NewCS v 1.31
Ferbius
Digital-Forum Silver Master
2 Marzo 2002
NewCS v 1.31
Found on the net:
Added support for Nagra "3" (Rom 142 cards).
Brand spanking new Web-console (look at httpd section in default config).
Completely rewritten tcp-console.
Added manual ecm/emm sending.
Fixed timeing on ATR (should be alot faster for slow cards!).
Increased timeout on SCI commands, should fix some Big Conax EMM's.
Default config for x86&/i686 is now /etc/newcs.xml.
Fixed uptime should be correct on win32 now!
Added "advanced" mode for tcp-console - to hide possibly scary manual ecm/emm sending.
Fixed so it increase reset-counter on manual reset.
Fixes for some Irdeto cards in SCI.
Fixes to Irdeto EMM-AU code.
Fixed should now send Issuer Ident for Viaccess again.
