Nabilosat Enigma2 Black Hole - DM7025 v0.3
JEEG72
Membro dello Staff
Moderatore
26 Maggio 2003
Varesotto
What is new in this version 0.3
Enigma2 Integrated SKY Italy EPG
This version of Nabilosat Black Hole will bring back to life the EPG for all the Italian channels included in the Sky Italy
package, along with Rai and Mediaset channels. To download the EPG, you need to zap to the channel MarcoPolo and wait till
the countdown is over. Should you wish to hide the popup window, simply press the OK button, however do not zap to another
channel during the download. EPG settings can be customized: press the Blue button 2 times, select the Nabilo EPG settins
option and press the OK button. The current settings will be displayed. To modify the current settings, press the RED button.
Here you can
Enable/Disable the EPG download
Enable/Disable the automatic EPG download
Schedule the download timing
Select the command to execute upon download completion (nothing, standby, deepstandby)
Select the media where to save the EPG file
Press the RED button again to save your preferences.
The automatic download will be completed even with your DM in standby mode.
Once the EPG is available on your DM, you can browse the events with various options
Press the INFO button and the YELLOW button to browse the current channel EPG.
Press the INFO button and the BLUE button to access the MULTI EPG option. Move forward/backward with BLUE/YELLOW
button.
Long press the BLUE button and select Graphical Multi EPG to have an EPG framed view.​
Nabilo Mount Wizard
The Nabilo Mount Wizard will help you mount and share your PC, Dreambox or Nas Hard Disk with a simple userfriendly
procedure. http://www.nabilosat.info/forum/showthread.php?t=54256
Enigma2 version date: 29/06/08
Openvpn Kernel module support included. Openvpn fully embedded in graphic interface.
Graphic MultiEPG included
Default Skin : Army Niro
Alternative Skin : Updated Porto Invader
Web Interface : Updated Nabilosat Web Interface
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button Blue-Long-Push = Extensions
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server​
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, AGC, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel​
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
About​
Save
Select/Start/Restart EMU​
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics​
Scripts
Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, DeepDiver
Credits
E2 Sky Epg loader integration by MaxZ4.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
Guida al dowload della EPG di Sky Italia con Nabilosat Black Hole v0.3
L'immagine Nabilosat Enigma2 Black Hole v0.3, sia per DM7025 che per DM800, include la funzione per il download della EPG di tutti i canali di Sky Italia, oltre che dei canali RAI e MEDIASET. Il download avviene tramite una funzione integrata nella immagine stessa e non richiede plugin aggiuntivi. Anche la consultazione della EPG non richiede altri plugins extra.
Questa semplice guida indica i passi necessari sia per poter effettuare il download, manuale ed automatico, della EPG di Sky Italia che per poterla consultare.
Il download fornira' la EPG di circa 300 canali, e per ognuno di essi scarica gli eventi, inclusi titoli e descrizioni, per 1 settimana. Per questa ragione, si raccomanda l'uso dello swap file. Per attivare lo swap file, e' necessario premere il pulsante BLU 2 volte e selezionare Swap File Settings. Creare ed attivare lo swap file. Nel seguente screenshot, lo swap file e' attivo su CF
Dopo aver creato ed attivato lo swap file, per poter effettuare il download della EPG, basta sintonizzarsi sul canale MARCOPOLO. Un messaggio comparira' sullo schermo, come nel seguente screenshot. Attendere il termine del conto alla rovescia, senza cambiare canale.
Al termine del download la EPG e' integrata in Enigma2, e puo' essere consultata in diversi modi.
Ad esempio, per leggere la EPG del canale corrente, basta premere il pulsante INFO e poi il pulsante GIALLO.
Invece, premendo il pulsante INFO, seguito dal pulsante BLU, si accede alla MULTI EPG, che fornisce gli eventi del bouquet corrente. E' possibile controllare gli eventi successivi/precedenti premendo i pulsanti BLU/GIALLO
Infine, premendo e tenendo premuto il pulsante BLU, si accede al menu delle estensioni, dove e' possibile selezionare GRAPHICAL MULTI EPG
Per poter usufruire del comodo download automatico, e' sufficiente premere il pulsante BLU 2 volte, selezionare Nabilo E2 EPG e premere OK.
Verranno mostrate le preferenze attuali. Per modificarle, basta premere il pulsante ROSSO di SETUP.
Premendo il pulsante ROSSO e' si puo' modificare la configurazione.
In questa pagina infatti e' possibile:
- abilitare/disabilitare il download della EPG.
- abilitare/disabiitare il download automatico della EPG
- selezionare l'orario in cui il download automatico verra' effettuato
- selezionare il comando da eseguire al termine del download (nothing,standby,deepstandby)
- selezionare il tipo di media su cui salvare la EPG ( USB, CF, HDD )
Dopo aver premuto il pulsante ROSSO per salvare la configurazione, sara' richiesto di premere OK al fine di riavviare Enigma2 ed attivare la configurazione. Il download automatico aggiunge un timer giornaliero. E' importante che questo timer non venga editato o cancellato.
Buona EPG a tutti :)
Ottima guida, Nabilo è sempre stato uno dei migliori Team , queste immagini lo dimostrano... grazie Black :D;).
Saluti
