Nuova CVS boxman
Valmont
Digital-Forum Senior Plus
18 Gennaio 2003
ein neues, aktuelles CVS-Image von heute Abend für die 7000er:
Änderungen/Fixes aus dem CVS:
rcS: fix cf mounting
webif 5.9.2: fix streaming of movie files to pc for vlc versions > 0.8.1
movieplayer adaptation to vlc 0.8.4 (untested)
movieplayer: add 25 fps to sout for vlc 0.8.4 (untested)
movieplayer: better transcoding defaults
movieplayer: add workaround for vlc webif deficiencies in playlist handling
tuxcom: 22.01.2006 Version 1.13
- overwrite directory fix (update by dbluelle)
movieplayer: play movies til the very end
epgcache.cpp: add byteorder check to epg.dat
Incl. satellites.xml by Reinh@rd (23.01.2006).
with-webif=expert
with-epg=private
with-mhw-epg=yes
with-flashtool=expert
with-reiserfs=yes
with-ext-flashtool=yes
with-enigma-debug=yes
with-pmt.tmp
md5: 72e0e8d0d505a3c136facc8e1a278658
Interessante la annunciata maggior compatibilità con le varie versioni di vlc
