and 366cm.
Edgar.
Update
Hello,
NTA International now transmitted also in LZ from NE zone beam.
3898 L 2894 3/4 channel name NW program (SID 1 / PMT 32 / V 512 / A 650 / PCR 128 / ONID 1 / TID 1). Signal with 4,4dB and 32% on Openbox X-810 and 366cm.
PS: 3898 R signal active with 6,5dB and 50%.
Edgar.
Oggi mi sono voluto divertire a passare sotto la lente d'ingrandimento l'Intelsat 907 con il
seguente hardware:
Parabola primofuoco 310cm con corotor LNB banda C 15K, echostar AD-3600ip & AZBOXHD+, zona Toscana.
La Blindscan in banda C di questo satellite ha prodotto i seguenti risultati:
3714 L 2914 DVB-S/QPSK
KNR TV
3772 L 9999 DVB-S2/QPSK
KNR(SAT) stessa TV di cui sopra trasmessa con un ritardo di alcuni secondi
DR HD
DR RAJ
DR K
sono inoltre presenti tre canali con identificativo TGTV08, TGTV09, TGTV10 ma lo schermo rimane nero
Per gli appassionati di ippica nazionale ecco tre canali interessanti
3850 L 3702 DVB-S2/QPSK
UNIRE-SNAI-SAT2
3854 L 4133 DVB-S2/8PSK
BOLOGNA
3860 L 4599 DVB-S2/8PSK
MI TROTTO 1 (questo ha le caratteristiche di un feed, cambia spesso identificativo ed anche parametri di trasmissione)
3715 R 8447 DVB-S/QPSK
VC FOR ENC P1 (C-SPAN VOA)
3764 R 24447 DVB-S/QPSK
CHANNEL#1 (C-SPAN VOA)
CH.80-AOR9-10, AOR11-12
CH.20 -MBN QUAD VIDEO
CH.15-ALHURRA (H.264)
3841 R 10848 DVB-S/QPSK
RTPi EUROPA
RTP AFRICA
RTPi ASIA
3936 R 4549 DVB-S/QPSK
RTG GUINEA (l'AzboxHD+ non memorizza nessun identificativo)
4014 R 2820 DVB-S2/QPSK
RCS MAP TABLE (0x3C) Schermo nero
4040 R 5999 DVB-S2/QPSK
In fase di blindscan il transponder viene agganciato, ci sono picchi sulla barra della qualità del segnale da 0 a 70% ma non si memorizza nulla
4048 R 6999 DVB-S/QPSK
RECORD AFRICA
4134 R 4099 DVB-S/QPSK
In fase di blindscan il transponder viene agganciato, ma non riesce poi a memorizzare nessun canale
4142 R 2893 DVB-S/QPSK
NW PROGRAM (NTA INTERNATIONAL)
......da altre zone d'Italia o con altri decoder si riuscirà a ricevere qualcos'altro? :eusa_think: ......adesso tocca a voi :eusa_whistle:
Saluti.
PantaSat
:eusa_think: ...dalle mie parti come ricezione non cambia praticamente nulla rispetto a Pantasat, se non un piccolo margine in più sui segnali in generale (confrontando le barre della AZBox), e la ricezione invece di tre canali (identificativo IBB HOTBIRD, VOA TV) sulla frequenza 4134 R SR 4099 FEC 3/4:
Effettivamente questa frequenza mi risulta più ostica, l'unico verso per agganciarla è quella di collegare il cavo direttamente all'Azbox
D'altra parte dopo quasi 50 mt di cavo, lo switch banda-KU banda-C 0/12 V, il segnale che da questo entra nell'Echostar e da questo riesce fuori per andare in un altro divisore di segnale e da questo all'Azbox....mi viene da domandarmi come riesco a vedere qualcosa:icon_rolleyes: :icon_rolleyes: .
Purtroppo sono i compromessi per non stare continuamente a collegare e scollegare cavi....l'iportante è sapere però che, se ce ne fosse bisogno....collegando di qui e staccando di là, magari facendo un nodo al cavo...quel determinato transponder si riesca a vedere :D
PantaSat
intruder800 ha scritto:
:D quanto sembrava grande la mia 180...............................cè poco da fare contro tre metri de dischetto:crybaby2:
beh, vabbè, non ci lamentiamo con le 180.........
io con la mia 180 non riesco a prendere NTA Int altrimenti tutto entra...
non ci lamentiamo.....:D
