News DaVinci 5.6
Neri73
Collaboratore
19 Gennaio 2003
Brescia
SDT DaVinci 5.6 FINAL
- Kernel and modules 2.6.9 (1_09.1d)
- Enigma compiled 09/05/2006 - CVS modified by SDTeam
- WebIf 5.9.7-expert + TELETEXT !
- TuxTxt 1.98 (teletext)
- Movieplayer 0.8.1
- SDTboss Panel v2.6.8
- emuboss v2.9.5 (emumanager)
New in DV 5.6:
- TeleText (Televideo) now available also from Web-Interface (new very useful new CVS feature)
Go to web-int, then press "TEXT" link on the top-right (near VLC button)
- TunerA icon on OSD:
Already available on 7025, but new on 7000:
icon lights when the service is tuned, stay black if tune has failed, or channel is not transmitting a signal.
- FlashWizard remote:
now is useable also from Multiboot installed images, allowing full operations.
No more need to use it only from flash image.
- all skins updates:
Anim5.6 new from Mimi74
Megalight 1.3a from Eagle
- full cleanup of OSD implementation:
now only the needed infos are displayed in each operating mode (TV, Radio, File)
- bugfixes and updates, as ever! :-)
New in DV 5.5:
- Support for an alternate Remote Control (!! new !!):
On DaVinci 5.5 you can select the keymapping for "Philips Pronto" or another compatible programmable remote control.
This is an absolutely innovative option, never seen on any other image before!!
- ECM Display on OSD:
Yellow, if encrypion is present (emm)
Green, if it is used for decoding (ecm)
- Decoding source display on OSD (card / emu / network)
- Added Betacrypt to known encryptions icons, displayed on OSD for ecm and emm
- Camd3:
added caInfo as default item when SDT Advanced Infos window displays.
- Gbox:
added SC item on SDT Advanced Infos window, displays full infos on inserted sc.
- Skins:
Added latest Mimi "Anim 5.5" compact/extended 4:3/16:9, and Eagle's Megalight 1.2
- Locales:
Added updated Italian and French translations
- A/V Settings shortcut:
Added very useful shortcut to "Audio/Video Setup" window in BOSS Panel's "Extra Setup" (3x Blue Key)
- EPG Wizard:
updated default download channel to "SKY Assist"
- As ever:
various updates and fixes to emuboss and all the rest
Ciao :D
Problema installazione "manuale" in /Tmp degli EMU
Inserendo con questa versione della Davinci l'emu newcamd 10 nella solita directory l'opzione installazione manuale trova il file ma non lo riconosce come valido.
Qualcuno sa il perche`?
Grazie e ciao
Assicurati che il file abbia come estensione tar.gz, scaricalo direttamente dal sito ufficiale per essere certo che sia quello buono.
L'EMU in questione era stato scaricato dal sito ufficiale SDT ed in piu` funziona perfettamente con la DaVinci 5.5.
Sembra quasi che il formato che la DaVinci 5.6 vuole sia diverso dal solito (.tar.gz)
Qualcuno sa il xche`?
Ciao e grazie
Io ho scaricato l'emu dal menu della davinci 5.6, ha scaricato e installato senza problemi.
Idem per me, nessun problema, attento che anche le emu per DBB hanno la stessa estensione della Da Vinci...
