Multiboot 8.4B by thowi
Ferbius
Digital-Forum Silver Master
2 Marzo 2002
Multiboot for Dreambox 7025 Version 8.4B by thowi from 8. December 2006
Thanks to noggie and grblmpfh for the basic research in this
area and others that contributed usefull stuff and feedback.
Thanks to 3c5x9 for creating the first python coding in enigma2.
Thanks to noggie and tmbinc for the nfi Image copy program examples.
Thanks for OoZooN for hosting the Multiboot nfi Image Download Center.
Thanks to Reichi for converting the Multiboot plugin icon.
Thanks to noggie for the Linuxkernelbuild with USB drivers included.
Thanks to Lowbytes and citrone for the German translation
Thanks to oldprogrammer for the Italian translation
Multiboot is FREEWARE, but this means also that nobody takes
responsibility if anything goes wrong
Release infos
7.0B add Multilanguage Support for script
non USB partitions now have rootdelay=0 in autorun.bat
4 Dummies installation now simply installs all nfi images found
and fills up with flash copies
7.1B multilanguage Version with English, German and Italian
7.2B copy N 0 is now supported (dumping Flash to nfi image)
multiboot kit is now downloadable from w**.oozoon.de
ipkg installation option now available (to prevent
/boot not found errors). Multiboot is now compatible to OE 1.4
Images which are having an extra /tmp filesystem
8.1B copy V is now gone for getting USB support - Kernel check
will be done during boot selection and USB Kernel is
used from Flash or /MB_Images/vmlinux.gzU
If you have an Image in Flash with USB Drivers linked
into the kernel (like latest OoZooN CVS Image) Multiboot
on USB Stick now works almost (!) as easy as with CF Card.
But be aware that still for Harddisk and USB only on every
change of the Bootimage the Flash of /boot is updated !
Added direct Image selector to Image copy menu to avoid
typing name with remote control when copying from image files.
Besides ipk installation multiboot now also supports extracting
any tar.bz2 file from /var/tmp or /MB_Images.
mkdosfs 2.11 is now included at /media/mb, maybe it fixes
the FAT problem which needed PC Format of CF card.
copy S to Flash was removed from menu interface, and also
the enable options which erase Harddisk !
info now shows only partition infos, for list of
images and kits use new list option in the download menu.
8.3B some bugfixes and rar and tar.gz support added
copy A is back to menu interface
use Mainloop for Enigma restart from Menu Interface
quick fix for OE 1.4 copy problems
remove Turbo Modus switching from menu interface
fix some small settings copy bugs
8.4B add fillsize of Partition to multiboot.sh info
add enable vtp option for ONLY moving /var /tmp and Plugins/Extensions
on CF card = lots of Place in Flash, but NO Multiboot !
hopefully fix copy 0 (Multiboot Partition to Flash copy)
add enable f (switch to Flash bootpartition only
= Flashwizzard style)
add enable n (switch to Multiboot bootpartitione only
= Classic Multiboot)
change default Imagesize from 80MB to 78MB to prevent Problems
on 256MB devices
Lo trovate -->> PORTALE
