Gemini2 v1.00:
Technical Infos:
* Enigma vom: 17.02.2006
* GCC 3.4.4 Original CVS
* Busybox 1.01
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* RED - Record
* GREEN - Subservices
* TEXT - VIDEOTXT
Features:
* Own Addon-Server via internet
* Downloading and installation of additional features via Internet from Gemini server
* EMM- und ECM- Display switchable
* Behaviour of infobar can be changed via Menu
* System Info: Many extra box infos (for example harddisk-temperature, storage usage, mountpoints)
* Extra Menu: Settings to many extras like Inadyn, HTTPD, NFS-Server, calendar
* Own Scripts can be started via Blue Panel
* Calendar including reminder (can be changed via /etc/calendar.xml)
New:
* Usage of USB hard disks as well as USB Sticks
* Support for CDROM/DVD, no matter if IDE or USB port
* Create your own Satellites.xml
* Dreambox can be used as printserver
* Menu for setting of SYSLOG
* Extended settings for Infobar
* Enahanced Systeminformations
* Embedding of kernel modules in extra menu
* Videotext ((Tuxtxt 1.96 für 7025 - Beta))
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Se volete provarla la trovate su I-HAVE
Technical Infos:
* Busybox 1.01
Function Buttons:
* RED - Record
* TEXT - VIDEOTXT
Features:
New:
