Nabilosat Darkstar DM7020
Hi Nabilo PPL.
Here is another one great suprise for all.
Nabilosat Darkstar 7020 !!!!!!!!!!!
This is a special version with experimental skin extensions.
What is new in this version?
- OE 1.4
- Latest CVS
- Added nfs server (to share hdd between dreamboxes)
- Added Network Control Center (you can easly enable/disable the services you are using. Disabling not used services will cause a better network performance).
- Added new pixmaps listboxes and new button objects.
- Added extended skin system for image panels.
- Fixed server connections
- Fixed webif css
and more...
In this Nabilosat image version many panels code have been moved to the skin.
In this way the skin can be more personalized and have panels in their own style.
Many pixmaps have been added too.
Warning: You can use only Skins for Nabilosat Darkstar on this image.
Special thanks to Vali for the wonderful skin.
Special thanks to Army for the new wonderful bootlogos.
Thanks to all the beta-testers.
Special thanks to all the skinners Army Vali Matrix10 and Porto for the support in graphics additions and improvements.
No Keys, No Emu Inside.
