Nabilosat Enigma2 Black Hole - DM800 v0.10
lorenzo64
16 Ottobre 2002
What is new in this version 0.10 ?
Nabilosat Black Hole socket system creates a communication with Enigma 2 for the management of the EMU restart and Nabilosat API's​
EMU Management: the Black Hole Socket system allows EMU's to be run externally to Enigma2.This solution offers a better EMU performance. As an example, when you start the EMU, the spinner will not display​
NEW EPG Panel introducing new features for the control of EPG​
Download Now reset EPG download timer and immediately start a download​
NEW EPG Provide list available in EPG main panel​
EPG settings global setting for all provider, and single provider settings​
EPG Cron for each single provider​
EPG search buttons enable/disable the epg search buttons​
Panic Button quickly zap to a fixed channel and clear zap history​
Analogue Clock: the analogue clock and gauge needles have been rewritten to offer a clear reading​
Increased Performance: all Nabilosat panel have been recoded to offer better performance​
System Pop Ups: using Nabilosat socket system now​
Extra Info Bar: new system​
Manual Install IPK: added Enigma2 console​
CCcam Info now available directly from the Green Panel (1x Green + 1x Red )​
New:
Nabilosat Black Hole System: this system represents a new approach to the communications exchange between the image core, the external environment and Enigma2. Making the image faster and more efficient.The Nabilosat Black Hole Socket allows also the following:
1) Introduction of Nabilosat Black Hole API
2) EMU and Application enhanced management, as they run externally to Enigma2
The following diagram represents the communication flow​
What are the benefits ? When you start or restart your default EMU, Enigma2 will be busy at controlling this process, until it is started and initialized. As Enigma2 is busy with this process, the spinner will display. With Nabilosat Black Hole System, when you start/restart your default EMU, Enigma2 will only send a short signal to the Socket, and this Socket will be responsible for starting the EMU. Therefore, Enigma2 is free to keep running, and the spinner will not display. Additionally, the EMU will also be more efficient as it does not depend from Enigma2.
Another benefit is represented by the possibility to send command to Enigma2 from the Linux shell, or from a schedule custom script. This system is the new Nabilosat Black Hole API.​
New:
Nabilosat API: you can now start a Telnet or SSH session and send a command to execute any of the following available API's:
- Restart EMU
- Restart E2
- Reboot DM
- Standby
- Shutdown
To launch each of the available API's, start a Telnet or SSH session, and type the following commands:
Nabilocmd restartemu
Nabilocmd restartenigma2
Nabilocmd standby
Nabilocmd reboot
Nabilocmd shutdown
Each API can also be executed manually via Telnet or SSH. It can also be included in your custom script. It can be executed automatically and regularly with the new Nabilosat Black Hole Cron Manager, at a set time, and every day.
Nabilosat API are also useful if your DM hangs. Instead of choosing to Power OFF, you can now simply restart Enigma2 or reboot using the required API.​
New:
Nabilosat Black Hole Cron Manager: you can now schedule recurring standard events ( restart e2, reboot, stand by, shutdown, restart emu ) or your custom commands, and execute them automatically. The scheduling of standard events will automatically execute Nabilosat Enigma2 API's. The custom command feature gives you the option to run any script of your choice automatically and at your set time​
New
Nabilosat Black EPG Panel: this new panel allows you to have full control of EPG for the following providers
Sky IT
Sky UK
Cyfra+
Csat
Canal Digitaal
Digital+
You can now schedule an automatic download for each of these providers. You can also perform an immediate download with the new Download Now feature.
You ca now enable/disable the EPG Search button, through the Gloabl Settings panel​
New
Nabilosat Black Hole Panic Button: this new feature, if enabled, will map your 0 key to zap to the first channel of your first bouquet, and clear the history​
New
Nabilosat CCcam Switch: this plugin has been recoded for HD skin and added by default to the image​
Enigma2 CVS date
29 April 2009 2.6 experimental​
Drivers date
30 April 2009​
Second Stage #72-r0
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button 1x Blue + 1x Yellow = New System Monitor Panel
Button Blue-Long-Push = Extensions
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server​
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Nabilo Panels features
1) Blue Panel
Setup
Black Hole EPG Panel
OSD Settings
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel​
CCcam Info
Service Info
Enigma2 Settings
About
Memory
Space
CPU
Process​
Save
Select/Start/Restart EMU​
2) Green Panel
CCcam Info
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics​
Scripts
Many thanks to the Beta Testers Team
Credits
E2 Sky Epg loader integration by MaxZ4.
Matrix10 for the new Black Shadow II skin.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
WARNING.
Nabilosat Team highly reccomends to install this image to flash. It will be perform at its best, and you will fully enjoy all the features. Else, if you install it to multiboot, you must install the Nabilosat Pure Flash DM 800 dated 02 May 2009.
ma che è una gara a chi copia di + il post?
la cosa bella è che nessuno ha cercato neanke di dare una spiegazione propria a quello che è stato aggiunto..
:eusa_wall:
A cosa ti riferisci?
Quale spiegazione vuoi visto che è tutto scritto?
beh io nn ne ho di certo bisogno..!!
solo che in tutti i forum c'è sempre lo stesso post..( e qui anche due..forse è vero che nessuno legge i topic :D :D :D ).
almeno qualche utente + esperto che metta un post di proprio pugno..invece di fare i post identici in 64 forum diversi..:D :D
Ma perchè scusa quando escono le altre immagini come vengono postate le novità? Mi pare che tutti mettano il readme accluso alle immagini stesse, poi certo se qualcuno necessità di ulteriori spiegazioni basta chiedere ma quì mi pare che il tutto sia molto chiaro. Se poi invece vai cercando la polemica sterile allora hai sbagliato posto..........
e per cosa ? sai che me ne frega fare polemica qui.
Il discorso è che io se faccio una segnalazione..la faccio dopo averla provata e dopo il primo topic (che è copiato)..cerco di scriver le sensazioni che si hanno nell'utilizzo e dare una spiegazione (semplicistica ) a gente che può capirci meglio ed essere interessato maggiormente a un modello in particolare..
E' chiaro che chi ha postato la news ha provato l'immagine e anche in maniera approfondita te lo posso garantire.
E nel caso specifico di quali sensazioni vogliamo parlare? Della qualità video che già sappiamo che sui canali SD non è il top? Oppure delle vere novità? Cioè il fatto che adesso le immagini Nabilosat Enigma2 hanno le proprie API che consentono l'invio di comandi per il riavvio di E2? E che sensazioni vuoi che ti offra su questa news? Oppure parliamo del Cron Manager inserito nel blu panel, o dell'Epg integrata disponibile per Sky It, Sky Uk, Cyfra, CanalSat, Canaldigital e Digital+, o ancora delle novità introdotte nelle skin.
ah finalmente così mi piaci!!:D
Se non ne hai bisogno lascia ad altri la critica della non chiarezza!!
La presentazione di una nuova imagine e sempre stata così .. ora arrivi tu e deti le nuove condizioni, non ti pare un pò presuntuoso?
Chiunque ha delle cose da chiedere sulle novità le chiederà e qualche esperto (vedi tu Raskino) le spiegherà.
Grazie della collaborazione :)
Fino a prova contraria, tutti i team hanno presentato le img con un testo unico su tutti i forum, questa fatta qui non è certo una novità quindi. Penso sia inutile aggiungere altro visto che il post è piuttosto nutrito. Se poi uno non ha voglia di leggerlo tutto è un altro problema, suo in questo caso, visto che le novità sono ben descritte e visibili anche dalle immagini. Personalmente non mi sono limitato a postare l'uscita dell'img e basta, l'ho provata ben bene, stai certo. Il testo non è doppio, perchè se forse non l'hai notato si tratta di img per modelli diversi, il DM 800 e il DM 8000, che presentano delle differenze, come per altro evidenziate nello scritto, nel secondstage e nello skin di default.
Ciao lorenzo64
beh non è questione di presunzione ma bensì di mediocrità!
Ciao lorenzo64
forse ha postato la stesso post angel ieri?è solo un post sotto il tuo..
Te l'ho anche spiegato che sono 2 img diverse e ti ho descritto anche alcune differenze, perchè insisti? Hai toppato finiscila li, capita a tutti di sbagliare, ma perseverare diventa diabolico.
Ciao lorenzo64
E' la seconda volta che alzi il polverone Raskino, fai in modo che sia l'ultima.
