LS E2 Image git 20091210
Branch = Experimental
Distro-Opendreambox (GIT) = 1.5
dm8000
Enigma2 = 20091210 (mod by Linsat Team)
Plugins = 20091210
DRIVERS = 20091209
Secondstage 76-r0
Traduzione LS 20091209 (Spaeleus)
Satellites.xml 20091208 (Reinh@rd)
Megalight v4.1 (Eagle: fix crash with subservices, add support Mytube)
+ Per TUTTI gli aggiornamenti in tempo reale del CVS vedere QUI
Alcuni changelog release ufficiali DMM dall'uscita dell'ultima LS ad OGGI:
* softwaremanager now replaces old softwareupdate
* new webinterface
* internal changes for better media playback support
* skin engine improvements
* add possibility to set a general ac3/pcm delay in av setup
* skip/seek forward/backward improvements for new recordings
* improved tuner timeout handling for faster service searching
* fix occasionally invisible rotor turning icon
* rds text for services with radiotext on different pids
* hotplug fixes/improvements
* more texts are now translatable/translated
* cleanupwizard added (automatically starts if there is very little flash space available)
* add possibility to change service in single service epglist with < > buttons
* show virtualkeyboard in more screens
* new plugins (installable via software manager)
* fixed crash in manual scan when no tuner was configured (bug #295)
* fixed wrong image and enigma2 information in about screen (bug #260)
* added arabic to encoding.conf (this fixes epg on some arabic transponders)
* fixed some and added missing translations
* added missing changes for faster service scan to tuner drivers (bug #278)
* improved stv0288 based alps-bsbe1 c01a tuner driver
* fixed WLAN to work with SSIDs that contain spaces (bug #175)
* fixed potential webinterface startup problem
* changed default oled standy brightness
* added support for new oled display
* some fast winding and slowmotion fixes
* fix strange audio noise on skip fast forward/backward (2nd try)
* improved position after seek/play transition a bit (2nd try)
* improved playback engine (lower cpu load)
* fix prerolling after buffer flush a bit
* disable some pcr workarounds when a tv services is running
* ignore audio pause request in live mode
* small fix for channels with very high pcr - stc difference (this fixes some hotbird services on 12360H)
* fix sometimes visible trash on scart output in soft standby
* fix oled brightness control a little bit and disable oled completely on lowest level
* fix not correctly working deinterlacer
* fixed audio-/video buffer empty detection
* networkbrowser
* buffer empty detection changes for /dev/dvb/.../videoX, audio0 and /dev/pvr
* more acurate timestamp queries (fixes seeking in some conditions)
* video freeze fixes (this fixes black picture in timeshift start)
* faster audio/video resync in some playback conditions
* some others and others...
D'ora in poi Vi risparmieremo l'elenco caratteristiche delle img LS che potete vedere nei vecchi thread, ci limitiamo solo a ricordare chi ha direttamente o indirettamente contribuito:
Ronaldd per i sorgenti del suo "Emumanager" e l' "expert-tuner infobar"
Lukkino per LoadEPG OpenTv e la traduzione del dizionario
Skaman per CrossEPG
PLi team per l'indicazione della posizione orbitale nello skin, per il menu telecomando e per il "BitrateViewer"
AliAbdul per lo "Scriptexecuter", per il "CCcaminfo" e per il "Numero canale nei bouquet"
dreg per il tuxcom E2
Reinh@rd per il satellites.xml aggiornato
Vali per le info frequenza avanzate
ritZmo e oozoon per il PiPzap
Ferbius e Power per gli skins alternativi
dm8000
Plugins = 20091210
DRIVERS = 20091209
Secondstage 76-r0
* new webinterface
* networkbrowser
Skaman per CrossEPG
ATTENZIONE:
I FIRMWARES IN OGGETTO NON CONTENGONO CHIAVI O EMULATORI DI NESSUN GENERE
LINSAT.NET NON E' RESPONSABILE IN NESSUN CASO DELL'USO CHE GLI UTENTI FARANNO DI QUESTI PROGRAMMI.
