LS-Enigma2 Images OE1.6 #20120211
JEEG72
Membro dello Staff
Moderatore
26 Maggio 2003
Varesotto
LS E2 Images OE1.6 #2012-02-11
dm500hd
dm7020hd
dm8000
Branch = 3.2
Distro-Opendreambox (GIT) = OE1.6
Kernel = 2.6.18-7.3
Enigma2 = 20120210 (mod by Linsat Team)
Plugins = 20120211
Dvb-modules = 20120209
Secondstage #84
Secondstage #85 (only dm7020hd)
satellites.xml 20120203
pwr skin 6.20
ValiHD skin 3.3 mod
EpgLoader r1.0-r1
ItalySatDTT v1.0
CrossEpg 0.6.2 patch by neoen
enigma2 rel3.2 20111110 -> rel3.2 20120210
- fixed blindscan for non universal LNBs
- fixed shared pvr channel allocate
- fixed sporadic crash on recording stop
- fixed picture errors on loopthrough tuner close
- removed PiP activation from context menu in radio mode with permanent service list
- various mount manager optimizations and fixes, added usb/cf support, also renamed to "storage devices"
- hotplug support is working again (for not explicitly mounted storage devices)
- use "auto" to mount the storage devices to allow non-EXT3 filesystems again
dvb-modules 20111109 -> 20120209
- fixed strange aliasing noise on PCM Playback with needed upsampling
- finally fixed hybrid DVB-C/-T Tuner 5V output for active antennas
- don't fallback to DVI when the HDMI EDID was not readable
(this fixes some HDMI audio/video problems)
- update to new writenfi tool with dm7020hd support
- cxd1981(hybrid DVB-C/-T) increased max. frequency to 900Mhz
- cxd1981(hybrid DVB-T) fixed ineffective 5V for active antennas after mode change
- bcm4505/6 improved receiption sensitivity (fixes problems with small dishes since blindscan support)
dm500hd,dm800se,dm7020hd:
fixed audio volume boost on alsa playback
dm7020hd:
- fixed frequently "error code 0x18006" messages on bootup
- added CI support for high bitrate transponders
secondstage-loader #85 (only dm7020hd)
- fixed ineffective front usb port
- fixed wrong frontpanel key handling
- prepare for new kernel versions
