Nabilosat Enigma2 Black Hole - DM800 v0.5
Ang.Junior
DIGITAL-FORUM SPECIAL GUEST
2 Settembre 2003
What is new in this version 0.5 ?
Enigma2 Version 2.6 experimental
This version of Nabilosat Black Hole is using the experimental version 2.6 of Enigma2. The image is very fast, reliable. Zap speed is even better than ever​
NOTE
You can install this image to flash, without any further support.
You can install this image to multiboot. In this case, you must have an updated image installed to flash. Else, many new features will not work properly.
Nabilosat team reccomends the Nabilosat DM 800 Pure Flash dated 11 December 2008, or other images released from today onwards. The CVS of the image in flash must be after 11 December 2008.​
Enigma2 CVS date
11/12/2008​
New skin Nabilosat Exclusive by Matrix10
Matrix10 released a brand new skin for this new version of Black Hole​
Blue Ray mkv file format support
This version of Nabilosat Black Hole 0.5 for DM800 includes full support of Blue Ray mkv files. Play them directly in your DM.​
Enigma2 Integrated Sky IT EPG
Updated Sky EPG IT, including full titles for 8 days. By MaxZ4​
OSD with Channel Number
The OSD Info Bar will now display the channel list number.​
OSD with Orbital Position and Satellite Name
The OSD Extra Info Bar will now display the Satellite name and orbital position​
Drives and CVS
Updated to the lastest available version
Web Interface
Updated Nabilosat Web Interface.​
Web Interface
Button icons fixed. Now you know what to press on your remote control.​
Grabber
The Grabber version is the latest available
NEW NEW NEW: Latest Plugins CVS 10 December 2008 directly tested and integrated in the image
configurationbackup
mediascanner
webinterface
graphmultiepg
pictureplayer
mediaplayer
antiscrollbar
autotimer
emailclient
epgrefresh
fritzcall
googlemaps
httpproxy
imdb
lastfm
mosaic
ofdb
passwordchanger
permanentclock
rsdownloader
simplerss
startuptostandby
trafficinfo
unwetterinfo
vlcplayer
webcamviewer
werbezapper
zaphistorybrowser​
NOTE. Most plugins will be available in MENU>PLUGINS or Nabilo Green Panel. Other plugins will be available in the Extesions Menu ( long press blue button )
NOTE. Permanent Clock is enabled by default. To disable it, go to MENU>PLUGINS> Permanent Clock.
Main Function ****
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button Blue-Long-Push = Extensions
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time Shift​
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server​
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information​
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
NEW LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel​
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
About​
Save
Select/Start/Restart EMU​
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics​
Scripts
Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, nixus, DeepDiver, Robyhummy.
Credits
E2 Sky Epg loader integration by MaxZ4.
Matrix10 for the new Exclusive skin.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any **** nor softcams.
Backups or other modified Images are not supported!
WARNING.
This image includes DVB drivers released today. Therefore, if you install it to multiboot, it will not work with any previous image in flash. If you install it to multiboot, you must install either the Nabilosat Pure Flash DM 800 dated 11 December 2008, or any other image release from today onwards.
ATTENZIONE.
Questa immagine include la serie di DVB Drivers pubblicati oggi. Quindi, se la installate in multiboot, assicuratevi di aver installato in flash la Nabilosat Pure Flash DM 800 del 11 Dicembre 2008. Se installate una altra immagine in flash, assicuratevi che il suo CVS sia successivo alla data di oggi.
Visto che ci sono dei betatester che sono membri del nostro forum di grazia potrebbero darcene una recensione???
