Nemesis 1.02 dm600pvr
Team Nemesis-Project: Gianathem, Verbatim, Mej, 3mendo, Bati®
Technical Infos:
* opendreambox v 1.4
* Enigma of: 10.05.2007 (fix Gianathem)
* Linux version 2.6.12
* GCC 3.4.4 Original CVS 1.1.0
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* Tuxtxt v. 1.99
for use in multiboot in USB, NFS, CF or flash
Function Buttons:
* BLUE - Nemsis Panel
* BLUE > 1s - ECM INFO
* 2x BLUE - Addons
* YELLOW – Plugins
* YELLOW > 1s – EMU - CS Info
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN – subservices
Features:
* Nemesis Manager 1.0.2
* Nemesis Manager in italian & English
* Independent Start & Stop
* Advanced Inadyn service configuration, with log manager
* Advanced external programs control
* Can start / stop your own binary by panel (see /var/etc/sample_startup.sh)
* Can create your own autostart boot script (see /var/etc/sample_startup.sh)
* Support for gSUB via advanced external programs control
* Advanced User Script
* Can run script in kernel mode
* Automount (see /var/script/mount.sh)
* Advanced System info (see /var/etc/script.xml)
* Advanced *** info (see /var/etc/emuscript.xml)
* Parental control shortcut
* Nemesis news
* MediaHighwayEpg
* emm, ecm support
Display Function:
* Army normative supported
* Display Snr, Agc, Ber
* Display video info
* Display frequency, polarization, symbol rate
* Display *** in use
* Display service providers name
* Display CaID, ProvID, PID
* Display Decoding Source (you can hide if you want)
* Display DC as IRDETO in OSD
* Display long date format
Addons:
* Advanced addons Manager
* Internet addons download with Proxy support
* Manual addons install
* Remove installed addons
No keys, No *** included
Note
Con la Nemesis potete scaricare tramite internet gli addons (legali ovviamente) messi a disposizione da Genesi-Project, per chi non fosse soddisfatto dei nostri gusti l'immagine è progettata in modo da poter inserire in var/etc un file formato unix che si chiamerà extra.url contenente il link del vostro server http personale, il formato dei file riconosciuti dalla Nemesis dovrà essere .tar.bz2 rinominati poi in .tbz2, nel menu si aggiungerà automaticamente una voce come potete vedere dalla foto sotto:
Sorgenti
Genesi-Project e il Team Nemesis-Project hanno deciso che i sorgenti di questa immagine saranno, a breve, Pubblici, l'unico vincolo (se così si può chiamare) è che gli utenti che useranno i nostri sorgenti sviluppino il loro lavoro nel nostro forum e che nelle info delle eventuali immagini da loro prodotte venga evidenziato che i sorgenti sono della nemesis, ovviamente non siete obbligati ma a noi farebbe molto piacere che si rispettassero queste 2 piccole regolette dato che nessun team fino ad ora li ha forniti, per i furbastri dato che ci sono sempre
sappiate che in qualsiasi momento siamo in grado di vedere se una immagine è stata fatta usando i nostri sorgenti. Chiaramente, per ovvi motivi, non forniremo supporto per i sorgenti, se non in maniera molto limitata
[/quote]
Appena testata veramente ottima
Technical Infos:
* Busybox 1.01
* Tuxtxt v. 1.99
Function Buttons:
* 2x BLUE - Addons
* YELLOW – Plugins
Features:
* Nemesis news
* MediaHighwayEpg
* emm, ecm support
Display Function:
Addons:
Note
Sorgenti
[/quote]
