KSF-S700H2 PVR Fully DVB-S2 (High Definition Satellite)
moikano2
Digital-Forum Junior Plus
8 Gennaio 2004
Pescara
- 2 Tuners PVR
- Compliant MPEG-4/H.264 & Fully DVB-S2 (High Definition)
- Simultaneous 6 Record and 1 playback
- Simultaneous Time-shifting & Dual Recording
- Dual Decoding from Live stream or Recorded stream (PIP: Picture-in-Picture)
- MP3(MPEG-1 Layer-3) Transfer & Play from Internet via USB 2.0
- RGB and YPbPr and S-Video and CVBS and HDMI video Outputs
- Powerful & Stable Trick mode
- USB 2.0 support for Fast transfer via PC
Main Processor 32-bit superscalar RISC CPU
Modulation QPSK, 8PSK
HDD Size 5.25 Inch of 80GB and more
Multistandard Demodulation DVB-S2 = QPSK,8PSK
Serial IF USB 2.0, RS232C of D-SUB 9
TUNNER & CHANNEL
2 Tuner Decoding & Recording [or Decoding]
RF INPUT RANGE 950MHz ~ 2150MHz
DYNAMMIC RANGE -65dBm ~ -25dBm
INPUT CONNECTOR F-type, Female
INPUT IMPEDANCE 75ohm
Symbol rate DVB-S2=Maximum QPSK 36 MSPS @ 108MHz fsamp
Maximum 8PSK 30 MSPS @ 108MHz fsamp
Multistandard decoding LDPC and BCH (1/4,1/3,3/4,5/6,6/7,7/8)
MPEG TS A/V DECODING
Transport Stream MPEG-4/H.264 HP@L4.0 1920x1080 interface@50Hz
Profile Level MPEG-2 MP@HL, MPEG-4/AVC MP@L4
Input Rate Max. 81Mbit/s
Aspect Ratio 4:3, 16:9, Letter Box
Video Resolution 1920*1080i, 1280*720p, 720*576i
Audio Decoding Dolby AAC, AC-3, MPEG-1 layers 1,2 and 3(MP3)
Audio Mode Mono / Left / Right / Stereo
A/V & DATA OUTPUT
Component Y/Pb/Pr 1 set (RCA Type)
RGB D-Sub 15 pin 1 Connector
CVBS 1 Connector (RCA Type)
S-Video 1 Connector
Dolby Digital 5.1 CH 1 Optical
Stereo L/R 1/1 Connector (RCA Type)
HDMI 1 Connector
DATA Port RS 232C Transfer rate 115Kbps, 9 pin D-Sub Type
SYSTEM RESOURCES
Flash Memory Max. 8MByte (Optional)
Program DRAM Max. 128MByte (Optional)
EEPROM Max. 32KByte (Optional)
POWER SUPPLY
Input Voltage AC 90 to 250V, 50/60Hz
Power Consumption MAX. 30W
Protection Separate Internal Fuse
Type SMPS
Safety & EMI For Australian Regulation
eh ragà, è moolto tempo che è sul loro sito...
non se ne sa tanto per ora, se non che dovrebbe essere disponibile da qualche parte in europa (svizzera...?) poco prima di natale
se riesco a saperne di più metto qualcosa come anticpazione sul portale
@POWERMAX ciao.Ho inserito questa news pur sapendo che era da molto tempo presente sul sito Kaon.L ho fatto per due motivi 1)perche ancora nessuno lo faceva 2)perche penso che potrebbe essere un ottima alternativa allo Humax il quale mi ha un pò deluso.Saluti
E hai fatto benissimo a segnalarlo..:icon_wink:
