Nuova Gemini2 v2.40
Ferbius
Digital-Forum Silver Master
2 Marzo 2002
Gemini2 v2.40:
Technical Infos:
* Engima from: 31.05.2007
* GCC 4.1.1 Original CVS
* Kernel 2.6.12.6
* Busybox 1.0.1
* Tuxtxt 1.95
* CIFS 1.44
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP
* 2x BLUE - BP -> Extras/Settings
* RED - Record
* GREEN - Subservices
* Yellow - Timeshift
Addons:
* Own Addon-Server via internet.
* Downloading and installation of additional features via internet from Gemini server.
* Use your own Personal addon server (configure it in /etc/useraddon.xml).
* Create your own Satellites.xml which only includes the satellites you need.
Camd:
* Assign of different Camd's to Stations/Providers (AutoCam).
* Change of the name and different functions over own menu.
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Device Settings->Printer (LPD), FAQs in the database).
* Dropbear (ssh) now switchable (BP->Extras->SSH).
* Upnp Server / Client
* automount, examples in /etc/automount.conf. Devices, NFS or CIFS get automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found at BP->Extras->Automount).
* Inadyn (Daemon for various DYNDNS-Services).
* little Apache (HTTP-Server based on HTTPD).
* NFS-Server (based on the NFS-Kernel-Modul).
Infobar / OSD:
* Provider and Sattelite will be showed in the Infobar (depends on the skin).
* EMM, ECM or "ExpertInfos" Display switchable.
* Picon (displays the station logo)
Files / Devices:
* Support for CDROM/DVD.
* HDD- temperature and performance visible in the menu.
* HDPARM values for harddisks disk can be changed by menu.
* SWAP setup and start automatically.
Extra:
* Dreamnetcast (shoutcast-player) with Streamripper (direct recording from server and coding into mp3´s).
* Weather Plugin with 10 days forecast.
* RSS/RDF reader with TOP list from RSS-scout.
* Webcam-Viewer with FullScreen mode.
* bell (plays mp3s on a fixed time)
* System Info: Many extra box infos like stream-rates, kernel-, memory- and prozessinfos.
* Own Scripts can be started via Blue Panel.
* Kernel modules can be reload separately.
* Password can be changed over the menu.
* EPG Cache and EPG Refresh (updates the EPG in the night) adjustable over BP.
* flashing clock when recording in standby.
New:
* Showing Onlinestatus when the Box is connected to the Internet (must be activated in the BP -> Extras/Settings/Online)
* Calendar for the iCalendar format + Reminder (supported by MAC, KDE, Thunderbird, Google calendar, Rainlendar…) , Standard-folder is /etc/ical.
* Spinner (response time adjustable of 0,5 to 2 sec. and deactivate).
Fix + Updates:
* see CVS
This Images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Da caricare subito :D
ottimissima NOTIZIA!!! :D
ma.... "component" nn è ancora supportato come dalla LT-image?
Grazie per l'info caro Ferby certo che e' giunta proprio ora che stavo organizzandomi per fare un mega aggiornamento, bary allen ecc ecc. Bhe forse meglio cosi.
Voi l'avete gia' montata e provata ? Come va ?
ciao
Lastrico
Va bene come la vecchia precedente, differenze non ne ho viste a parte i due ingranaggi che girano nel bootlogo copiati dalla LT, cercherò più a fondo per vedere cosa c'è di nuovo cvs a parte
ciao
nono, nn và come la precedente....va peggio!
ingranaggi a parte, che potrebbero esser pure simpatici..... è stata tolta la possibilità di attivare USB-ide/add su BluPanel-ExtraSetting-KernelModules, questo fà si che compilando Automount x montare una pendrive-USB, questa venga montata,ma....quando si tenta l'accesso si riceve un bell'access-denied!!! (e relativa schermata BLU se si fa da un applicazione del Dream) :(
BEL PROGRESSO!!!!! :D
GraZzZie Gemini Team!!!
Ciao cari, ieri ho fatto un po' di pulizia, ho cambiato la versine ed ho messo la 2.4 in flash ed ho installato anche barryAllen.
Ma come si toglie l'ingranagetto che gira ?
E poi come si aggiunge una voce nel menu che esce quando si preme il tasto blu a lungo ? Ho visto che Barry Allen e' richiamabile anche da li e prima che lo installassi non c'era.
buona settimana a tutti
Lastrico
Ma pensa un po!!!! perchè lo avranno fatto?
comunque in multiboot ho ancora la 230 e la 220 speriamo che nella prossima
rimedino a questo bug, tanto non abbiamo molte alternative visto che il team colosseum è praticamente scomparso dal pianeta 7025
ciao
a sto installando adesso, ero fermo alla 2.20, ha effettuato anche l'upgrade dellFront Processor..speriamoi bene:D:D
