kilkenny1975
- 12 Marzo 2006
Ciao,
ho una scheda DTT USB della MCFTec, con il software propietario riesco a captare una marea di programmi TV ( anche con la sua antenna portatile ) ma quando provo con Mytheatre il software sembra riconoscere la scheda ( in basso a sinistra appare una scritta in rosso che dice: C&E DVB-T Device T5 )
ma quando provo a fare una scansione dei canali questo è il risultato.. NULLA
1tp - Ter(500) 178750 8MHz: Nothing found.
2tp - Ter(500) 186750 8MHz: Nothing found.
3tp - Ter(500) 194750 8MHz: Nothing found.
4tp - Ter(500) 202750 8MHz: Nothing found.
5tp - Ter(500) 210750 8MHz: Nothing found.
6tp - Ter(500) 218750 8MHz: Nothing found.
7tp - Ter(500) 474000 8MHz: Nothing found.
8tp - Ter(500) 482000 8MHz: Nothing found.
9tp - Ter(500) 490000 8MHz: Nothing found.
10tp - Ter(500) 498000 8MHz: Nothing found.
11tp - Ter(500) 506000 8MHz: Nothing found.
12tp - Ter(500) 514000 8MHz: Nothing found.
13tp - Ter(500) 522000 8MHz: Nothing found.
14tp - Ter(500) 530000 8MHz: Nothing found.
15tp - Ter(500) 538000 8MHz: Nothing found.
16tp - Ter(500) 546000 8MHz: Nothing found.
17tp - Ter(500) 554000 8MHz: Nothing found.
18tp - Ter(500) 562000 8MHz: Nothing found.
19tp - Ter(500) 570000 8MHz: Nothing found.
20tp - Ter(500) 578000 8MHz: Nothing found.
21tp - Ter(500) 586000 8MHz: Nothing found.
22tp - Ter(500) 594000 8MHz: Nothing found.
23tp - Ter(500) 602000 8MHz: Nothing found.
24tp - Ter(500) 610000 8MHz: Nothing found.
25tp - Ter(500) 618000 8MHz: Nothing found.
26tp - Ter(500) 626000 8MHz: Nothing found.
27tp - Ter(500) 634000 8MHz: Nothing found.
28tp - Ter(500) 642000 8MHz: Nothing found.
29tp - Ter(500) 650000 8MHz: Nothing found.
30tp - Ter(500) 658000 8MHz: Nothing found.
31tp - Ter(500) 666000 8MHz: Nothing found.
32tp - Ter(500) 674000 8MHz: Nothing found.
33tp - Ter(500) 682000 8MHz: Nothing found.
34tp - Ter(500) 690000 8MHz: Nothing found.
35tp - Ter(500) 698000 8MHz: Nothing found.
36tp - Ter(500) 706000 8MHz: Nothing found.
37tp - Ter(500) 714000 8MHz: Nothing found.
38tp - Ter(500) 722000 8MHz: Nothing found.
39tp - Ter(500) 730000 8MHz: Nothing found.
40tp - Ter(500) 738000 8MHz: Nothing found.
41tp - Ter(500) 746000 8MHz: Nothing found.
42tp - Ter(500) 754000 8MHz: Nothing found.
43tp - Ter(500) 762000 8MHz: Nothing found.
44tp - Ter(500) 770000 8MHz: Nothing found.
45tp - Ter(500) 778000 8MHz: Nothing found.
46tp - Ter(500) 786000 8MHz: Nothing found.
47tp - Ter(500) 794000 8MHz: Nothing found.
48tp - Ter(500) 802000 8MHz: Nothing found.
49tp - Ter(500) 810000 8MHz: Nothing found.
50tp - Ter(500) 818000 8MHz: Nothing found.
51tp - Ter(500) 826000 8MHz: Nothing found.
52tp - Ter(500) 834000 8MHz: Nothing found.
53tp - Ter(500) 842000 8MHz: Nothing found.
54tp - Ter(500) 850000 8MHz: Nothing found.
55tp - Ter(500) 858000 8MHz: Nothing found.
Qualcuno mi sa dare una dritta ?
Ho un bel po di banda e volevo mandare on-line un po di TV in chiaro
