Neutrino Dream Plus_dm7000_nplus_v2_20060623_OK
Ferbius
Digital-Forum Silver Master
2 Marzo 2002
Welcome on Neutrino.DREAM Plus!
v2.00/20060623OK
file: dm7000_nplus_v2_20060623OK.img
md5sum: CDB2314999CEBD9036B38520EA2D1EB9
Kernel 2.6.9 Squashfs 2.2-r2 LZMA-Patch
version=2200200606232149
comment=ruDbox dream image
creator=ruDbox
Question: How to switch off RC-click beep?
ANSWER: Main Menu/Settings/Key Setup/Key click =on/off
2006 0623
added yWeb v2.1 (Let's try it!)
MoviePlayer.
added new function botton OK - channels-list output
if it not working try to stup new key for "Play"
it must be any botton but not OK
MHW-Epg.
Before You make a start, see /var/bin/realgetepg.sh and editing it for your choice.
1. Zapit to one of:
NOT TESTED! Canal+/CanalSatellite France : Astra 19.2E / 12363 V / 27500
NOT TESTED! Canal Digitaal : Astra 19.2E / 12515 H / 22000
NOT WORKING! Digital+ : Astra 19.2E / 10847 V / 22000
NEED MORE FREE SPACE AND MEMORY THAN DBOX2 HAS!Sky Italia : Hot Bird 13E / 12418 V / 27500
WORKING! Cyfra+ : Hot Bird 13E / 10719 V / 27500
2. Main menu->Scripts->Load MHW epg
Think about.
You can make your personal scripts for save and restore all epg, not mhw only.
sectionsdcontrol --saveepg /hdd/your_dir - save epg to /hdd/your_dir
sectionsdcontrol --readepg /hdd/your_dir - reading epg from /hdd/your_dir
Virtual Zap.
Settings->Misc settings->-------General-------Virtual Zap: ON/OFF
EPG Cash.
Settings->Misc settings->-------Epg settings-------
Be carefull with "Dir for epg cash"!!!
There is must be freespace on hdd or your mount-partion/directory named as /hdd/, /mnt/, /media/, /tmp/.
Example: /hdd/epg, /mnt/your_dir/epg, /media/your_dir .
Some changes on Channels-List under recording.
More big and small fixes and new bugs presenting for test.We have nothing against modifications to our Enigma/Neutrino
images, if you follow our small conditions, namely:
1. The original Readme files must remain in archives with
your mod image.
The same counts to all readme and info files within the image.
How can you check who is original creator of the image?
There is information in file called ".version" in root
directory of every image.
Please, leave it also unchanged.
2. NO KEYS/RSA/ROM files within your renamed - modified image.
3. We are glad, NAME of our team(ruDbox) in file names of your
archives and mod image independently to see,
e.g. - ruDbox **** _mod_your_name or your_name_mod_ruDbox ***.
That's all.
Certainly you cannot follow our requirements and continue
everything like it is.
Believe, however, that attention of our friends who use
our private images is enough for us.
ruDbox Team
#dbox2 /Dalnet
Su I-HAVE :icon_wink:
