MPlayer & vid?
Lost1
29 Novembre 2007
Ciao!
Il USB-Responsabile usa MPlayer per giocare le lime del .vid.
Qualcuno sa compilarlo MPlayer in modo da può giocare le lime del .vid?
Un altro qestion che lo interessa: Il X12 inoltre registra tutti i flussi audio delle scanalature scrambled? È il convertito possibile la lima del .vid e mantiene tutti i flussi audio?
Hello!
The USB-Manager uses MPlayer to play the .vid files.
Does anybody know how to compile MPlayer so it can play the .vid files?
Another qestion that interests me:
Does the X12 also record all audio streams of scrambled channels? Is possible to convert the .vid file and retain all audio streams?
Thanks
The files with .vid extension produced by the X-12 receiver are dirty.
You can use the program TSConvert vers. 1.5 to translate .vid files into .ts.
This is the page where you can find it: http://www.digital-sat.it/mod_downloads.php?id=22
I files con estensione .vid prodotti dal ricevitore X-12 non sono altro che .ts sporchi. Puoi usare il programma TSConvert vers. 1.5 per tradurre i files .vid nel formato .ts. La pagina dove puoi trovare il download è questa: http://www.digital-sat.it/mod_downloads.php?id=22
Hi!
Thanks ALEVIA for your answer.
I tested TSConvert v1.5 but it also descrambles only one audio stream. On the receiver it's possible to change the audio streams, so they get recorded. It should be possible to descramble all audio streams on PC. With non encrypted channels it's possible.
TSConvert v1.5 is very slow when working with encrypted channels. I prefer TSConvert v1.0 from SAB. It's faster and provides the same results.
With my old receiver I could use "Offline Descrambler" to descramble all audio stream. Unfortunately it's not working here.
Noone knows how to compile/customize MPlayer so it plays the .vid files? I would like to be able to watch the .vid files from my old Xbox with XBMC.
Thanks, kind regards
Hi!
ALEVIA Grazie per la risposta.
Ho testato TSConvert v1.5, ma anche descrambles un solo flusso audio. Il ricevitore è possibile cambiare la flussi audio, in modo da ottenere registrati. Dovrebbe essere possibile descramble tutti i flussi audio su PC. Con canali criptati non è possibile.
TSConvert v1.5 è molto lenta quando si lavora con i canali criptati. Io preferisco TSConvert v1.0 da SAB. E 'più veloce e fornisce gli stessi risultati.
Con il mio vecchio ricevitore ho potuto utilizzare "offline Descrambler" a tutti i descramble flusso audio. Purtroppo non è lavorare qui.
Nessuno sa come compilare / MPlayer personalizzare in modo che svolge l'. Vid file? Vorrei essere in grado di guardare l'. Vid file dal mio vecchio Xbox con XBMC.
Grazie, cordiali saluti
I use JsVid2Ts. to vid-> ts
So you have a ts file that retains all the audio tracks.
By the way I burn directly the ts files with dvr studio to obtain
a dvd with all the audio tracks.
Bye Marrong
Thank you marrong!
But unfortunately this works only with FTA recordings.
Regards
