Nonostante la JTAG dopo il gold
deleolino
9 Dicembre 2006
Ciao, dopo aver inviato il gold che è andato a buon fine quando ho cercato di inviare alla ram, il crak
Spento... Ho recuperato con la JTAG ma non del tutto ti invio il dump (dopo il recupero) Mi dai uno sguardo e poi consigli?
Grazie Grazie:========================================
Samsung Brand 5512 Model
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
Select Download
Timeout
Reboot
AVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STCLKRV_Init(CLKRV0)=Ok
Demodulator OK!
PTI_Init()=Ok
STCLKRV_Open(CLKRV0)=Ok
declared symbols = 0 (0 commands + 0 macros + 0 strings + 0 numbers)
allocated symbols = 0 / 0
free memory size = 800000 bytes
STAUD_Init(AUD0)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
>>>>>>>>>>>>>>>>>>START TELETEXT INIT<<<<<<<<<<<<<<<<<<<<<<<<<
>>>>>>>>>>>>>>>>>>END TELETEXT INIT<<<<<<<<<<<<<<<<<<<<<<
STTTX_Init(TTX)=Ok
STAUD_Open(AUD0)=Ok
STVTG_Open(VTG0)=Ok
STVID_Open(VID0)=Ok
5512STDENC_Init : Done
STDENC_Open, Device 'DENC0' Opened
5512STDENC_SetEncodingMode : Done
STVTG_SetMode()=Ok
Mode 576,50,27000
STVTG_GetMode(Active XYWH 132,23,720,576 Scan 2, FRate 50)=Ok
Device 'OSD0' initialisedSTVTG_GetMode(Active XYWH 132,23,720,576 Scan 2, FRate
50)=Ok
OSD: Region creation . . . passed
OSD Region: W=720, H=576, X=0, Y=0
OSD: top_address = C00D8508, top_address_tail = C010AF08
OSD: bot_address = C010B408, bot_address_tail = C013DE0
OSD: set draw region addresses . . . passed
OSD: palette init . . . passed
uncompress font20 data ...
uncompress font24 data ...
uncompress font16 data ...
- fonts compact -> ON
- fonts gzip -> ON
OSD: Initialized
STDENC_EnableVideo : DoneError STOSD_GetScreenParams Ok
Error STVID_GetScreenParams000
[TEST_CYRUS] Register couple functions for test of 'boot-main cross'
DEVELOP_InitCommand() : macros registrations ok
[CA_GLUE]CAS MODEL:00000001
[SCPRIM](2)CARD NO: [VIA_detect_monitor]:smart card detect monitor
[VIA_monitor_init_sc]smart card init monitor task started...
0
[SMART-MAN] CONTEXT: c0778df8, dl:1, il:7
[T0]!!!!!INSTALL INTERUPT!!!!!
Due domande:
1) Che problemi ti dà adesso che lo hai recuperato?
2) Quale firmware hai inviato con la JTag?
il firm*are è il dsa9500mcmain.bin con jkeys.exe.
Ho provato anche altri firm con lo stesso risultato:accende il display scrive 9500- si intravede la videata iniziale con la scritta samsun in blu e subito si blocca senza nessuna indicazine sul display. riAccendendo stessa cosa.
Con Seriale sia con iperterminal sia con samedit carica i firmw ma il risultato non cambia. In attesa tuoi consigli Grazie, saluti.
Ricordi la versione del loader che aveva il tuo decoder? Era 500 o 501?
In area download del forum trovi i file con il bootloader del 500 e 501, prova a rimettere quello giusto e vediamo che succede.
Ho provato sia con il 500 sia con il 501
risultato: scrive 9500 videata verde e si blocca
dopo il boot 500 501 cosa devo altro caricare ?
è importante usare wind 98 io ho usato XP.
il caricamento dei firm*are vanno a buon fine sia con jtag che con seriale.
Modifica quanto detto : Ho provato con il boot 500 ed il firm 112 e tutto ok
ma non lascia poi aggiornare a versioni nuove quale procedura è comunque bene utilizzare com e sequenza ?
Grazie Grazie
Grazie Grazie
Visto che ci sei aggiorna al boot 501 che come abbiamo visto non ha problemi.
Ciao Corino Grazie di avermi risposto
Ho cariacato il Boot 501 e poi il firm 112 e tutto ok
se carico altri firmw non va .
è il 9500 ci.
cosa ne pensi?
ciao Grazie.
Perchè hai voluto mettere il gold sul CI?
Comunque è strano che la procedura sia andata bene e poi non ti fa caricare altri firmware: che messaggio ti da?
Ciao Sul 9500 Ci il gold no?
con altri Firm : scrive 9500 videata verde e si blocca senza indicazioni sul display. Nessun messaggio.
Il 9500ci solo da usare come freetooair?
Lo aveva già testato l'amico Cuorino e il resoconto purtroppo diceva che non si può usare il gold sul 9500 CI.
Potresti accoppiarci una buona cam.
